vfc on Indigo2 Impact
rooprob
Unread postby rooprob » Fri Jun 16, 2017 2:03 pm
Hi,
Has anyone successfully execute vfc on Impact (I know they have on Octane MGRAS).
Reason for asking, vfc throws a wobbler from the installed mgras.def, then drops core.
IRIS 94% ./modelines-mgras modelines.tmpl < modelines-v2.txt
1600x1000 FrontPorch H/V 104/1, BackPorch H/V 272/31 Sync H/V 168/3 FPS 60.000000
executing /usr/sbin/vfc -c chip=/usr/gfx/ucode/vfc/rules/mgras_vc3.def,board=/usr/gfx/ucode/vfc/rules/mgras.def -o i2mgrast_1600x1000_60___4.vfo i2mgrast_1600x1000_60___4.vfs
"/usr/gfx/ucode/vfc/rules/mgras.def", line 45 near ";" The variable RSSCOUNT is not defined
Explicitly declare this variable before use
"/usr/gfx/ucode/vfc/rules/mgras.def", line 46 near "==" The variable DB32 is not defined
[error 5]"/usr/gfx/ucode/vfc/rules/mgras.def", line 48 near "else": expecting: '!' '(' '{' '}' '~' "active" "assign" "bpt" "color" "dump" "error" "eye" "false" "for" "free" "high" "if" "info" "initial" "linetypelength" "low" "msec" "pixels" "print" "sec" "set" "signal" "statedurationtable" "transition" "true" "usec" "vertical" "warning" "within" NAME STRING_CONSTANT U_LONG DOUBLE
"/usr/gfx/ucode/vfc/rules/mgras.def", line 101 near "==" The variable INTERLACED is not defined
[error 46]"/usr/gfx/ucode/vfc/rules/mgras.def", line 103 near "else": expecting: '!' '(' '{' '}' '~' "active" "assign" "bpt" "color" "dump" "error" "eye" "false" "for" "free" "high" "if" "info" "initial" "linetypelength" "low" "msec" "pixels" "print" "sec" "set" "signal" "statedurationtable" "transition" "true" "usec" "vertical" "warning" "within" NAME STRING_CONSTANT U_LONG DOUBLE
"/usr/gfx/ucode/vfc/rules/mgras.def", line 111 near "==" The variable INTERLACED is not defined
"/usr/gfx/ucode/vfc/rules/mgras.def", line 122 near ";" The variable tHHalfALine is not defined
"/usr/gfx/ucode/vfc/rules/mgras.def", line 140 near "==" The variable INTERLACED is not defined
Assertion failed: 0, file PcodeItem.c++, line 143
The top part of my vfs, adapted from the stock 1280x1024
General
    FieldsPerFrame = 1;
    FramesPerSecond = 60.00;
    TotalLinesPerFrame = 1035;
    TotalPixelsPerLine = 2144;
    ActiveLinesPerFrame = 1000;
    ActivePixelsPerLine = 1600;
    FormatName = "i2mgrast_1600x1000_60___4";
Active Line {
    HorizontalFrontPorch = 104 pixels;
    HorizontalSync = 168 pixels;
    HorizontalBackPorch = 272 pixels;
Stock 6.5.22m
IRIS 106% versions vfc
I = Installed, R = Removed
   Name                 Date        Description
I  vfc                  01/07/2009  Video Format Compiler, 1.2
I  vfc.books            01/07/2009  Books
I  vfc.books.VFC_PG     01/07/2009  Programmer's Guide
I  vfc.man              01/07/2009  Man Pages
I  vfc.man.manpages     01/07/2009  Man Pages
I  vfc.man.relnotes     01/07/2009  Release Notes
I  vfc.sw               01/07/2009  Software
I  vfc.sw.base          01/07/2009  Base Software
I  vfc.sw.vfs           01/07/2009  Sample Video Format Source
IRIS 107% uname -aR
IRIX64 IRIS 6.5 6.5.22m 10070055 IP28
IRIS 17% ls -al ucode/vfc/rules/
total 360
drwxr-xr-x    2 root     sys         4096 Jan  7  2009 .
drwxr-xr-x    4 root     sys           42 Jan  8  2009 ..
-rw-r--r--    1 root     sys         5345 Jan  7  2009 O2_Board.def
-rw-r--r--    1 root     sys          653 Jan  7  2009 O2_Chip.def
-rw-r--r--    1 root     sys         4692 Jan  7  2009 VPro_BlockSync.def
-rw-r--r--    1 root     sys        53633 Jan  7  2009 VPro_Board.def
-rw-r--r--    1 root     sys          189 Jan  7  2009 VPro_Chip.def
-rw-r--r--    1 root     sys         4352 Jan  7  2009 VPro_DCD.def
-r--r--r--    1 root     sys        10708 Jan  7  2009 dg4.def
-r--r--r--    1 root     sys        12208 Jan  7  2009 dg4_ddo_gvo.def
-r--r--r--    1 root     sys        10663 Jan  7  2009 dplex.def
-r--r--r--    1 root     sys        34059 Jan  7  2009 mgras.def
-r--r--r--    1 root     sys          196 Jan  7  2009 mgras_vc3.def
-r--r--r--    1 root     sys         2566 Jan  7  2009 sampleboard.def
-r--r--r--    1 root     sys          653 Jan  7  2009 samplechip.def
-r--r--r--    1 root     sys         1980 Jan  7  2009 voc1.def
New Zealand
Users browsing this forum: Google [Bot], voidfoo and 1 guest
