SGI PCI card 4 Port USB Card 9210286 on my ONYX4
jmjsgi
Unread postby jmjsgi » Wed Apr 19, 2017 8:22 pm
Hello everyone
I have installed a SGI PCI card 4 Port USB Card 9210286 on my ONYX4 and when i connect my SGI USB keyboard. It does not work.
My IRIX system is 6.5.30m.
Can anyone help me?
:O2+: :1600SW: SGI O2+ R12000 400 768mo and 36gb
:O2: :1600SW: :O2: O2 R5000 180 320 2x18gb
:Indy: Indy R5000 180mhz
:Indigo2IMP: Indigo2maximum impact R10000 195
:O3x0: ONIX4 4x800 8gb V12 150gb
:Tezro: TEZRO 4x1ghz
Re: SGI PCI card 4 Port USB Card 9210286 on my ONYX4
Unread postby recondas » Fri Apr 21, 2017 3:49 pm
jmjsgi wrote:Can anyone help me?
Your USB card might be bad, but a more likely suspect would be how IRIX handles the connection of previously unused I/O devices. When you change from a PS/2 to USB keyboard/mouse, ioconfig adds the new USB kb&m to its configuration list but leaves the PS/2 kb&m active. IRIX expects the sysadmin will examine ioconfig.conf and reorder/reinstate the list as necessary. If you're not running mission critical big iron, the quick and dirty fix is to delete ioconfig.conf and reboot.
If you haven't already done so, you might try deleting or renaming /etc/ioconfig.conf, then reboot the system with the USB kb&m attached. IRIX will regenerate ioconfig with active entries for your USB kb&m (run man ioconfig at a command prompt for some additional detail).
I prefer to save the existing copy of ioconfig, and usually rename to ioconfig.conf.O. That's a capital O (as in Old), which would make the saved copy appear if you ran the versions changed command).
