convert onyx 10000 to 220v outlet
MrBill
Unread postby MrBill » Thu Aug 03, 2017 7:08 am
the machine is wired for 3 phase power. i have seen elsewhere people have modified the machine to run on a 220 volt dryer outlet. how do i do so?
jebmayers
Re: convert onyx 10000 to 220v outlet
Unread postby jebmayers » Thu Aug 03, 2017 10:59 pm
Does the machine have the 3rd card cage and 3rd offline switcher? As far as I know for 2 card cage/OLS configurations it doesn't require 3 phase, it can be run from single phase 220v supplies
As for the wiring requirements I don't know off the top of my head, but I do have an Onyx rackmount that is happily running on single phase 240v (UK) power - so we can certainly compare the wiring?
Jeb
jebmayers
Unread postby jebmayers » Mon Aug 14, 2017 12:03 am
Hi Mr Bill,
Attached the circuit diagram on the inside of the back door of my Onyx rack. Do you have a similar one for your 3-phase setup to help compare?
Jeb
MrBill
Unread postby MrBill » Mon Aug 14, 2017 9:15 am
i will check tomorrow thanks. sorryto not get back to you till just now. quite busy over here.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 2 guests
