Yet another VFC compilation error post
praetor242
Unread postby praetor242 » Sun Dec 17, 2017 3:44 pm
I'm trying to create a VFO for my Dell E1909W, which is 1440x900@60, but when I compile my vfs file (https://gist.github.com/gwfisher/de68192da33eeec0d03a692837902ea5 it gives me the following errors (https://gist.github.com/gwfisher/76b8487a0d96db12bb80ee666225c2be. No clue why. I've pulled the EDID info from the monitor and also used Arachnoid's modeling calculator, which spit out similar values to the EDID. I think this is a fairly generic monitor. But not sure why it's not compiling. I've been at it all day :( HALP!
GRudolf94
Re: Yet another VFC compilation error post
Unread postby GRudolf94 » Sun Dec 17, 2017 6:02 pm
It seems to me that you made a mistake down below in the file. For that resolution there are 934 lines total, and 900 active ones, but, if I understood the VFC manpage correctly, shouldn't, in line 51 of your VFS, it be written "repeat 900" instead of "repeat 1050"? That tries to generate sync for more lines than there are on each frame...
I could be very wrong, though, I'm just a noob.
praetor242
Unread postby praetor242 » Sun Dec 17, 2017 6:03 pm
Sounds reasonable. Lemme try it.
praetor242
Unread postby praetor242 » Sun Dec 17, 2017 6:22 pm
And that worked :D Thanks!!!
GRudolf94
Unread postby GRudolf94 » Sun Dec 17, 2017 7:18 pm
Glad to help! :-D
praetor242
Unread postby praetor242 » Sun Dec 17, 2017 7:21 pm
It still glitches when it does 3D graphics though :\ Need to tweak things I guess. Not sure what to tweak. It's a V6 board, and those are touchy.
GRudolf94
Unread postby GRudolf94 » Sun Dec 17, 2017 8:35 pm
106MHz should be within the allowable pixel clock for v6. It should glitch out at above 109. But anyway, look into making a reduced blanking mode, that'll reduce the pixel clock and should work ok.
praetor242
Unread postby praetor242 » Sun Dec 17, 2017 8:44 pm
Yeah. The guide I'm following recommends that, so I'm going to fidget with it and see if I can't get it to work right.
Users browsing this forum: Ahrefs [Bot], Shiunbird and 1 guest
