Phobos G100 10/100 GIO32 NIC
orionpi
Unread postby orionpi » Wed Feb 05, 2003 11:31 pm
I've found very little info on the card, and thought I'd post a photo and let people know it works. Drivers are avaliable from SonicWall (http://www.sonicwall.com/support/Other_products.html), they claim it's an EISA card, but is GIO32. I have it working on my Indy under IRIX 6.5 in slot 1 with slot 0 occupied (I don't know if the Indy has the same DMA limitations of the Challenge S).
Shtoink
Unread postby Shtoink » Wed Feb 05, 2003 11:34 pm
Very cool! 8)
That's one SICK Indy you got there man...
Re: Phobos G100 10/100 GIO32 NIC
Unread postby nekonoko » Wed Feb 05, 2003 11:35 pm
Cool! I have Phobos G130 GIO32 card ... it's also available for sale ;)
orionpi
Unread postby orionpi » Wed Feb 05, 2003 11:37 pm
Shtoink wrote:Very cool! 8)
Still could upgrade the G100 to a G130 and replace the 4x16MB with 4x32MB. And even overclock the R5k to 200Mhz. It's still "upgradable".
Shtoink
Unread postby Shtoink » Wed Feb 05, 2003 11:38 pm
BTW O, how's that Challenge S?
akimmet
Unread postby akimmet » Sun Feb 09, 2003 11:11 am
Just as a warning, a g100 will only work in 100baseTX mode, and will *NOT* negotiate with 10baseT interfaces. So hook it up only to a switch, or a 10/100 hub with only 100baseTX stuff hooked to it. I found that out the hard way...
orionpi
Unread postby orionpi » Thu Feb 20, 2003 9:45 pm
akimmet wrote:Just as a warning, a g100 will only work in 100baseTX mode, and will *NOT* negotiate with 10baseT interfaces. So hook it up only to a switch, or a 10/100 hub with only 100baseTX stuff hooked to it. I found that out the hard way...
Thanks for the warning, it works great for remote X-sessions :)
Shtoink
Unread postby Shtoink » Fri Feb 21, 2003 9:08 am
You need to set up a webcam or an indycam in the basement O...
That would certainly scare a few people, maybe even get a shot of Binky mixin on his turntables. 8)
