Onyx2 trouble
MrBill
Onyx2 trouble
Unread postby MrBill » Thu Feb 09, 2017 6:59 am
Bought an onyx 2. Seems to hang during startup. If i leave it alone for a long time (over 10 minutes) it gets to the main prom menu. It has not gotten that far the last couple times. What is the procedure for connecting a serial terminal? I want to see if there is any info i am missing.
MrBill
Re: Onyx2 trouble
Unread postby MrBill » Thu Feb 09, 2017 7:19 am
figured it out. Not sure what that round diagnostic port on the front is used for, but i have a vt100 connected and it is working.
Re: Onyx2 trouble
Unread postby uunix » Thu Feb 09, 2017 7:39 am
MrBill wrote:figured it out. Not sure what that round diagnostic port on the front is used for, but i have a vt100 connected and it is working.
Could be the AUX port, I had the very same issue when I tried to power up my o200 (the one smashed up in the back of the car) for the first time.
MrBill
Re: Onyx2 trouble
Unread postby MrBill » Thu Feb 09, 2017 9:34 am
A little bit of progress. I have run into some trouble getting an a fresh install on the machine, but i decided to did through the boxes and found the original drives for the machine, which contained a working install of irix which i was able to boot into. However, something is not quite right.
Everything is ... like, covered in lines. but only certain windows. some parts are completely clear.
I... do not know what is going on, never seen such a thing till now.
Re: Onyx2 trouble
Unread postby Raion-Fox » Thu Feb 09, 2017 1:31 pm
It looks like a video problem. Pull the power, make sure it's discharged and then reseat the video and node boards.
Re: Onyx2 trouble
Unread postby recondas » Thu Feb 09, 2017 2:45 pm
Since it seems to run ok on the compute side, before you do anything else my suggestion would be to make a few passes with the diagnostic tool for InfiniteReality graphics, irsaudit. If you do pull boards, mark 'em so you know which slot each one came in (if you get them out of order/position POD will bitch at you until you correct the issue or erase it's memory).
irsaudit won't run while while graphics are loaded/running, so my preference is to boot via serial terminal.....though if you prefer you boot the system into graphics mode and stop graphics for the test, then restart graphics when the tests are done.
I typically launch irsaudit with the following command:
/usr/diags/IR/bin/irsaudit REPEAT=5
I use the "REPEAT=5" switch to ensure the system gets fully warmed up and to ensure that reports of errors (or the lack there of) remain consistant. There's a nekowiki @ http://www.nekochan.net/wiki/InfiniteRe ... h_irsaudit
If you go the serial terminal route, if possible use one that can display color graphics. irsaudit will color code the test results for you, which makes reading a couple hundred lines of text a much easier job. Use a null modem cable, set the serial terminal to 9600/8/N/1 and connect it to the first serial port on the IO6G (tty1).
MrBill wrote:Not sure what that round diagnostic port on the front is used for, but i have a vt100 connected and it is working.
The port is on the MSC (module/system controller), like the L1 controllers used in later generation hardware it provides some (lesser) environmental monitoring and other basic control functions. If the key is in the right position, there are a number of queries/commands the MSC will respond to; there are a few scattered through this thread.
BTW, your recent additions are some mighty fine examples of SGI hardware, including a Crimson (which is probably defined in the dictionary as the the SGI collector's Holy Grail). FWIW, since it appears to have two router boards in the photos, I think your skinless system is an O2K/Onyx2 compute module. If all else fails I'm pretty sure I still have a rack-style fascia panel / skin for an O2k (blue rather than purple).
MrBill
Re: Onyx2 trouble
Unread postby MrBill » Thu Feb 09, 2017 3:17 pm
Quite helpful information, thanks. How would i go about starting the system without graphics. I already have a serial terminal connected?
Crimson as the holy grail is close to my line of thought. I was amazed to get the first crimson a while back, kinda amazed i was able to find another. My first crimson had an issue with the IO3 board, i was unable to locate just the board, so i managed to get another whole machine. The other one still kinda works, although in a kind of crippled state.
I was under the impression that these onyx2 machines linked together in some way with numalink cables or something. The skinless one appears to have those connectors, the deskside does not. I know nothing about them yet really, still need to run hinv and get the details.
I have a skin set for the rackmount machine, what i appear to be missing is the bottom plastic with the casters. Without being propped up on something, it is sitting flush with the vents, no air getting through.
