Two Identical Octanes? Or are they? (Boot problem)
Unread postby uunix » Sun Jun 11, 2017 2:32 pm
As I started writing this, as with many issues, you suddenly get a brainstorm.. and that didn't work.
So I have two very similar Octane 2's Machine 1 and Machine 2
Both 2 x 600 Mhz CPU
Machine 1 has a tad under 4GB Ram, Machine 2 has a Tad Over 1 GB
Both have V12 with DCD
Machine 1 has DM3 with 2 x FC & PCi shoe box... GB Lan... the other doesn't.
Both 1.4 XBow..
So, should I be able to take the root drive from one, place it in the other and boot? So long as the boot up env is correct yes?
On boot I get -
Unable to execute xio(0)pci(15)scsi(0)disk(1)rdsk(0)partition(0): execute form error
Now the xio(0)pci(15)scsi(0)disk(1)..blah.. I thought was strange because the donor machine had scsi(0)disk(1)... blah
So I changed Machine 2 to match. Still wouldn't load, yet leaving these setting and putting the original disk in, it booted fine.
Both run 6.5.30 normally, so any prom updates would have been done if such a thing exists, the second machine just won't boot from this disk.
The disk partition looks fine and must be, because it boots up fine in Machine 1.
What gives?
Re: Two Identical Octanes? Or are they? (Boot problem)
Unread postby robespierre » Sun Jun 11, 2017 2:45 pm
looks like missing boot file argument/ OSLoadFilename. Is the default kernel name set in the disklabel? (fx label/show/bootinfo)
Unread postby uunix » Sun Jun 11, 2017 3:06 pm
Holly Cow.. :D Nice spot chap..
fx/label/show> b
----- bootinfo-----
 root partition = 0     swap partition = 1    bootfile =
----- please choose one (? for help, .. to quit this menu)-----
[para]meters       [part]itions       [b]ootinfo         [a]ll
[g]eometry         [s]giinfo          [d]irectory
fx/label/show>
But.. how did it boot on Machine 1 I ask? and how do I add one without destroying the universe?
[Edit] Nice one robespierre , I have changed the bootinfo. and we are away.. :D
Unread postby robespierre » Sun Jun 11, 2017 4:08 pm
One machine has the filename set as a NVRAM variable and the other one doesn't
Users browsing this forum: Jack Luminous and 1 guest
