Indigo2 IMPACT 10K Soft Power Problem
archaic
Unread postby archaic » Wed Mar 22, 2017 7:55 pm
I have an Indigo2 IMPACT 10000 that has a strange soft power problem. The machine works perfectly except that after it is powered down it will not come back on until the power cord is unplugged for about 20 seconds. I have changed the power supply with a brand new one, and it made no difference. I was wondering if anybody had any ideas. It's not a huge deal, but I am curious as to why.
It has a dead battery in the Dallas chip, would that make a difference?
Patrick
Patrick
- You have got to be kidding... -
Re: Indigo2 IMPACT 10K Soft Power Problem
Unread postby Trippynet » Thu Mar 23, 2017 1:46 am
For what it's worth, I have the exact same issue with mine. I also changed PSU and it did not help. Dallas battery in mine is fine and my system has no other faults I'm aware of.
Not sure what is causing it, but as the Indigo2 PSU gobbles nearly 20w of power when off, mine is always switched off physically at the wall when not in use, hence it's not been a problem for me. However, you're not alone with this issue and I've not been able to figure out what causes it either.
archaic
Unread postby archaic » Thu Mar 30, 2017 6:39 pm
Trippynet wrote:For what it's worth, I have the exact same issue with mine. I also changed PSU and it did not help. Dallas battery in mine is fine and my system has no other faults I'm aware of.
Thanks. It is good to know that I am not the only one with this issue.
Patrick
Patrick
Unread postby jan-jaap » Thu Mar 30, 2017 11:58 pm
archaic wrote:Thanks. It is good to know that I am not the only one with this issue.
I think (not 100% sure) that this is the thing that goes away of you replace 4 small elcos in the PSU. The procedure is on Ian Mapleson's site.
Users browsing this forum: johnnym and 3 guests
