300 MHz o2 startup issues. Ram?
Intuition
Unread postby Intuition » Tue Jul 04, 2017 4:28 pm
So I've been messing around with my o2 systems.
The older one is the r12k 300 MHz. I recently broke it out and started it up.
It began barking at me whilst on the desktop.
That's the message about dimms.
Now it doesn't want to boot to the desktop.
It starts. Gives me some orange light and then shows me a messsge with numbers/text.
I tried reseating the ram. But it still persists.
What I do know is that the hinv now says 256 instead of 384 like it used to. Is one of the ram sticks bad?
Image O2 - 300mhz
aka Casey Christopher
cris_adder
Re: 300 MHz o2 startup issues. Ram?
Unread postby cris_adder » Wed Jul 05, 2017 1:25 am
I have had a few O2 ram sticks behave strangely and found that sometimes they worked when switched around into different sockets (of couse keeping pairs in the same size). However, some just completely did not work.
Intuition
Unread postby Intuition » Mon Jul 10, 2017 7:00 pm
cris_adder wrote:I have had a few O2 ram sticks behave strangely and found that sometimes they worked when switched around into different sockets (of couse keeping pairs in the same size). However, some just completely did not work.
That worked, thanks !
I tried reseating it but swapping them around fixed whatever it was.
Was thinking I had to buy new ram. It's all up and working again.
Image O2 - 300mhz
gijoe77
Unread postby gijoe77 » Wed Jul 12, 2017 7:41 am
Did you really test the system after moving the RAM around? Like by trying to run a very memory intensive process? I ran into this sort of issue before - started playing musical chairs with the DIMMS only to get bit once I ran a highly memory intensive process
Intuition
Unread postby Intuition » Wed Jul 12, 2017 12:42 pm
Yes, I ran Maya and Softimage and did both animation and render tests. The machine ran all day with no DIMM warnings as before.
I think it is good for now.
Image O2 - 300mhz
Dalplex
Unread postby Dalplex » Wed Jul 12, 2017 3:16 pm
O2 need the larger size dimm in the bank A. In your case as combination of 256+128. 256 need in bank A.
