Onyx2 Reality Graphics problems
jebmayers
Unread postby jebmayers » Sun Jul 23, 2017 1:38 am
Hi all,
I recently acquired an Onyx2 with Reality graphics and it seems to have developed a fault. When booting IRIX I get the following error:
unix: |$(0x83b)WARNING: IR0: XG ERR_STAT==0x1000 after reset.
unix: |$(0x845)WARNING: IR0: XG Map RAM Parity error.
unix: |$(0x83f)WARNING: IR: Bad XG MAPRAM entry found during kona_mapram_init!
unix: IR0: ARM: Welcome to ARMLand - 0/0x0d00
unix: IR0: ARM: running...(sherwood-root 0012312203)
unix: IR0: ARM: ******************************************************
unix: IR0: ARM: * InfiniteReality/Reality Software, IRIX 6.5 release *
unix: IR0: GE0: Welcome to GELand!
unix: IR0: GE1: Welcome to GELand!
xdm[1142]: Server for display :0 terminated unexpectedly: 2560
unix: |$(0x849)WARNING: IR0: mopup timeout.
unix: |$(0x842)WARNING: IR0:  Fatal error.  bdata = 0xa800000000746000 death_reason = 17
unix: Graphics FIFO depth is 0 words.
gfxinit: Pipe 0 in bad state (0x11) ... starting postmortem
kpm[1684]: Initiating kpm dump
kpm[1684]: Kernel graphics information is corrupted
kpm[1684]: Proceeding assuming #GEs = 1, #RMs = 4
kpm[1684]: Cannot read JTAG files. Aborting
kpm[1684]: Finished kpm dump
I have tried resetting the GE eeprom using ireeprom, but this either kills itself or fails with 'cannot communicate with graphics board'
Any ideas what might be wrong? I have tried searching for the MAPRAM error but have had limited success - from what I have found I am leaning towards a GE problem?
Any insight would be much appreciated ;o)
Jeb
jebmayers
Re: Onyx2 Reality Graphics problems
Unread postby jebmayers » Sun Jul 23, 2017 5:13 am
Some more info - I get a graphics display on boot and in the PROM, and booting IRIX until it tries to initialise the GFX. I also get the display back when I shut it down IRIX.
I booted the system without graphics and managed to run irsaudit - here are the results:
IRIS 22# ./irsaudit
INFO                Unable to detect EventMon Deamon. Logging disabled.
REV                 Rev:3.3.2 Thu Jul 20 18:13:09 PDT 2006 sherwood on splat
CMDL                ./irsaudit
TEST reset          Reset
WARNING: I0: XG Map RAM Parity error.
WARNING: IR0: XG error interrupt received.
RSLT reset          PASS
TEST xgid           Report XG ID and test MAP RAM config
INFO                Revision: 00, Part No.: c102, Manufacturer No.: 2aa
INFO                MAP RAM Config = 128Kx32 bits, SSRAM type used = 32K*36
INFO                  bits
RSLT xgid           PASS
TEST xgregs         Test the XG registers
RSLT xgregs         PASS
TEST xgram          Test the XG MAP RAM
INFO                Found XG MAP RAM to have 128K entries
TRCE                Doing XG MAP RAM data path test
TRCE                Doing XG MAP RAM address path test
INFO                ERROR:Addr: 17fff8 Exp: 0007fff8 Rec: 0003fffc
INFO                ERROR:Addr: 17fff4 Exp: 0007fff4 Rec: 00000000
INFO                ERROR:Addr: 17ffec Exp: 000ffec Rec: 00000000
INFO                ERROR:Addr: 17ffdc Exp: 0007ffdc Rec: 00000000
INFO                ERROR:Addr: 17ffbc Exp: 0007ffbc Rec: 00000000
INFO                ERROR:Addr: 17ff7c Exp: 0007ff7c Rec: 00000000
INFO                ERROR:Addr: 17fefc Exp: 0007fefc Rec: 00000000
INFO                ERROR:Addr: 17fdfc Exp: 0007fdfc Rec: 00000000
INFO                ERROR:Addr: 17fbfc Exp: 0007fbfc Rec: 00000000
INFO                ERROR:Addr: 17f7fc Exp: 0007f7fc Rec: 00000000
INFO                ERROR:Addr: 17effc Exp: 0007effc Rec: 00000000
INFO                ERROR:Addr: 17dffc Exp: 0007dffc Rec: 00000000
INFO                ERROR:Addr: 17bffc Exp: 0007bffc Rec: 00000000
INFO                ERROR:Addr: 177ffc Exp: 00077ffc Rec: 00000000
INFO                ERROR:Addr: 16fffc Exp: 0006fffc Rec: 00000000
INFO                Total errors in XG MAP RAM address path test: 15
TRCE                Doing XG MAP RAM cell test.
