SGI Keyboards
JacquesT
SGI Keyboards
Unread postby JacquesT » Mon Mar 19, 2018 3:40 am
Hi,
Could somebody please do me a favour and measure the width of the standard granite and black ps2 SGI keyboards. I'd like to replace the current HP ps2 keyboard I use but have a slide in drawer that sits in under my desk of fixed width.
Thanks.
J
:Octane: - 1xR12k 400Mhz, 1GB RAM, V8 GFX, 18Gb 10K & 36Gb 15K HDD, 6.5.30
:Octane: - 1xR12k 300Mhz, 384Mb RAM, SSE GFX, 18Gb 10K HDD, 6.5.30
:O2: - 300Mhz R5200, 384Mb RAM, 36Gb 15K RPM HDD, A/V Module, 4x CD-ROM, 6.5.30
Re: SGI Keyboards
Unread postby robespierre » Mon Mar 19, 2018 4:38 am
The RT6856T granite keyboard is exactly 18 inches wide. The older granite keyboard is wider, but I haven't measured.
devv
Re: SGI Keyboards
Unread postby devv » Mon Mar 19, 2018 5:00 am
Hey, I have black USB SGI keyboard.
It's this one: https://www.indytech.jp/img/RIMG0117.jpg (just without chinese keys, of course :-)
SGI P/N is 062-0031-001.
It is 45.7 cm wide, and 4.3 cm high. If you extend the legs on the back side then the height is 5.9 cm.
oOoO :Tezro: oOoO
JacquesT
Re: SGI Keyboards
Unread postby JacquesT » Mon Mar 19, 2018 9:58 am
Thanks all, 45.7mm is the same width as the granite keyboard and will fit spot on. Now to find one for cheap-o...! :)
