SGI PROM binaries? ... Solved
jammaster
Re: SGI PROM binaries? ... Solved
Unread postby jammaster » Mon Feb 20, 2017 7:34 am
Solved (!!!)...
The V11 is NO COMPATIBLE with all Impact boards.
Mines seem to be coming from R10K system (?).
The last V12 (good dump) improve compatibility.
Life is complicated!
I have used better eproms (10ns vs 12ns)...
.......... :Onyx2: ............................... :Indigo2IMP: ..................................... :Indigo2: ........................... :Indigo: .............
IR2E 6GB 4x400Mhz .... MAXImp/4MB 512MB 195Mhz .... Extreme 384MB 250Mhz....Elan 64MB R3K ....
............. :Indy: ................................. :Octane2: .................
XS24 256MB 150 Mhz R5K .... V12 2GB 2x600Mhz ....
Intergraph TDZ2000 GL2 4110GT 1GB 2x600Mhz ... HP Visualize X-Class FX10 4GB 2x1000Mhz ... IBM 5160 V20, 8087 30Mb ... IBM 5162 10Mhz, 287XL, 6Mb, ST-4096 ... APPLE PowerMAC 9600/300 ... APPLE Quadra 840AV ... APPLE PowerMAC G5 Quad ... DEC AlphaStation 255/300 PS40 ... DEC AlphaStation 500/333 PS51 ... IBM RS/6000 PowerStation 7012-320 + GT3i ... SUN SparcStation 20 256MB AG10-E 2xSM81 ... SUN Ultra 80 4x450Mhz ... Amiga 2000HD, ECS 2MB ... Intergraph InterPro 225 ... DEC AlphaServer 4100 4x533Mhz 2MB ... SUN V880 ... DEC Multia 233Mhz
Unread postby SAQ » Thu Feb 23, 2017 7:10 am
Solid IMPACT was introduced slightly after High/Max IMPACT, so there's a possibility that v11 was made before Solid was a product. There's a big difference between Solid and High/Max with the absence of texturing, whereas with most SGI graphics the difference is in number of processors or amount of RAM (XS being the exception).
R4400 IMPACT systems were a factory shipped option. I've seen them reported as MG10 IMPACT or Solid IMPACT. R8k IMPACT was the unsupported config.
IP28 is sufficiently different from IP22 that I doubt you would get anything if you have a IP28 PROM plugged in.
Unread postby jan-jaap » Fri Mar 03, 2017 5:26 am
jammaster wrote:The V12 Indigo 2 existing software dump is false [...] Hardware Dumps rules ;-)
If only all hardware (I'm assuming you mean EPROM burners) agreed on byte order .... except they don't.
I'm guessing your EPROM burner is connected to a little endian x86 PC, while the SGI is a big endian MIPS.
Personally, I prefer to store EPROM images in host-native byte order, so text strings are readable and e.g. IDA can handle them. But to each their own.
jammaster
Unread postby jammaster » Mon Mar 06, 2017 1:39 pm
Yep, you are right ... But a lot of Hobbyists (normally constitued ^_^) use x86 machines for preservation/programation. (I think about MAME team...)
It's like you'd store a 16 bit program directly interleaved from two 8bits PROMs...
But, i had the chance to find your "not ready to burn" dump, so it's a good begining and i'll not complain ^_^;
A good stuff would be to update the nekowiki/PROM section. Just for saying that Solid Impact seem to be not 100% compatible with V11 Rev.
Unread postby robespierre » Mon Mar 06, 2017 1:51 pm
any programmer worth its salt should be able to switch byte and interleave order.
Unread postby dexter1 » Tue Mar 14, 2017 3:48 am
jammaster wrote:A good stuff would be to update the nekowiki/PROM section. Just for saying that Solid Impact seem to be not 100% compatible with V11 Rev.
I have updated the Wiki earlier to reflect this compatibility issue.
jammaster
Unread postby jammaster » Mon Mar 20, 2017 2:40 am
Great. Thank a lot for those who will fall on this topic...