INFO               ERROR:Addr: 160000 Exp: 00000000ffffffff Rec:
INFO                  0000000000000000
INFO                ERROR:Addr: 160008 Exp: 55555555aaaaaaaa Rec:
INFO                ERROR:Addr: 160010 Exp: 33333333cccccccc Rec:
INFO                ERROR:Addr: 160018 Exp: 00000000ffffffff Rec:
INFO                ERROR:Addr: 160020 Exp: 55555555aaaaaaaa Rec:
INFO                ERROR:Addr: 160028 Exp: 33333333cccccccc Rec:
INFO                ERROR:Addr: 160030 Exp: 00000000ffffffff Rec:
INFO                ERROR:Addr: 160038 Exp: 55555555aaaaaaaa Rec:
INFO                ERROR:Addr: 160040 Exp: 33333333cccccccc Rec:
INFO                RROR:Addr: 160048 Exp: 00000000ffffffff Rec:
INFO                ERROR:Addr: 160050 Exp: 55555555aaaaaaaa Rec:
INFO                ERROR:Addr: 160058 Exp: 33333333cccccccc Rec:
INFO                ERROR:Addr: 160060 Exp: 00000000ffffffff Rec:
INFO                ERROR:Addr: 160068 Exp: 55555555aaaaaaaa Rec:
INFO                ERROR:Addr: 160070 Exp: 33333333cccccccc Rec:
INFO                ERROR:Addr: 160078 Exp: 00000000ffffffff Rec:
INFO                ERROR:Addr: 160080 Exp: 55555555aaaaaaaa Rec:
INFO            WARNING: IR0: XG error interrupt received.
WARNING: IR0:  Fatal error.  bdata = 0xa8000000007e8000 death_reason = 12
    ERROR:Addr: 160088 Exp: 33333333cccccccc Rec:
INFO                ERROR:Addr: 160090 Exp: 00000000ffffffff Rec:
INFO                ERROR:Addr: 160098 Exp: 55555555aaaaaaaa Rec:
Killed
Irinikus
Unread postby Irinikus » Sun Jul 23, 2017 9:00 am
Just so that I fully understand, confirm that you get a display as the system boots, and only loose the display once IRIX starts it's booting process?
Is the IRIX install on the system a fresh install?
Image ... Image
jebmayers
Unread postby jebmayers » Sun Jul 23, 2017 9:14 am
Yes, that is correct, I get a display up until the GFX initiliases and it would display the login screen. I get the graphics console displaying the boot progress.
I have tried it with both the system disk that came with the system and with a fresh 6.5.30 install. It had been working with the original system disk, when it stopped I tried a fresh install of 6.5.30 on a new HDD with no luck.
Jeb
Irinikus
Unread postby Irinikus » Sun Jul 23, 2017 9:22 am
I take it that you have removed all of the graphics modules and cleaned them.
How many raster managers does the system have? and does it show you the number of raster managers present in the system as the system boots? (on the infinite reality screen)
Image ... Image
Irinikus
Unread postby Irinikus » Sun Jul 23, 2017 9:28 am
Did you carry out the fresh IRIX install on the Onyx 2 machine with the CD-ROM fitted in the machine?
Image ... Image
jebmayers
Unread postby jebmayers » Sun Jul 23, 2017 9:30 am
It has one RM8-16, and it does show the info on the PROM screen (Reality, 2GE, 1RM or something similar).
Yes, everything has been cleaned - a visual inspection reveals no bent pins. I am going to try and replace the compression connector on the GE as, well why not, it is worth a go. I am not holding out much hope though.
Irinikus
Unread postby Irinikus » Sun Jul 23, 2017 9:33 am
How did you install IRIX on the new system disk?
Image ... Image
Irinikus
Unread postby Irinikus » Sun Jul 23, 2017 9:37 am
The graphics system seems to be working properly if it shows the correct info on startup.
I'm just thinking that your install of IRIX might not have the relevant Graphics libraries for the graphics setup that you have installed in your machine.
