Indigo power-on issues, possible dead drive
Unread postby Daniel80486 » Sun Jun 11, 2017 7:26 pm
After my power supply repair (, my Indigo starting giving the TOD error. I did a CR2032 conversion, but seem to have additional issues.
I get a dead screen about 50% of the time but I think I just need to pull everything and thoroughly clean all the contacts.
I've had the hard drive removed to spare it from all the power cycling from my PSU testing. When the system doesn't hang with a dead screen, it runs diagnostics and correctly detects SCSI failure, as expected for a missing drive, so that seems encouraging:
However, with the drive installed, the drive makes a clunk 3 or 4 times, and the diagnostic shows Drive Not Ready: ASC=0x4c
I'm almost certain this is a drive failure, but if there's anything I can check, I'm open to suggestions. :(
:Indigo: :Cube:
Re: Indigo power-on issues, possible dead drive
Unread postby robespierre » Sun Jun 11, 2017 9:06 pm
dks0d1s0: Drive not ready: ASC=0x4c,.
ASC 4C/00 is defined as LOGICAL UNIT FAILED SELF-CONFIGURATION, also called "Diagnostic Failure - config not loaded".
It appears that the drive is malfunctioning.
