Display issue octane emxi vga
bvgoor
Unread postby bvgoor » Thu Mar 15, 2018 2:57 pm
Hello all,
After a bit of advice, just starting to install an octane using a 13w3 to vga adapter and experience some artifacts on the display, any idea what this might be?
Thx,
Bas
computron
Re: Display issue octane emxi vga
Unread postby computron » Thu Mar 15, 2018 3:35 pm
Hello
A photography can help...
Cheers
Eve
bvgoor
Unread postby bvgoor » Thu Mar 15, 2018 4:17 pm
Sorry something went wrong whilst trying to use an attachment, 2nd try
michaelpastras
Unread postby michaelpastras » Thu Mar 15, 2018 8:46 pm
hmm... try and eject and carefully clean the connectors (both on the motherboard and the Video Board) and reseat the Octane's Graphics Module!
If it doesn't get fixed, then it probably has to do with the Video Board's memory, I guess.
JacquesT
Unread postby JacquesT » Fri Mar 16, 2018 12:26 am
Looks like a dirty connection or gfx hardware issue. Had an SSI card that did the same, nothing I did could save it. Try and clean the compression connector with compressed air and reseat the card.
Have you got TRAMs on the board?
:Octane: - 1xR12k 400Mhz, 1GB RAM, V8 GFX, 18Gb 10K & 36Gb 15K HDD, 6.5.30
:Octane: - 1xR12k 300Mhz, 384Mb RAM, SSE GFX, 18Gb 10K HDD, 6.5.30
:O2: - 300Mhz R5200, 384Mb RAM, 36Gb 15K RPM HDD, A/V Module, 4x CD-ROM, 6.5.30
bvgoor
Unread postby bvgoor » Mon Mar 19, 2018 1:23 pm
Okay tried all suggestions thx for the assistance sadly no joy
My second idea was to hook up to one of my indigo2 machines but both failed to start suspect psu problem
Not my night
Bas
mopar5150
Unread postby mopar5150 » Mon Mar 19, 2018 1:36 pm
I have had several 13w3 to VGA cables cause the effects you are seeing. Try a different cable before tearing the machine apart. Here is an example.
:Tezro: :O3x0: :A350:
Unread postby jan-jaap » Mon Mar 19, 2018 1:53 pm
TRAM problems can cause repeating patterns in the display output.
Before you pull the board out, run the integrated diagnostics from the PROM menu (option #3).
If it fails the diagnostics, pull the gfx board, unscrew the two nylon screws in the metal bracket outside, and re-seat the two TRAM modules (eventually clean with some alcohol, but don't damage the connectors). Fix the TRAMs with the nylon screws again.
Worked for me (twice) in the past to revive a malfunctioning MXE (= emxi) board. If it still fails the diagnostics, you can always try without the TRAMs, that would make it an ESSI graphics, though.
bvgoor
Unread postby bvgoor » Mon Mar 19, 2018 3:11 pm
Didn’t realise it could run without tram, I removed cleaned and reseated but will try without
Sadly don’t have another 13w3 at the moment
bvgoor
Unread postby bvgoor » Tue Mar 20, 2018 12:23 pm
Tried without tram and same result
michaelpastras
Unread postby michaelpastras » Tue Mar 20, 2018 2:45 pm
It has to be a faulty GPU. Or! A dirty connector (either on the midplane or on the GPU side)
Can you borrow a simple SI Video Board from a member and try with that?
JacquesT
Unread postby JacquesT » Wed Mar 21, 2018 1:41 am
Do you need anything larger than 1280x1024 to test with? I have a SE card you can borrow for testing purposes.
bvgoor
Unread postby bvgoor » Wed Mar 21, 2018 12:56 pm
Jacques thx let me consider it or I’ll drive up with my octane, let’s see
I tried the card in xio slot d and same result
So must be the card I think
spiroyster
Unread postby spiroyster » Wed Mar 21, 2018 1:37 pm
Might have a spare one of these going...erm spare... if you are in this part of the country ;)
bvgoor
Unread postby bvgoor » Wed Mar 21, 2018 1:50 pm
Okay henley on thames close to reading, don’t know if that’s close?
Users browsing this forum: Bing [Bot], mapesdhs and 2 guests
