FUEL Psu Fixed...
jammaster
FUEL Psu Fixed...
Unread postby jammaster » Wed Mar 01, 2017 11:52 am
I have fixed a Fuel PSU today if it can help someone.
The culprits were 3 Capacitors on the pusle daughter board.
This little daughter board is mounted on the main power PCB (At the bottom of the PSU connected to the powerline).
All the capas of power board:
4C4 33uf 35V
4C3 10uf 50V
4C5 1000uf 10V
1C19 680uf 10V
1C21 2.2uf 50V
1C20 10uf 50V
2C1 47uf 25V
2C2 4.7uf 25V
1C17 22uf 50V
5C1 47uf 25V
Dead ones were 4C3 4C4 4C5 and 1C19 was not healthy !
You need to desolder this daughter board before doing anything...
You can test your PSU whitout a Load/Workstation by grounding green wire/pin of the WTX connector.
.......... :Onyx2: ............................... :Indigo2IMP: ..................................... :Indigo2: ........................... :Indigo: .............
IR2E 6GB 4x400Mhz .... MAXImp/4MB 512MB 195Mhz .... Extreme 384MB 250Mhz....Elan 64MB R3K ....
............. :Indy: ................................. :Octane2: .................
XS24 256MB 150 Mhz R5K .... V12 2GB 2x600Mhz ....
Intergraph TDZ2000 GL2 4110GT 1GB 2x600Mhz ... HP Visualize X-Class FX10 4GB 2x1000Mhz ... IBM 5160 V20, 8087 30Mb ... IBM 5162 10Mhz, 287XL, 6Mb, ST-4096 ... APPLE PowerMAC 9600/300 ... APPLE Quadra 840AV ... APPLE PowerMAC G5 Quad ... DEC AlphaStation 255/300 PS40 ... DEC AlphaStation 500/333 PS51 ... IBM RS/6000 PowerStation 7012-320 + GT3i ... SUN SparcStation 20 256MB AG10-E 2xSM81 ... SUN Ultra 80 4x450Mhz ... Amiga 2000HD, ECS 2MB ... Intergraph InterPro 225 ... DEC AlphaServer 4100 4x533Mhz 2MB ... SUN V880 ... DEC Multia 233Mhz
Elf
Re: FUEL Psu Fixed...
Unread postby Elf » Wed Mar 01, 2017 12:43 pm
Good job! :) Nice to see people fixing these.
Electrolytic capacitors do seem to be the culprit for most age related electronics failures.
For trying to lower the risk of fixing PSUs and testing them afterwards, "electronic loads" are a good tool, although somewhat expensive. See: http://www.tequipment.net/power-supplie ... nic-loads/
They can be programmed for constant current, constant power, and the more advanced ones can follow load patterns that you can program for duty cycle testing. Most of them will have various protections built in to make them harder to zap, for example if one of the switching MOSFETs fails and starts conducting through some hundreds of volts (in some designs).
Unread postby jan-jaap » Wed Mar 01, 2017 12:49 pm
Well done!
Was that the NMB or the HiPro power supply?
jammaster
Unread postby jammaster » Wed Mar 01, 2017 1:23 pm
It's the NMB...
Always these TEAPO crap capa... The green serie is awfull (mounted on some Apples Emac/G4 etc ... )
jammaster
Unread postby jammaster » Wed Mar 01, 2017 1:30 pm
Elf wrote:Good job! :) Nice to see people fixing these.
When it's a more rare PSU, I use and alternostat/variable PSU for pushing up gently the primary voltage.
I was talking about green wire just for starting up the PSU. This one doesn't need a load (HD/mobo) for powering up.
In add, i use my tiny tektronix scope just to see the ripple/noise of the main output rails (5V 12V 3.3V)
