Galileo Indy Video
Galileo Indy Video
Unread postby uunix » Fri Apr 21, 2017 6:02 am
This arrived today, (along with a cpu) which I fitted, installed drivers and gets picked up fine and works fine so far. Just need to read up on what the ports do.
Indy Video (ev1): unit 0, revision 0
Re: Galileo Indy Video
Unread postby dexter1 » Fri Apr 21, 2017 6:21 am
An ev1, very nice.
BTW, is that a 68-pin disk inside your indy? You could do with some more flat-cable management :)
And congratulations on the 200MHz R4400 CPU, you don't see those every day.
Unread postby uunix » Fri Apr 21, 2017 7:42 am
dexter1 wrote:An ev1, very nice.
:) To complete my cable management, I normally just put the cover back on.
Of all my Indy's, this is my favourite.
As a side note, the CPU I purchased with the ev1 is a 180MHz R5000SC - 030-0985-002
