Indigo 2 panic with ethernet
Toxiccameron
Unread postby Toxiccameron » Fri May 05, 2017 6:59 pm
So I'm trying to use the Ethernet port on my indigo 2 for network installation but whenever it tries to use Ethernet with a cable plugged in, the system crashes with the bad address 0x8. Removing the hard drive and CD Rom didn't change anything but when I unplug the Ethernet, it only complains about there not being Ethernet plugged in with no crash. Do i have to use a special kind of Ethernet? Right now I'm using a laptop to share Ethernet to the computer with a standard cat5e cable.
:Indigo2IMP:
Re: Indigo 2 panic with ethernet
Unread postby Raion-Fox » Fri May 05, 2017 7:20 pm
You need a crossover cable to 'share' Ethernet. But as for the routing you'll need to ask someone else here.
Unread postby josehill » Fri May 05, 2017 7:36 pm
I have an old post that runs through setting up an O2 to connect through a Windows 7 PC. Perhaps that will help.
viewtopic.php?f=10&t=16726535&p=7349828#p7349828
Toxiccameron
Unread postby Toxiccameron » Fri May 05, 2017 9:43 pm
josehill wrote:I have an old post that runs through setting up an O2 to connect through a Windows 7 PC. Perhaps that will help.
The problem there though is that I can't even install irix. I've had no luck burning cds and the Ethernet crashes the computer when I try to use it for network installation. I'm not sure if I would be able to connect it to my modem as the room it's in doesn't have any ethernet.
:Indigo2IMP:
Unread postby josehill » Fri May 05, 2017 9:56 pm
Sorry about that! I read a little too quickly!
Have you reset the PROM environment on the Indigo 2 as described in http://shiftleft.com/mirrors/dina.harrydebug.com/ ?
Toxiccameron
Unread postby Toxiccameron » Fri May 05, 2017 11:12 pm
josehill wrote:Sorry about that! I read a little too quickly!
Yep. Double checked. I have attached the error it puts out when it gets Ethernet info.
:Indigo2IMP:
Unread postby Raion-Fox » Sat May 06, 2017 8:26 am
Hey Cameron if you have a Best Buy or Microcenter or can order off Amazon get a set of powerline adapters, that way you can tunnel Ethernet over your homes mains wiring and avoid the issue of the Indigo panicking.
Toxiccameron
Unread postby Toxiccameron » Sat May 06, 2017 10:23 am
Raion-Fox wrote:Hey Cameron if you have a Best Buy or Microcenter or can order off Amazon get a set of powerline adapters, that way you can tunnel Ethernet over your homes mains wiring and avoid the issue of the Indigo panicking.
I tried that too and had the same issue. I think my motherboard might be bad..
:Indigo2IMP:
Unread postby Raion-Fox » Sat May 06, 2017 10:37 am
Don't despair you can always pick up an aui transceiver and try that. Failing that, check with Krokodil as he was selling a motherboard
Unread postby josehill » Sat May 06, 2017 3:49 pm
Have you tried a different cable, especially a crossover cable?
Krokodil
Unread postby Krokodil » Sat May 06, 2017 9:24 pm
Raion-Fox wrote:Don't despair you can always pick up an aui transceiver and try that. Failing that, check with Krokodil as he was selling a motherboard
Yup. $50.00 USD for an Indigo2 IMPACT mainboard with R4400 250MHZ processor! It will be going on Ebay soon otherwise, because it's sitting around taking up space and I would like to move it on.
Disclaimer: Before anyone decides to send me a PM about how that's not an R4400... I am well aware of that. Couldn't find a suitable picture of an R4400 and board in a pinch. Thanks for your understanding.
Alphaserver DS10 - 466MHZ
Sun Ultra 5 - 440MHZ.
Toxiccameron
Unread postby Toxiccameron » Sun May 07, 2017 9:43 am
Hmm. I have a r10000 on the motherboard I have. Can I move it to the other one?
:Indigo2IMP:
Krokodil
Unread postby Krokodil » Mon May 08, 2017 11:33 am
Toxiccameron wrote:Hmm. I have a r10000 on the motherboard I have. Can I move it to the other one?
Ah. No. You have to upgrade the board to upgrade the CPU. :x
Toxiccameron
Unread postby Toxiccameron » Mon May 08, 2017 1:46 pm
Damn. I saw an r10000 board on eBay that is identical to the one I have but I'll wait for the transceiver before I go spend more money on this computer.
:Indigo2IMP:
japes
Unread postby japes » Tue May 09, 2017 1:35 am
I upgraded my R4400 Impact (Ready) to R10000 with an ebay motherboard several months ago. Added a Solid Impact board from ebay too so it's actually Impact - kind of wish I had a 10000 badge but oh well...
Your problem sounds like a bad network interface sadly and probably won't change much with an AUI transceiver. Hope I'm wrong, but it should have worked - 1gig port on your laptop would be auto mdi-x so no crossover cable should be required. You could try changing your ram around and reseating the CPU just to be sure it wasn't a hardware problem in those areas. Or maybe you do have a cable problem and the PROM code is bad at handling it, for that I would try some simple switch and a known good cable - though it sounds like you've probably been down that road already.