Image ... Image
jebmayers
Unread postby jebmayers » Sun Jul 23, 2017 9:55 am
Yes it was installed on the Onyx2 with the internal CD-ROM. Regardless, the problem developed with the old system disk where things had been working fine.
jebmayers
Unread postby jebmayers » Sun Jul 23, 2017 10:02 am
Does anyone happen to know which subsystem it is testing when irsaudit doing TEST xgram? GE, RM or DG? Or even worse Midplane? That is my real fear - GE, RM I will happily replace as I was considering an upgrade anyway - DG5 would be annoying but again is replaceable, but I am not sure I want to replace the midplane.
Irinikus
Unread postby Irinikus » Sun Jul 23, 2017 10:08 am
MY Onyx 2 currently has a problem in that it simply wont display a picture with both raster managers installed (even during the initial boot sequence), but it works fine with one raster manager and both raster managers do work.
I have a DG5-8 coming in from the US, which should hopefully solve my problem as there seems to be some damage on the connector of my DG5-2.
I pray that this fixes the problem, or I may also be in for a mid-plane replacement, and that would be a real mission!
Image ... Image
Irinikus
Unread postby Irinikus » Sun Jul 23, 2017 10:13 am
I hope you can sort your machine out, I do think that it's strange that you get picture on initial boot, but not as IRIX boots!
It may not be a hardware problem.
I have had a problem similar to this before on other SGI machines, when IRIX didn't have the required library's to support the graphics hardware installed in the machine.
If you stop for maintenance, before IRIX boots and do an hinv, what does it show?
Image ... Image
jebmayers
Unread postby jebmayers » Sun Jul 23, 2017 12:19 pm
a PROM hinv is showing the graphics option. Just to illustrate that this was a sudden thing, here is the SYSLOG from the session before the error first appeared and the one where it appeared. Please excuse the time and date being wrong ;o)
Oct  8 13:59:54 6F:onyx2 syslogd: restart
Oct  8 13:59:54 6A:onyx2 unix: IRIX Release 6.5 IP27 Version 01101245 System V - 64 Bit
Oct  8 13:59:54 2A:onyx2 unix: Copyright 1987-2001 Silicon Graphics, Inc.
Oct  8 13:59:54 2A:onyx2 unix: All Rights Reserved.
Oct  8 13:59:54 6A:onyx2 unix: Setting rbaud to 19200
Oct  8 13:59:54 5A:onyx2 unix: NOTICE: Start mounting filesystem: /
Oct  8 13:59:54 5A:onyx2 unix: NOTICE: Starting XFS recovery on filesystem: / (dev: 0/179)
Oct  8 13:59:54 5A:onyx2 unix: NOTICE: Ending XFS recovery for filesystem: / (/hw/module/1/slot/io1/baseio/pci/0/scsi_ctlr/0/target/1/lun/0/disk/partition/0/block)
Oct  8 13:59:56 6D:onyx2 eventmond[119]: |$(0x200110)started - (normal mode)
Oct  8 14:00:05 3D:onyx2 mrouted[178]: can't forward: only one enabled vif
Oct  8 14:00:06 3D:onyx2 nsd[193]: NIS server for domain nicve.salford.ac.uk not responding.
Oct  8 14:00:07 6B:onyx2 syslog: opened /tmp/.mkpd_socket, fd=3
Oct  8 14:00:07 6D:onyx2 mkpd[348]: daemon started ...
Oct  8 14:00:08 6D:onyx2 sn0log: The following are messages stored in the flashlog from a previous system boot.
Oct  8 14:00:08 6D:onyx2 sn0log: End of flashlog messages.