MrBill
Re: Onyx2 trouble
Unread postby MrBill » Thu Feb 09, 2017 3:27 pm
Re: Onyx2 trouble
Unread postby recondas » Thu Feb 09, 2017 3:40 pm
MrBill wrote:Quite helpful information, thanks.
You're welcome.
MrBill wrote:How would i go about starting the system without graphics. I already have a serial terminal connected?
Boot the system with only the serial terminal connected (no monitor, kb or m). Login as root, and run /usr/gfx/gfxinfo. If it indicated no graphics are loaded start the irsaudit tests. If graphics show to be loaded, run /usr/gfx/stopgfx , then run the tests. Depending on the type and number of graphics boards you have you're potentially looking at an output of several hundred lines of text, so set your serial terminal up with a fairly large scroll back buffer so you can save the entire results. BTW, even if you do happen to start irsaudit with graphics are loaded, you won't do any physical harm; the test will nag you to stop gfx and not go any farther.
If the tests don't report any major errors, I'd suggest pulling the old boot drive and put it aside for later content examination, and do a clean install on to a different drive. If you're lucky what you saw on the screen might just be bit rot.
MrBill wrote:I was under the impression that these onyx2 machines linked together in some way with numalink cables or something. The skinless one appears to have those connectors, the deskside does not.
Because of the space taken on the midplane by the IR board set slots, an Onyx2 Deskside doesn't have the necessary hardware to allow full NUMAlink connections, so a compute module / Onyx2 DS hook-up probably isn't gonna happen.
MrBill
Re: Onyx2 trouble
Unread postby MrBill » Thu Feb 09, 2017 4:30 pm
INFO                Unable to detect EventMon Deamon. Logging disabled.
REV                 Rev:3.3.2 Sun Jan  8 23:51:21 PST 2006 sherwood on splat
CMDL                /usr/diags/IR/bin/irsaudit REPEAT=5
TEST reset          Reset
RSLT reset          PASS
TEST xgid           Report XG ID and test MAP RAM config
INFO                Revision: 00, Part No.: c102, Manufacturer No.: 2aa
INFO                MAP RAM Config = 128Kx32 bits, SSRAM type used = 32K*36
INFO                  bits
RSLT xgid           PASS
TEST xgregs         Test the XG registers
RSLT xgregs         PASS
TEST xgram          Test the XG MAP RAM
INFO                Found XG MAP RAM to have 128K entries
TRCE                Doing XG MAP RAM data path test
TRCE                Doing XG MAP RAM address path test
TRCE                Doing XG MAP RAM cell test.
RSLT xgram          PASS
TEST xgerr          Test the XG Error Behavior
INFO                Running Bad Map RAM Parity Tests
INFO                    Enabling parity checking...
INFO                    Disabling parity checking...
INFO                Running XT Configuration Tests
RSLT xgerr          PASS
TEST hh_reg         HIP Host Registers
RSLT hh_reg         PASS
TEST ha_reg         HIP ARM Registers
RSLT ha_reg         PASS
TEST jtaginit       JTAG Master
RSLT jtaginit       PASS
TEST mbox           ARM-Host Mailbox
RSLT mbox           PASS
TEST sysprobe       JTAG System Probe
TRCE                GE board has 4 GE ASICs.
INFO                GE board is a GE16.
TRCE                BEF has 4MB of memory.
TRCE                RM #0 is an RM/TM combination.
INFO                RM #0 is an RM9
TRCE                TM #0 has 64MB (1Mx16 parts) of texture memory.
TRCE                RM/TM #1 not detected via JTAG.
TRCE                RM/TM #2 not detected via JTAG.
TRCE                RM/TM #3 not detected via JTAG.
TRCE                DG has 2 VOC configuration.
TRCE                No option present in DG option slot.
TRCE                DG has 32K colormap RAMs.
TRCE                DG has no external gamma/deep colormap RAM.
