Sun sparcstatuin 5 CD-ROM bootable for Indigo r4000 ?
Dalplex
Unread postby Dalplex » Sun Jun 11, 2017 11:44 am
Hi,
The indigo boot up to the login screen and I have no way to proceed. All guest account that I know is not available.
I am thinking about connecting the CD-ROM from Sun sparc station 5 externally to indigo but not sure the combination will be bootable?
Thanks for your advise
Re: Sun sparcstatuin 5 CD-ROM bootable for Indigo r4000 ?
Unread postby robespierre » Sun Jun 11, 2017 11:50 am
It should work fine. Do you have the required cabling (CN50 to IDC50 and a terminator)?
Dalplex
Unread postby Dalplex » Sun Jun 11, 2017 4:16 pm
The active terminator is available from the Indigo. But I do not have any cables that can connect the CD-ROM 50 pin receptacle to the external SCSI receptacle.
I am still trying to figure out whether it was possible use Sun sparc original internal SCSI cable, which I thought might be feasible on O2 with sca but not for Indigo case.
Unread postby robespierre » Sun Jun 11, 2017 6:03 pm
SCA is the 80-pin connector with data and power together. I don't believe any CD/DVD drive has that connector.
The Sun Aurora chassis has a SCA backplane for hard disks, but the CD connector is a 50-pin IDC type. The cable is a special type for the Aurora, something like HD50M --- IDC50F --- HD50M to go over to the SCA backplane. It wouldn't work at all in the O2, the types of connectors are different.
To connect a CDROM drive to the external SCSI port on an Indigo, you can either use a disk enclosure (which has a power supply and the requisite data cabling), or hack something together with a suitable cable and a spare ATX power supply.
Dalplex
Unread postby Dalplex » Tue Jun 13, 2017 7:55 pm
Bought a Toshiba TXM5701s without power supply.
Dalplex
Unread postby Dalplex » Wed Jun 14, 2017 2:35 pm
Had never seen this kind of receptacle before.
Dalplex
Unread postby Dalplex » Thu Jun 15, 2017 3:48 am
Believe this is the same mini din as 3D view.
Unread postby robespierre » Thu Jun 15, 2017 7:16 pm
It is some proprietary configuration of DC power connector. It could be +5V, +12V, Gnd, if the drive uses both +12V and +5V rails, which I don't know offhand. Or it could be some other voltage or pair of voltages if there is an internal power converter. But Mini-DIN connectors are not rated to 120VAC and the device wouldn't pass approvals if it was 120V.
Dalplex
Unread postby Dalplex » Thu Jun 15, 2017 7:42 pm
Internally directly connect to molex connector on the CD-ROM.
Unread postby robespierre » Thu Jun 15, 2017 10:17 pm
That makes it easier. If they've used standard colors, the yellow is +12V, the red is +5V, and the black is Gnd return.
That looks like standard Mini-DIN-3.
Unread postby josehill » Fri Jun 16, 2017 4:28 am
Dalplex wrote:Had never seen this kind of receptacle before.
This type of power connector was very common back then, especially on SCSI peripherals that used external power bricks.
Dalplex
Unread postby Dalplex » Fri Jun 16, 2017 4:39 am
I believe this was true.
I have to admit this is the first time for me seeing 3 pins mini din.
Indigo does use it on the 3D google receptacle at the back of display card.
Dodoid
Unread postby Dodoid » Sat Jun 24, 2017 9:29 am
I think I have one of those 3 pin things for a USB DVD drive I have. Totally unrelated to SCSI or SGI, but, it's the same connector (though not guaranteed to be the same electrically).
and a small army of Image
Dalplex
Unread postby Dalplex » Sat Jun 24, 2017 11:29 pm
I ordered a few from Xbay and plan to retrofit an Atx molex connector to it.
Too bad, almost everything I have does not work directly by themselves.
