Lyon-Lamb IVAS installation problems
JKG2
Unread postby JKG2 » Wed May 24, 2017 7:26 pm
Hi everyone, long-time lurker, first time poster here.
I have a long love/hate affair with SGI going back many decades, and besides my O2, my most precious machine is my r4400 Indigo with Elan graphics. I recently picked up a NOS Lyon lamb IVAS video card for this machine, and everything has been going swimmingly except for one major problem with the installation.
According to the installation manual, after installation the software will modify the kernel to create a newer architecture compatible with the card. This appears to be a post command that is run after the installation from a script found in the tmp folder. Problem is, it is trying to grep in a variable called "system" but nothing is found with that name. I've tried running the script again just as an executable from the shell but I get the same response. When the machine reboots it shows that it could not run the script because of some similar problem. I am by no means an expert in this kind of stuff, but I am guessing maybe it's because something changed from 5.3, the IRIX version for which I think this IVAS software was intended, to 6.5 which I am running now.
Does anybody know what it is looking for when it requests "system"?
Is it something I can change in the script and just rerun it and have it then do the architecture fix on the next reboot?
The manual is unfortunately rather vague with any details about what exact architecture changes happen after the reboot. (I have never seen this dialogue that it speaks of asking if it's ok to do the actual architecture modification.)
I'm including screencaps of my Hinv, all the error messages, the actual script that's trying to call the system variable, the manual, and anything else I thought might be useful. I really appreciate all your help, I realize that knowledgeable SGI folks are a rapidly dying breed so hopefully I can get this fixed sooner rather than later :-)
Re: Lyon-Lamb IVAS installation problems
Unread postby robespierre » Wed May 24, 2017 9:31 pm
I can see there was one previous post about this system, although the poster didn't actually have one: viewtopic.php?t=16727826
I wish I had more information about the IVAS, it looks very interesting. About your error message "Cannot open system":
The script is trying to access the file /usr/sysgen/system (it is not a variable). This file existed in that location in an earlier version of Irix (4 or 5, I don't remember). In Irix 6.5, it does not exist and so you get the error. The equivalent file is /var/sysgen/system/irix.sm, but I can't say for certain that the lines the script is trying to add will work.
The second error, from S84ivas (an rc script) is that the program /usr/etc/ivas/ivasdl could not be executed. It could be a permissions problem (the wrong owner or missing +x perm) or an incompatible executable. Irix 5.3 was able to use COFF binaries, but Irix 6.5 cannot. If you run "file /usr/etc/ivas/ivasdl" it will tell you if it is COFF or ELF.
JKG2
Unread postby JKG2 » Wed May 24, 2017 11:05 pm
Thanks so much! Seems like its on the right track, but new questions arise (of course)
So I changed the script up to match the new directory structure, and lo and behold, after reboot it did indeed try to change the system architecture, but it ran into a problem, trying to locate a "master file" (?) called "ivas" in /var/sysgen/master.d/
So I looked in /usr/sysgen/ and found the two files (ivas in master.d and ivas.o in boot)the installer had put in the old (wrong place) and copied them to master.d and boot dirs in /var/sysgen. After rebooting I got a new message with the COFF errors you mentioned.
Right under there it said reboot to use reconfigured kernel, so i did, this time a clean login:
but trying to run ivasterm or producer only gives the architecture error still.
So unless you have any insights, I think i've run up against a wall here, which won't be solvable unless I go back to 5.3 because of the COFF issue.
What do you think?
Unread postby robespierre » Thu May 25, 2017 7:14 am
I think going back to Irix 5.3 is your best option. It is conceivably possible to convert a COFF binary to ELF, (there is a program called cof2elf), but it is not for the fainthearted (besides a different container format, there are memory layout changes and you basically have to disassemble and patch all of the code)
JKG2
Unread postby JKG2 » Fri May 26, 2017 8:15 pm
Ok, thanks for all your help! Im gonna try a last-ditch effort to contact John Lamb and see if they ever updated it for 6.5 before I throw in the towel.
Hakimoto
Unread postby Hakimoto » Fri Jun 02, 2017 2:46 am
@JKG2: I split the topic for you and moved your last post to the "Hardware for Sale/Trade" subforum. Maybe you want to head over there and edit your post a bit, if you feel the need to add some information!
grace, elegance and style.
Users browsing this forum: bjornl and 1 guest
