Indigo 2 Solid Impact HD problem
weGuru
Unread postby weGuru » Sat Jul 15, 2017 9:11 am
Hello.
Ive recently got my hands on an Indigo 2 solid impact. And I installed IRIX on it. On the desktop alot of disks show up even though i only have 1 disk in the machine.
When i do hinv it lists
SCSI Disk: scsi(0)disk(1)
SCSI Disk: scsi(0)disk(2)
SCSI Disk: scsi(0)disk(3)
SCSI Disk: scsi(0)disk(4)
SCSI Disk: scsi(0)disk(5)
SCSI Disk: scsi(0)disk(6)
SCSI Disk: scsi(0)disk(7)
Is there a way to delete all the other "disks" so it only shows up 1 disk?
:Indy: R4600 :Indy: R4600 :Indy: R5000 :Indigo2IMP: R10k :O2: R5000 :Octane: R10k :Indigo: R4400
Sun Ultra 10, Sun 220R, Sun 420R, Sun 670MP, Sun E250, Sun IPC, Sun Ultra 60, Sun Ultra Ent 2, Sparcserver 5, IBM R/S 6000 model 590, DEC Vaxstation 4000/90
Re: Indigo 2 Solid Impact HD problem
Unread postby Trippynet » Sat Jul 15, 2017 9:40 am
Sounds like either there's an issue with the internal terminator, or you might have somehow set the drive to the same ID as the controller or something like that. Make sure the SCSI ID connector on the drive sled is connected to the drive - this should set the ID automatically.
weGuru
Unread postby weGuru » Sat Jul 15, 2017 12:11 pm
The drive sled ID connector dont reach. But i moved the jumpers around and now hinv shows correctly.
Thanx for help
Unread postby Trippynet » Sat Jul 15, 2017 12:56 pm
Glad it's working, and enjoy the system! Do pop a hinv and some pics up if you can :)
weGuru
Unread postby weGuru » Sat Jul 15, 2017 1:05 pm
Will make a post of my sgi computers as soon as they all are ready and installed :)
Ok to post my SUN machines as well? :P
Unread postby Trippynet » Sun Jul 16, 2017 2:03 am
Well, there's a Sun folder, so I don't see why not :)
