Octane lightbar 'white' bulb voltage
JacquesT
Unread postby JacquesT » Fri Nov 24, 2017 12:44 pm
Unfortunatley the website
http://www.k-huhn.com/octane_mod/
is no longer up...
Does anybody recall what the supply voltage is for the white bulbs on the Octane lightbar? I've measured both 3.6v and 5v so not too sure?!
I assume to replace the blown bulbs you simply replace with a suitable LED with series resistor based on the supply voltage, diode forward voltage and diode forward current?
Thanks.
kubatyszko
Re: Octane ightbar 'white' bulb voltage
Unread postby kubatyszko » Fri Nov 24, 2017 6:04 pm
JacquesT
Unread postby JacquesT » Sat Nov 25, 2017 10:39 am
Thank you, much appreciated.
JacquesT
Re: Octane lightbar 'white' bulb voltage
Unread postby JacquesT » Sun Nov 26, 2017 12:41 am
Replaced mine with a green 3.3v 25mA LED, looks great with the earlier skins. Wanted something other than the standard white or blue bulbs you see so much of.
