HELP! Kernel Panic!!
OSWebman
Unread postby OSWebman » Sun Apr 18, 2004 10:05 am
After a lot of tinkering, the Octane boots and passes diagnostics, but all versions of Irix that I have on hardisks give me Kernel Failures on mainboards that have been used for a while. Short of tossing the system and/or components how can I fix this? Is there anyway to boot without any services through sash ie..single user mode or overide a kernel fault?
PANIC: KERNEL FAULT
PC:0xa8000000202e7d40 ep: 0xffffffffffffbc48 EXC
code:128 'software detected SEGV'
bad addr: 0x3e8 cause: 0x8<CE=0
The mainboard connectors are perfectly clean.
Please help out, any suggestions are useful...I feel like I'm so close to the finish line/login screen.
Thank you,
Eugene Redko
cosmos
Re: HELP! Kernel Panic!!
Unread postby cosmos » Sun Apr 18, 2004 1:26 pm
OSWebman wrote:After a lot of tinkering, the Octane boots and passes diagnostics, but all versions of Irix that I have on hardisks give me Kernel Failures on mainboards that have been used for a while. Short of tossing the system and/or components how can I fix this? Is there anyway to boot without any services through sash ie..single user mode or overide a kernel fault?
PANIC: KERNEL FAULT
Thank you,
Eugene Redko
boot single
or just single
from the sash. cant remember right now, way too many litres of whiskey
The preceding thoughts were brought to you by Jack Daniels.
