3D Print Octane front door?
Unread postby Raion-Fox » Thu May 04, 2017 9:04 pm
So I'm bidding on an Octane2 without a front door. I thought about how the doors/hinge are pretty fragile and wanted to see if anyone is willing try 3d printing the door. I asked my machine shop about CNC but because of its shape it would cost a fortune to CNC mill even a small run. As I'm not versed in 3D printing, I don't know if the plastics produced will be too brittle. I'd probably end up sanding and painting it, tbh.
Dodoid
Re: 3D Print Octane front door?
Unread postby Dodoid » Fri May 05, 2017 5:33 am
PLA is brittle, but it's strong enough that that shouldn't matter. You need a 3D model of the door obviously.
and a small army of Image
Y888099
Unread postby Y888099 » Fri May 05, 2017 5:51 pm
PLA-door sounds ok for me.
Dodoid wrote:3D model of the door
can you design it?
kubatyszko
Unread postby kubatyszko » Sun May 07, 2017 6:44 pm
Dodoid wrote:PLA is brittle.
Might be much stronger than most SGI plastics these days...
Dodoid
Unread postby Dodoid » Sun May 07, 2017 9:36 pm
Quite possibly stronger, you're right. I don't know how well I would be able to replicate something like the Octane door, I have essentially no experience with organic shapes (as opposed to say, a more geometric but still complicated Indigo door). I could look to see if I could find an Octane model elsewhere and then essentially cut out the door. Will have to see.
japes
Unread postby japes » Sun May 07, 2017 10:53 pm
viewtopic.php?f=10&t=16728572&p=7389043&hilit=octane+3d+model#p7389043
Says the shuttle demo includes a model of the Octane.
Unread postby vishnu » Tue May 09, 2017 10:56 am
japes wrote:http://forums.nekochan.net/viewtopic.php?f=10&t=16728572&p=7389043&hilit=octane+3d+model#p7389043
Actually, that's video of an Inventor demo that was created from Pro/E models of the individual parts, no way to extract the models from that. Interesting that they actually modeled the chips on the mainboard.
kubatyszko
Unread postby kubatyszko » Tue May 09, 2017 6:04 pm
Dodoid wrote:...replicate something like the Octane door, I have essentially no experience with organic shapes (as opposed to say, a more geometric but still complicated Indigo door)
Whoever has 3D scanner - please step forward.
Unread postby vishnu » Tue May 09, 2017 9:22 pm
The door wouldn't be that hard to model; with a caliper and Pro/E I think you could get pretty dang close in about an hour. Of course, you'd actually have to have a door in order to do that. And Pro/E. Wait a minute, I've got both! Hmmmm.... 8-)
Dodoid
Unread postby Dodoid » Wed May 10, 2017 5:12 am
Yeah, I have a door and caliper, and could provably find Pro/E, but I'm just not really experienced enough (especially not in Pro/E, which I've never used). I mainly use SketchUp, which is great for some jobs and horrible for others.
japes
Unread postby japes » Wed May 10, 2017 4:42 pm
Can't do anything with an Open Inventor 2.0 file then?
caseFront.iv.gz
(438.61 KiB) Downloaded 15 times
Does seem to be one piece, but maybe if it can be imported into something it can be sliced up?
Unread postby vishnu » Thu May 11, 2017 10:54 am
caseFront.iv.gz
Wow, nice! :mrgreen: Wherever did you obtain that? :shock:
Kotomo
Unread postby Kotomo » Tue May 16, 2017 12:49 pm
Managed to get this converted to an .stl a bit more useful for 3D printing. Managed to do this with someone's old c++ code here: http://people.sc.fsu.edu/~jburkardt/cpp ... ivcon.html
However, this appears to just be the SGI logo =/ Maybe japes can clarify on that.
This is what I got when importing the converted .stl into TinkerCAD
Still, could be fun to 3D print, and we have a MakerBot at work, so I'm going to print this for the heck of it. Here's the STL file if anyone else is interested.
caseFront.stl.gz
(212.72 KiB) Downloaded 9 times
:Octane: :Octane: :Octane: :Octane: :Octane2: :Octane2: :Fuel: :O2: :O2: :O2: :O2000: :O2000:
Dodoid
Unread postby Dodoid » Tue May 16, 2017 1:40 pm
I printed the Logo and use it in my videos. This model is also available on Thingiverse, probably converted from the same place.
Kotomo
Unread postby Kotomo » Wed May 17, 2017 9:29 am
Dodoid wrote:I printed the Logo and use it in my videos. This model is also available on Thingiverse, probably converted from the same place.
True, but I haven't seen any with the actual lettering up on Thingiverse. Not that it really matters.
I tried printing this, but I'm not sure makerware could make sense of the SGI cube. I got a few cylinder posts sticking up on the build platform. The lettering came out nice, but that's not much to write home about.