Oct  8 14:00:11 3D:onyx2 inetd[236]: sgi-esphttp/tcp: unknown service
Oct  8 14:00:23 5D:onyx2 timed[387]: This machine is master
Oct  8 14:00:27 5B:onyx2 sendmail: Generating /etc/sendmail.cf from /etc/sendmail.mc
Oct  8 14:00:46 4D:onyx2 eventmond[119]: Warning: can't contact espdbd. The following message is normal at boot time - (normal mode)
Oct  8 14:00:46 3D:onyx2 eventmond[119]: |$(0x20011E)Can't init SSDB library "libssdb.so", current timeout is 30 sec. - (normal mode)
Oct  8 14:00:47 6C:onyx2 sendmail[463]: starting daemon (SGI-8.9.3): SMTP+queueing@00:15:00
Oct  8 14:00:53 3D:onyx2 /usr/freeware/sharity/sbin/sharityd[468]: [1] main: cannot create pid-file /usr/freeware/sharity/var/sharity.pid: [2] No such file or directory
Oct  8 14:02:49 6D:onyx2 sesdaemon[893]: starting
Oct  8 14:02:49 6D:onyx2 sesdaemon[893]: |$(0x153) No fibre channel controllers found
Oct  8 14:02:49 6D:onyx2 sesdaemon[893]: exiting
Oct  8 14:02:58 6A:onyx2 unix: IR0: ARM: Welcome to ARMLand - 0/0x0d00
Oct  8 14:02:58 6A:onyx2 unix: IR0: ARM: running...(sherwood-root 0012312203)
Oct  8 14:02:58 6A:onyx2 unix: IR0: ARM: ******************************************************
Oct  8 14:02:58 6A:onyx2 unix: IR0: ARM: * InfiniteReality/Reality Software, IRIX 6.5 release *
Oct  8 14:02:59 6A:onyx2 unix: IR0: GE0: Welcome to GELand!
Oct  8 14:02:59 6A:onyx2 unix: IR0: GE1: Welcome to GELand!
Oct  8 14:03:51 6B:onyx2 Xsession: root: login
Oct  8 14:07:41 6B:onyx2 runpriv[1394]: Running privilege dtshutdown for user root.
Oct  8 14:07:41 6B:onyx2 dtshutdown[1394]: /usr/sysadm/bin/runpriv dtshutdown -g 0 -i 0
Oct  8 14:07:44 7B:onyx2 syslog: {start,stop}midi entered
Oct  8 14:07:48 6B:onyx2 Xsession: root: logout
Oct  8 14:07:51 1A:onyx2 unix: ALERT: /hw/module/1/slot/io1/baseio/pci/7: RAD thread held off for more than 32 mS
Oct  8 14:07:52 1A:onyx2 unix: ALERT: /hw/module/1/slot/io1/baseio/pci/7: RAD thread held off for more than 32 mS
Oct  8 14:07:52 3A:onyx2 INFO: The system is shutting down.
Oct  8 14:07:52 3A:onyx2 INFO: Please wait.
Oct  8 14:08:14 0D:onyx2 inetd[236]: inetd received SIGTERM; terminating.
Oct  8 14:08:14 3B:onyx2 syslog: sdpd: FAMNextEvent error (Operation not permitted)
Oct  8 14:08:15 3F:onyx2 syslogd: going down on signal 15
Oct 16 13:45:59 6F:onyx2 syslogd: restart
Oct 16 13:45:59 6A:onyx2 unix: IRIX Release 6.5 IP27 Version 01101245 System V - 64 Bit
Oct 16 13:45:59 2A:onyx2 unix: Copyright 1987-2001 Silicon Graphics, Inc.
Oct 16 13:45:59 2A:onyx2 unix: All Rights Reserved.
Oct 16 13:45:59 6A:onyx2 unix: Setting rbaud to 19200
Oct 16 13:45:59 5A:onyx2 unix: NOTICE: Start mounting filesystem: /
Oct 16 13:45:59 5A:onyx2 unix: NOTICE: Starting XFS recovery on filesystem: / (dev: 0/149)
Oct 16 13:45:59 5A:onyx2 unix: NOTICE: Ending XFS recovery for filesystem: / (/hw/module/1/slot/io1/baseio/pci/0/scsi_ctlr/0/target/1/lun/0/disk/partition/0/block)
Oct 16 13:46:01 6D:onyx2 eventmond[119]: |$(0x200110)started - (normal mode)
Oct 16 13:46:10 3D:onyx2 mrouted[178]: can't forward: only one enabled vif
Oct 16 13:46:11 3D:onyx2 nsd[193]: NIS server for domain nicve.salford.ac.uk not responding.
Oct 16 13:46:13 6B:onyx2 syslog: opened /tmp/.mkpd_socket, fd=3
Oct 16 13:46:13 6D:onyx2 mkpd[348]: daemon started ...
Oct 16 13:46:14 6D:onyx2 sn0log: The following are messages stored in the flashlog from a previous system boot.
Oct 16 13:46:14 6D:onyx2 sn0log: End of flashlog messages.
