Fuel - on board network connector failed
Mark_G
Unread postby Mark_G » Fri Aug 18, 2017 6:45 am
Recently my house was directly stuck with a lightning strike.
(I got a lot of damage, like a partly blown roof, broken windows, etc..)
Happily, the power-lines for my computers are very well secured, and no psu blowed away.
However, My cable network lines where electrically overloaded, and a lot of network cards, routers etc.. are now broken.
This happens also to my Fuel.
I can boot my fuel, but the lights on the network connector don't flash up.
Also On start-up I get a warning that no network connection could be established.
I checked the network cables on other systems, and there is no fault in the wiring.
So my questions :
- Are there some specific irix commands, I can check the status of the network card?
- Is there a fuse on the mobo, I can check ?
- Do I need to replace the full mobo ?
Thanks in advance,
Mark
Re: Fuel - on board network connector failed
Unread postby uunix » Fri Aug 18, 2017 6:50 am
Mark_G wrote:Recently my house was directly stuck with a lightning strike.
So my questions :
Thanks in advance,
Mark
There are PCi compatible NICs, so the board replacement shouldn't be needed.
As for checking the status, I wonder does the card appear in the hinv?
Possible, it became disabled also, and can be enabled using the on board serial connector, which I cannot for the life remember the name now. L1? heck.. Something like that.
Mark_G
Unread postby Mark_G » Fri Aug 18, 2017 7:23 am
Hello,
The Network connector is shown in hinv. It gives :
Integral Fast Ethernet: ef0, version 1,
I'll check this out. However I'm not an SGI guru.
Thanks
Unread postby Trippynet » Fri Aug 18, 2017 7:39 am
If the onboard network is toast, you could use this as an excuse to put a Gigabit Ethernet card in the Fuel. I upgraded my own Fuel this way last year and don't use the onboard Ethernet any more.
Mark_G
Unread postby Mark_G » Fri Aug 18, 2017 7:43 am
I was aslo thinking that way.
However, I like a full working motherboard too. So, I'm looking to some blown fuse.
Because the machine shows ef0 ( 'hinv -vm' and 'configmon - h').
japes
Unread postby japes » Fri Aug 18, 2017 2:22 pm
Definitely time to drop in a PCI-X gig card....but you want the onboard to work so you can install from the network.
It's possible the network chip was damaged, but I wonder if the transformer is what took the blow and could be replaced....that's where I'd look first.
Mark_G
Unread postby Mark_G » Fri Aug 18, 2017 5:18 pm
Thanks for the suggestion.
I will check the transformer.
kubatyszko
Unread postby kubatyszko » Thu Aug 24, 2017 12:51 am
Here are some pictures of the Ethernet jack and nearby area:
(note the bodge wires leading from the ethernet jack to the interfacing chip.
There are 2 components that could have failed in your case - the magnetics (transformer) in the jack itself:
http://datasheet.octopart.com/6605708-1 ... 579429.pdf
(not an exact match, didn't have time to look for it)
Or the transceiver chip:
http://www.mouser.com/ProductDetail/Tex ... 52bA%3D%3D
Both can be replaced rather easily, hope that helps.
Mark_G
Unread postby Mark_G » Mon Aug 28, 2017 8:46 am
Hello,
Thanks for all the information.
In a couple of weeks, my Fuel undergoes the surgery.
I hope that everything goes well. I'll keep you informed.
