Indy memory problem - runs with 4x32, but not with 8x32
halfmanhalftaco
Unread postby halfmanhalftaco » Fri Apr 28, 2017 8:38 am
I have an Indy with an R4600SC cpu and the XL24 graphics board that I'm trying to max out the RAM on. It came to me with 8x 8MB SIMMS, so I went out and picked up a set of 8 32MB 60ns FPM/parity SIMMs.
When all 8 32MB SIMMs are installed, it chimes like normal, I can get into the PROM monitor, etc, but it never gets past the "The system is coming up" screen. Since my understanding is that RAM has to be installed in banks of 4, I pulled the top bank of 4 out and it boots without a hitch. Swapping in SIMMs from the set I removed into the lower bank also boots successfully every time.
Anyone know what's going on? It doesn't seem to be bad RAM because any of them work fine when in the lower bank. And I know all the SIMM slots do work because it originally had 8x8MB in it.
:Indy: :Indigo2: :Octane: :Octane: :Octane:
Indy XL24 R4600SC 133MHz | Indigo2 Extreme R4400 250MHz | Octane MXI 2xR12000 300MHz
2x Octane SE 2xR10000 195MHz
SPARCstation 20 SX 2x125MHz HyperSPARC | SPARCstation 20 TurboGX+ 2x60MHz SuperSPARC-II
SPARCstation IPC GX 25MHz SPARC | SPARCstation IPX GX 40MHz SPARC | SPARCclassic TurboGX 50MHz microSPARC
SPARCclassic X cg3 50MHz microSPARC | Sun Blade 100 Expert3D-Lite 500MHz UltraSPARC IIe
JavaStation-1 (Mr. Coffee) 110MHz microSPARC-IIe
https://halfmanhalftaco.com/inventory/
Re: Indy memory problem - runs with 4x32, but not with 8x32
Unread postby robespierre » Fri Apr 28, 2017 9:54 am
My suspicion is that you do not have a large enough swap partition if your kernel is configured to use hard swap space.
halfmanhalftaco
Unread postby halfmanhalftaco » Fri Apr 28, 2017 10:29 am
I have a 512MB swap partition.
Another data point, it also fails to boot with 4x32MB in the lower bank (the bank closest to the power supply), and 4x8MB in the upper bank.
cris_adder
Unread postby cris_adder » Fri Apr 28, 2017 3:50 pm
One or more of the ram chips could be faulty, you may have to mix and match (also with the 8Mb Chips)...
Unread postby robespierre » Fri Apr 28, 2017 4:22 pm
That's a good point. You can run the hardware confidence test by typing "boot stand/ide" at the PROM console prompt.
halfmanhalftaco
Unread postby halfmanhalftaco » Fri Apr 28, 2017 6:22 pm
robespierre wrote:That's a good point. You can run the hardware confidence test by typing "boot stand/ide" at the PROM console prompt.
I'm running the 'memtest' command in ide as we speak. Should I also run the 'dram'/'ldram' or any other tests?
halfmanhalftaco
Unread postby halfmanhalftaco » Fri Apr 28, 2017 11:32 pm
Ran memtest, dram and ldram and they all passed. I let it run the normal bank of tests including the graphics tests and those all passed as well.
I can also boot into fx just fine, but booting into IRIX installers fails - kernel panics each time. I tried IRIX 5.3, 6.2 and 6.5.22. The miniroot copies then it either kernel panics when it boots the install before getting to the Inst> prompt (6.2 and 6.5.22), or panics when turning the network on when selecting a software source with 'from' (5.3).
I'll have to see if they throw the same panic each time, but the 6.5.22 installer gave a PANIC: VEC_syscall, 6.2 did PANIC: kernel used coprocessor, and 5.3 did PANIC: kernel fault.
Starting to think I'm stuck with 128MB on this thing.