Oct 16 13:46:16 3D:onyx2 inetd[236]: sgi-esphttp/tcp: unknown service
Oct 16 13:46:27 5D:onyx2 timed[387]: This machine is master
Oct 16 13:46:32 5B:onyx2 sendmail: Generating /etc/sendmail.cf from /etc/sendmail.mc
Oct 16 13:46:52 4D:onyx2 eventmond[119]: Warning: can't contact espdbd. The following message is normal at boot time - (normal mode)
Oct 16 13:46:52 3D:onyx2 eventmond[119]: |$(0x20011E)Can't init SSDB library "libssdb.so", current timeout is 30 sec. - (normal mode)
Oct 16 13:46:53 6C:onyx2 sendmail[462]: starting daemon (SGI-8.9.3): SMTP+queueing@00:15:00
Oct 16 13:46:58 3D:onyx2 /usr/freeware/sharity/sbin/sharityd[468]: [1] main: cannot create pid-file /usr/freeware/sharity/var/sharity.pid: [2] No such file or directory
Oct 16 13:48:53 6D:onyx2 sesdaemon[914]: starting
Oct 16 13:48:54 6D:onyx2 sesdaemon[914]: |$(0x153) No fibre channel controllers found
Oct 16 13:48:54 6D:onyx2 sesdaemon[914]: exiting
Oct 16 13:49:01 4A:onyx2 unix: |$(0x845)WARNING: IR0: XG Map RAM Parity error.
Oct 16 13:49:01 4A:onyx2 unix: |$(0x83f)WARNING: IR: Bad XG MAPRAM entry found during kona_mapram_init!
Oct 16 13:49:02 6A:onyx2 unix: IR0: ARM: Welcome to ARMLand - 0/0x0d00
Oct 16 13:49:02 6A:onyx2 unix: IR0: ARM: running...(sherwood-root 0012312203)
Oct 16 13:49:02 6A:onyx2 unix: IR0: ARM: ******************************************************
Oct 16 13:49:02 6A:onyx2 unix: IR0: ARM: * InfiniteReality/Reality Software, IRIX 6.5 release *
Oct 16 13:49:03 6A:onyx2 unix: IR0: GE0: Welcome to GELand!
Oct 16 13:49:03 6A:onyx2 unix: IR0: GE1: Welcome to GELand!
Oct 16 13:49:57 4A:onyx2 unix: |$(0x849)WARNING: IR0: mopup timeout.
Oct 16 13:49:57 4A:onyx2 unix: |$(0x842)WARNING: IR0:  Fatal error.  bdata = 0xa800000000746000 death_reason = 17
Oct 16 13:49:57 6A:onyx2 unix: Graphics FIFO depth is 0 words.
Oct 16 13:49:57 3B:onyx2 xdm[1135]: Server for display :0 terminated unexpectedly: 2560
Oct 16 13:49:57 4D:onyx2 gfxinit: Pipe 0 in bad state (0x11) ... starting postmortem
Oct 16 13:49:57 6B:onyx2 kpm[1238]: Initiating kpm dump
Oct 16 13:49:58 3B:onyx2 kpm[1238]: Kernel graphics information is corrupted
Oct 16 13:49:58 6B:onyx2 kpm[1238]: Proceeding assuming #GEs = 1, #RMs = 4
Oct 16 13:49:58 3B:onyx2 kpm[1238]: Cannot read JTAG files. Aborting
Oct 16 13:49:58 6B:onyx2 kpm[1238]: Finished kpm dump
Oct 16 13:50:05 4A:onyx2 unix: |$(0x83b)WARNING: IR0: XG ERR_STAT==0x1000 after reset.
Oct 16 13:50:05 4A:onyx2 unix: |$(0x83f)WARNING: IR: Bad XG MAPRAM entry found during kona_mapram_init!
Oct 16 13:50:05 4A:onyx2 unix: |$(0x845)WARNING: IR0: XG Map RAM Parity error.
Oct 16 13:50:05 6A:onyx2 unix: IR0: ARM: Welcome to ARMLand - 0/0x0d00
So the machine had been down for 8 days, but not moved. The next time I started it up, these errors started appearing. ;o(
I hope you get your machine sorted also, thanks for your help so far!
Unread postby jan-jaap » Sun Jul 23, 2017 11:54 pm
jebmayers wrote:Any ideas what might be wrong? I have tried searching for the MAPRAM error but have had limited success - from what I have found I am leaning towards a GE problem?
I think you're right. You can try to run the IR diagnostics for only the GE, RM or DG board to get more confidence, e.g. "irsaudit -ge".
Users browsing this forum: shutitalldown and 1 guest
