SGI PROM binaries? ... Solved
jammaster
Unread postby jammaster » Fri Feb 17, 2017 8:28 am
I'm curious about an hybrid indigo 2 with R4400 and Impact framebuffer.
I'm working on it now (R4k 200 with solid impact).
The machine boot and "chime" (old one) but no post on screen.
i have the standard 070-1367-004 EPROM on the mobo.
I own the last one (i presume) 070-1367-011 for IP22.
Coulid it be my IP22 board that haven't the correct PROM?
I'll switch with the later one...
And in add, it seem there is no dump of SGI PROM on the net ???
I'll take out my eprom burner ...
.......... :Onyx2: ............................... :Indigo2IMP: ..................................... :Indigo2: ........................... :Indigo: .............
IR2E 6GB 4x400Mhz .... MAXImp/4MB 512MB 195Mhz .... Extreme 384MB 250Mhz....Elan 64MB R3K ....
............. :Indy: ................................. :Octane2: .................
XS24 256MB 150 Mhz R5K .... V12 2GB 2x600Mhz ....
Intergraph TDZ2000 GL2 4110GT 1GB 2x600Mhz ... HP Visualize X-Class FX10 4GB 2x1000Mhz ... IBM 5160 V20, 8087 30Mb ... IBM 5162 10Mhz, 287XL, 6Mb, ST-4096 ... APPLE PowerMAC 9600/300 ... APPLE Quadra 840AV ... APPLE PowerMAC G5 Quad ... DEC AlphaStation 255/300 PS40 ... DEC AlphaStation 500/333 PS51 ... IBM RS/6000 PowerStation 7012-320 + GT3i ... SUN SparcStation 20 256MB AG10-E 2xSM81 ... SUN Ultra 80 4x450Mhz ... Amiga 2000HD, ECS 2MB ... Intergraph InterPro 225 ... DEC AlphaServer 4100 4x533Mhz 2MB ... SUN V880 ... DEC Multia 233Mhz
jammaster
Re: SGI PROM binaries?
Unread postby jammaster » Fri Feb 17, 2017 9:22 am
Ok so I need the rev E...
Here is my dumps:
070-1367-004
SGI Version 5.3 Rev C IP22 Oct 20, 1994 (BE):
http://theangel540.free.fr/PROM%20Sgi/Indigo%202/IP22-004.bin
070-1367-011
SGI Version 5.3 Rev E IP22 Sep 28, 1995:
http://theangel540.free.fr/PROM%20Sgi/Indigo%202/IP22-011.bin
070-1477-002
SGI Version 6.2 Rev A IP28 Aug 26,1996:
http://theangel540.free.fr/PROM%20Sgi/Indigo%202/IP28-002.bin
Unread postby robespierre » Fri Feb 17, 2017 2:15 pm
I am pretty sure the 1994 PROM is too old for Impact. But the others should work fine.
jammaster
Unread postby jammaster » Fri Feb 17, 2017 2:54 pm
Very strange...
My two IP22 boards upgraded with Rev E PROM don't want my three working solid impact (!)
all is working (impact I/O board, impact power supply ...)
with an IP22, a full impact accessories (psu + i/o + rev E PROM) but with an extreme boardset (and psu wires looped on tiny pcb), the mobo chime/post corectly.
With solid impact, the mobo chime corectly (!) and my monitor sync with my impact board but NOTHING on screen (just sync signal i think)...
the impact ready IP22 (8225-008) seem different than standard mobo (8225-004)...And too bad, my impact ready is dead...
????? (nvram ? ... Plcc flash onboard?)
jammaster
Unread postby jammaster » Sat Feb 18, 2017 2:03 am
I can't make an IP22 impact posting on screen now with V11 ROM. I am doomed...
Unread postby dexter1 » Sat Feb 18, 2017 6:36 am
Well, can you enter the PROM via serial console? And if so, can you run diagnostics?
So the Rev C PROM is the -004 version? Good, i've put that in the Wiki: http://www.nekochan.net/wiki/PROM#SGI_I ... nge_M_PROM
Unread postby jan-jaap » Sat Feb 18, 2017 7:30 am
There's an easy way to find out, assuming you've dumped your PROM image such that strings are in natural (readable) byte order.
Run strings on the binary and grep for 'mgras':
$ strings ip22prom.070-1367-012.bin | grep mgras
bootp()mgras.ide.IP22
mgras
mgras: VC3SRAM verify failed -
mgras_i2c: Unknown command %d
$ strings ip22prom.070-8127-002.bin | grep mgras
(no output)
jammaster
Unread postby jammaster » Sat Feb 18, 2017 7:37 am
...Fortunaly no, i haven't got a DIN8 to DB9 converter. (A shame, i'll made one or found one ... Seem to be a sun DIN plug)
It's very strange.
In all Indigo 2, i presume, the frame buffer post on just before switching the green led (after amber and chime).
My working impact post on (blanck screen but synchro) after the last green led...
The couple, CPU/ram/mobo seem to be OK... And work like a charm with an old extreme stack.
Does my PSU have a too low 5V extrenal rail??? (dawn, i just recaped it with new capacitors)
I have try with the last revision V12 dump, but the mobo won't chime (!)... corrupted dump???
PS: yep, the C revision seem to be 004... ^_^
jammaster
Unread postby jammaster » Sat Feb 18, 2017 7:40 am
...I have dumped all my PROMs with my eprom programer!
In the end, i'll search a used IP28 mobo... I'm bored with impact ready config :evil: . (but curious to make one working).
If anybody with pity sell one at a reasonably price ??? :oops:
jammaster
Unread postby jammaster » Sun Feb 19, 2017 9:03 am
Made a cable.
The Indigo seem to work headless ... But my Solid impact post nothing (!) ...
I don't think it's my monitor, my other indigo 2 maximpact work great on it!
jammaster
Unread postby jammaster » Sun Feb 19, 2017 10:42 am
Diganostic passed in console mode.
The only time i have seen this hybrid config posting!
Next step??? tree ... rope ...
Unread postby robespierre » Sun Feb 19, 2017 10:49 am
Do you see patterns on the display during the IDE test? OK, that's good.
It might be a cable problem... the assignment of the pins changed at some point.
jammaster
Unread postby jammaster » Sun Feb 19, 2017 10:59 am
yes, i have seen the test fully... the little mardigras logo on bottom left !
And the x3 cards i have work perfectly... I am lost at this point !
And same thing with my two IP22 mobos...
Is it a challenge to have a R4k/imp working?
different NVRAM between two configs ?
jammaster
Unread postby jammaster » Mon Feb 20, 2017 1:40 am
The V12 Indigo 2 existing software dump is false:
Here is my corrected one:
http://theangel540.free.fr/PROM%20Sgi/I ... 22-012.bin
I could dream to have a V12 Eprom working with my hell setup...
The problem of Endianness on 16Bits ROMs ... ^_^;
Hardware Dumps rules ;-)
I'll try my last rifle with this V12 on better eprom (10ns vs 12ns)... :roll:
jammaster
Unread postby jammaster » Mon Feb 20, 2017 1:57 am
