Tezro start up - stuck on PROM BOOTING
Unread postby uunix » Mon Mar 19, 2018 12:11 pm
Here's what I have so far .. memory miss-match?
entering console mode  001c01 console, <CTRL_T> to escape to L1
WARNING: power on 001c01 appears off!
Starting PROM Boot process
IP35 PROM SGI Version 6.181  built 04:34:43 PM Mar 19, 2004
*** Memory sizing failure:
*** Bank 0 (512 MB) and bank 1 (1024 MB) sizes differ,
*** treating them both as 512 MB
*** Bank 2 (1024 MB) and bank 3 (512 MB) sizes differ,
*** Mixed standard and premium memory:
*** Treating all as standard.
Discovering local IO ......................             serial_dma: Timeout on uartA dma ....
serial_dma: Timeout on uartB dma ....
serial_dma: Timeout on uartC dma ....
serial_dma: Timeout on uartD dma ....
serial_dma failed:
RSLT serial_dma     FAIL                diag_rc = 75
A 000 001c01:
A 000 001c01: *** General Exception on node 0
A 000 001c01: *** EPC: 0xc00000001fc44e9c (0xc00000001fc44e9c)
A 000 001c01: *** Press ENTER to continue.
A 000 001c01: POD SysCt Dex>
Irinikus
Re: Tezro start up - stuck on PROM BOOTING
Unread postby Irinikus » Mon Mar 19, 2018 12:22 pm
I'm sure you know this, the 1GB sticks have white markings and the 512MB sticks have green markings.
The memory must be matched in this way:
Image ... Image
Unread postby uunix » Mon Mar 19, 2018 12:32 pm
Irinikus wrote:I'm sure you know this, the 1GB sticks have white markings and the 512MB sticks have green markings.
Just removed and reset memory, and It passes.
serial_dma failed:
A 000 001c01:
[EDIT...]
tried a working i09 board, still no good.
Unread postby uunix » Tue Mar 20, 2018 2:24 am
Update... still not working.
Have swapped out most parts now into other system with the exception of the CPU board and the power supply.
Also swapped the memory around which has left me with reduced memory in the working system.
Testing/Initializing memory ...............     *** Swapping bank 0 with bank 2 on module 001c01 (nasid 0)
*** All other banks on the node are remapped as well.
        DONE
Now I'm getting 2560 MB instead of the installed 4GB.
There is a way to reset the registered memory at the l1 iirc but I can't recall it.
Irinikus
Unread postby Irinikus » Tue Mar 20, 2018 3:24 am
"enableall" is the command which will enable disabled memory.
Are you at least able to get as far as the prom menu?
Image ... Image
Unread postby uunix » Tue Mar 20, 2018 3:47 am
Irinikus wrote:"enableall" is the command which will enable disabled memory.
Connected via l1 currently, enableall is not available?
There doesn't actually seem a lot you can do with the memory.
Ctl T - help:
001c01-L1>help
Commands are:
check              fru                promver|promversionnode
reset|rst          prom               try                pic
make               pwm                syscom             error
pci                *                  autopower|apwr     syscom|junkbus|jb|bedrockbrick
partdb             cpu                nia|ni|ctc         nib
iia|ii|cti         iib                iic                iid
config|cfg         debug              display|dsp        button|btn
env                fan                help|hlp           history|hist
l1dbg              link               log                ioport|ioprt
istat              l1                 leds               margin|mgn
network            pimm               port|prt           power|pwr
reset|rst          nmi                softreset|softrst  select|sel
serial             sysstate           eeprom             uart
usb                router|rtr         service            date
nvram              security           flash              reboot_l1
version|ver        pbay               test|tst           scan
[Edit...]
it appears that 5 Memory modules are working, each 512Mb which also seems odd.
[Edit...Edit...]
Ah.. ok, so still talking about the working machine, it appears I do have a mixed memory module.
Memory at Module 001c01/Slot 0: 2560 MB (enabled)
  Bank 0 contains 512 MB (Standard) DIMMS (disabled)
  Bank 1 contains 512 MB (Standard) DIMMS (disabled)
  Bank 4 contains 256 MB (Standard) DIMMS (disabled)
  Bank 7 contains 512 MB (Standard) DIMMS (enabled)
Will get that sorted when I get home.
Unread postby uunix » Wed Mar 21, 2018 2:54 am
Another day another dollar..
Now back on the non working machine.
So reading this thread http://forums.nekochan.net/viewtopic.php?f=3&t=16727613&p=7359126&hilit=timeout+uart#p7359126 has helped me get a bit further. After a reset I'm moving forward.
Seems to be SCSI related anyway.
001c01-L1>power up
returning to console mode  001c01 CPU0, <CTRL_T> to escape to L1
Discovering local IO ......................             DONE
Local hub NUMAlink is down.
*** Local network link down
DONE
Found 1 objects (1 hubs, 0 routers) in 5900 usec
Intializing any CPUless nodes..............             DONE
Local slave entering slave loop
BASEIO PROM Monitor SGI Version 6.181  built 04:34:05 PM Mar 19, 2004 (BE64)
2 CPUs on 1 nodes found.
NVRAM checksum is incorrect: reinitializing.
Graphics diagnostics
        Board version 1 - Buzz revision 2B
        On board sdram size: 32 Mb
        Cas latency: CAS 3
        4 banks by sdram module
Device passed diagnostics
On-board (IO9) tigon3 1000BaseT interface
Base I/O Ethernet set to /dev/ethernet/tg0
Probing IOC4 ATA adapter 2
IOC4 RevId = 79
Detected Vendor id/Product MATSHITA DVD-ROM SR-8588
=====> scsi_dma diag took an exception. <=====
 EPC    : 0xc000000013092fc0
 BadVA  : 0x70007f00f0037f0c
 Cause  : 0x000000000000c01c
scsi_dma failed: Took an exception
RSLT scsi_dma       FAIL                diag_rc = 87  Took an exception
diag_scsi_dma: /hw/module/001c01/xtalk/15/pci/3: FAILED
A 000 001c01:
A 000 001c01: *** EPC: 0xc000000013097518 (0xc000000013097518)
Unread postby uunix » Wed Mar 21, 2018 3:02 pm
Tonight's update, I have Tezro 1 working fine again. Will post a hinv since it's rather spiffing.
Now working on Tezro 2 which has the SCSI issue.
Unread postby uunix » Fri Mar 23, 2018 2:45 am
Last night I fired up the machine without the IO9 and it went through and reached the PROM..
It sort of says the IO9 is at fault and that I should just disregard the part were I swapped the IO9 out with a working machine and it passed the tests, I must have imagined doing that. If I did, it must be some good imagination since I still have a cut on my hand trying to get the darn card in. I do not want to carry out that operation again, in fact I don't want to touch the working Tezro again.
I think this weekend, I will strip it ALL down, see what I can find.
BTW, it's a 2x700MHz job, I managed to get a tiny hinv out of it.
Unread postby uunix » Sat Mar 24, 2018 9:05 am
Have temp put low low spec Tezro by the side, as I am pretty sure it's the IO9..
But fear not.. the Tezro is still productive..
As a seat/chair
Users browsing this forum: Ahrefs [Bot] and 3 guests
