Network traffic
JacquesT
Network traffic
Unread postby JacquesT » Tue Apr 17, 2018 11:54 am
Could anybody advise how to check for transfer speed (bits or bytes) via ethernet port? I'm busying transferring stuff from my debian NFS server and it's taking for ever, even for a measly 600mb.
Could be either command via debian / irix. Thanks.
:Octane: - 1xR12k 400Mhz, 1GB, V8, 18Gb 10K & 36Gb 15K HDD, 6.5.30
:Octane: - 1xR12k 300Mhz, 384MB, SSE, 18Gb 10K HDD, 6.5.30
:O2: :1600SW: - 300Mhz R5200, 384MB, 36Gb 15K HDD, A/V, FPA, 4x CD-ROM, 6.5.30
"Ho Ho," Says the keeper of the beat.
mrthinlysliced
Re: Network traffic
Unread postby mrthinlysliced » Tue Apr 17, 2018 1:49 pm
I like to use gkrellm on linux if I have ssh access and X on the client.
Gives all the usual telemetry suspects like cpu, mem, swap, load, disk + network. Gives friendly human values like K etc.
Otherwise under linux you could use any of these (bmon is nice):
https://askubuntu.com/questions/257263/ ... e-terminal
rooprob
Re: Network traffic
Unread postby rooprob » Wed Apr 18, 2018 7:43 pm
If you only have tcpdump,
substitute the correct interface
# tcpdump -i en0 -nn -tt  | perl -ne '($ts) = (/^([\d\.]+)/); ($l) = (/length (\d+)/); $int+=$l ; if ($ts-$p >= 1 || eof) { printf("%02d:%02d:%02d %10.2f Mbytes/s %s\n", (localtime($p))[2,1,0], $int/1024/1024, "." x ($int/1024/1024)); $p=$ts; $int=0;}'
14:41:44       2.00 Mbytes/s ..
14:41:45       3.98 Mbytes/s ...
14:41:46       2.03 Mbytes/s ..
14:41:47       3.76 Mbytes/s ...
14:41:48       2.39 Mbytes/s ..
New Zealand
shutitalldown
Re: Network traffic
Unread postby shutitalldown » Thu Apr 19, 2018 1:31 am
umm, nettop is a text console"top"-like program for network activity
I am tattooed in reverse, cause if you break rules you don't know where it leads.
But, say, all the venus in furs are so manically depressed and manically dressed.
Users browsing this forum: Ahrefs [Bot], Majestic-12 [Bot], Yandex [Bot] and 4 guests
