(SOLVED) Octane 1.5 no music at startup/shutdown
def13
Unread postby def13 » Wed Aug 16, 2017 3:19 pm
I've received my SGI Octane 2 months ago and it works perfectly well, excepte for one thing : no music at startup or shutdown.
Strangely, all other system and desktop sounds words... and I can read all of my audio files with all apropriates software.
I've tried to find an answer on the net (perhaps something to switch on for the boot ?), but I have not found anything.
Any idea please ?
:Octane2: (in fact a 1.5) mono 400 Mhz - 2Go - VPro V8
Re: Octane 1.5 no music at startup/shutdown
Unread postby dexter1 » Wed Aug 16, 2017 3:38 pm
This seems to be covered in viewtopic.php?t=10309
So in the prom, do
setenv boottune 1
setenv volume 100
and plugging the speakers to either the Line out or Headphones jack should give something coming out of the speakers when booting.
def13
Unread postby def13 » Thu Aug 17, 2017 7:20 am
Thanks Dexter1 !
After a quick tour in the PROM, nothing change ... (°_°?)
So instead plug the line out in my Philips 190x6, I try with a basic amp, and it works.
Infact, the issue comes from the screen and it was easy to solve. I just have to tell the screen to set audio interface being stand alone (doesn't waiting for any video signal to start working) :
Philips 190x6 OSD Menu > More settings > Audio options > Stand-alone = On
