Onyx2 trouble
MrBill
Re: Onyx2 trouble
Unread postby MrBill » Fri Feb 10, 2017 9:14 am
Thanks for the info, i will get it swapped out tonight. I will get the actual part number off the mystery board as well. not sure what it is. ill get some pictures too.
I hate the idea of the DM board being junk, if someone else has a damaged one of the same model they are willing to part with perhaps i can make a working one out of the two bad ones.
MrBill
Re: Onyx2 trouble
Unread postby MrBill » Sat Feb 11, 2017 7:39 am
Swapped out the DM board and everything is looking good. Thanks for all the help.Im just glad i had the spare parts on hand needed to make it work.
Going to image the disks in the machine then ill move along to the other rackmount onyx2 and the crimson.
Re: Onyx2 trouble
Unread postby Raion-Fox » Sat Feb 11, 2017 12:50 pm
You could always mail the board to Ian Mapleson, see if he can resurrect it or use it for parts.
Re: Onyx2 trouble
Unread postby recondas » Tue Feb 28, 2017 4:50 am
MrBill wrote:Swapped out the DM board and everything is looking good.
Glad to hear you're up and running!
jan-jaap wrote:The remarks about replacing RAM chips that 'irsaudit' spews out are for SGI engineers. It doesn't even say where on the board to replace anything so it's not very useful for an end user.
FWIW, I seem to recall the solder side of some IR boards are marked with an alphanumeric grid. Haven't pulled a board to see if there's even a remote correlation between the my vague memories of a grid and the pin locations mentioned by irsaudit
INFO                * Miscompare on bit: 29 XMAP CLUT DATA pin: R 22
INFO                * Miscompare on bit: 30 XMAP CLUT DATA pin: R 21
INFO                * Miscompare on bit: 31 XMAP CLUT DATA pin: T 23
and the even less specific irsaudit repair recommendations
DIAG                Replace DG board; repair based on above INFO lines by 1)
DIAG                  fixing shorts or stucks on memory bus interfaces, 2)
DIAG                  replacing memory chips, 3) replace flawed ASICs (in order
DIAG                  of likelihood).
