Using a 1600SW on an Octane?
orb85750
Unread postby orb85750 » Sat Feb 03, 2018 12:24 pm
I have my Octane hooked up to a VGA monitor using a 13w3 to VGA cable. I just acquired a 1600sw with a Multilink too, but no cables. Anyone using a 1600sw with an Octane -- how are you doing it? Thank you.
:Octane:
Intuition
Re: Using a 1600SW on an Octane?
Unread postby Intuition » Sat Feb 03, 2018 12:53 pm
I’m trying to figure this one out too.
I think one of the video cards can output dvi
And that would get you to the multilink.
But as far as 13w3 to dve I think it would require a special cable. I see something like it on Ian’s website but it costs $50 and says “rare”.
Know that I am looking for a way to do this same set up.
Image O2 - 300mhz
aka Casey Christopher
Unread postby uunix » Sat Feb 03, 2018 1:21 pm
Intuition wrote:I’m trying to figure this one out too.
I used a setup outputting from my DCD, had to modify the cable by pulling a couple of pins out. I recall it worked, then didn't then did.. typical. The info is on this site somewhere.
orb85750
Unread postby orb85750 » Sat Feb 03, 2018 6:04 pm
Oh my, sounds like this is going to be less likely than I anticipated.
:Octane:
