Fuel strange memory issue
marmotta
Unread postby marmotta » Thu Feb 01, 2018 4:10 pm
Hi
I have a R14000 600/V10 fuel, I have two dimms of 512mb each (tot 1gb) if I put the two dimm on bank1 (slot0 and slot2) the fuel fail the memory test and the red light blink... if I put the dimm on bank2 (slot1 and slot3) the fuel boot up without issue with 1gb of ram but hinv show me: 256mb disabled for error! With hinv -v I see my two 512mb dimm and two 128mb dimm (disabled)! Why? The slots are empty
I have some time tried to clean the contacts with no success...
marmotta
Re: Fuel strange memory issue
Unread postby marmotta » Fri Feb 02, 2018 12:50 pm
Screenshots:
marmotta
Unread postby marmotta » Fri Feb 02, 2018 3:22 pm
Problem solved! And is very easy!
This is the solution:
enableall
update
init
In the past they were present two damaged dimm, and they have been disabled and never rehabilitated