RSLT sysprobe       PASS
TEST nicprobe       NIC Board Probe
TRCE                Checking XG NICs
TRCE                Reading ARM ucode from: /usr/diags/IR/ucode/arm1_nic.u
TRCE                GE NIC #: 0000.002b.f160 (family: 0b)
TRCE                    Serial #: GLN976
TRCE                    Part #: 030-1398-001
TRCE                    rev_code: A
TRCE                    name: GE16-4
NIC#                PNGE-030-1398-001 SN-GLN976 (0000.002b.f160)
TRCE                RM0 NIC #: 0000.0025.9bd4 (family: 0b)
TRCE                    Serial #: DEM976
TRCE                    Part #: 030-1402-001
TRCE                    rev_code: A
TRCE                    name: RM9
NIC#                PNRM-030-1402-001 SN-DEM976 (0000.0025.9bd4)
TRCE                TM0 NIC #: 0000.0024.051e (family: 0b)
TRCE                    Serial #: GBY932
TRCE                    Part #: 030-1053-001
TRCE                    rev_code: F
TRCE                    name: TM7-64
NIC#                PNTM-030-1053-001 SN-GBY932 (0000.0024.051e)
TRCE                DG NIC #: 0000.004d.e7de (family: 0b)
TRCE                    Serial #: KWZ301
TRCE                    Part #: 030-1055-001
TRCE                    rev_code: P
TRCE                    name: DG5-2
NIC#                PNDG-030-1055-001 SN-KWZ301 (0000.004d.e7de)
RSLT nicprobe       PASS
TEST intr           HIP Interrupts
TRCE                Expecting ARM interrupt...
TRCE                Expecting a FIFO_HI interrupt...
TRCE                Expecting a FIFO_LO interrupt...
RSLT intr           PASS
TEST icu_mem        ICU Memory
RSLT icu_mem        PASS
TEST fmreg          FM Registers
RSLT fmreg          PASS
TEST fmvcbus        VC Bus Test (using FM)
RSLT fmvcbus        PASS
TEST fmdid          FM Normal DID Table
RSLT fmdid          PASS
TEST fmovdid        FM Overlay/Underlay DID Table
RSLT fmovdid        PASS
TEST encreg         Encoder Registers
RSLT encreg         PASS
TEST vocreg         VOC Registers
RSLT vocreg         PASS
TEST vocdblbuf      VOC Double-buffered Registers
RSLT vocdblbuf      PASS
TEST vocspreg       VOC Special Register Operations
RSLT vocspreg       PASS
TEST voccpbuf       VOC Copy-buffered Register Mechanisms
RSLT voccpbuf       PASS
TEST dacreg         Video DAC Registers
RSLT dacreg         PASS
TEST xmapreg        XMAP Registers
RSLT xmapreg        PASS
TEST xmapdid        XMAP Normal DID Table
RSLT xmapdid        PASS
TEST xmapovdid      XMAP Overlay/Underlay DID Table
RSLT xmapovdid      PASS
TEST xmapchid       XMAP Channel Id Table
RSLT xmapchid       PASS
TEST vcbus          VC Bus Test (using XMAP)
RSLT vcbus          PASS
TEST xmapmem        XMAP mem test
TRCE                Doing XMAP CLUT data path test.
TRCE                Doing XMAP CLUT address path test.
INFO                XMAP 0 CLUT Addr test failures
INFO                * Miscompare on bit: 1  XMAP CLUT ADDR pin: C 21
INFO                * Miscompare on bit: 2  XMAP CLUT ADDR pin: D 20
INFO                * Miscompare on bit: 3  XMAP CLUT ADDR pin: D 21
INFO                * Miscompare on bit: 4  XMAP CLUT ADDR pin: C 22
INFO                * Miscompare on bit: 5  XMAP CLUT ADDR pin: E 21
INFO                * Miscompare on bit: 6  XMAP CLUT ADDR pin: D 22
INFO                * Miscompare on bit: 7  XMAP CLUT ADDR pin: B 24
INFO                * Miscompare on bit: 8  XMAP CLUT ADDR pin: F 21
INFO                * Miscompare on bit: 9  XMAP CLUT ADDR pin: E 22
INFO                * Miscompare on bit: 10 XMAP CLUT ADDR pin: G 20
INFO                * Miscompare on bit: 11 XMAP CLUT ADDR pin: C 23
INFO                * Miscompare on bit: 12 XMAP CLUT ADDR pin: C 24
INFO                * Miscompare on bit: 13 XMAP CLUT ADDR pin: D 23
INFO                * Miscompare on bit: 14 XMAP CLUT ADDR pin: F 22
INFO                * Miscompare on bit: 15 XMAP CLUT ADDR pin: E 23
TRCE                Doing XMAP CLUT cell test.
INFO                XMAP 0 CLUT data cell failures
INFO                * Miscompare on bit: 0  XMAP CLUT DATA pin: J 21
INFO                * Miscompare on bit: 1  XMAP CLUT DATA pin: H 22
INFO                * Miscompare on bit: 2  XMAP CLUT DATA pin: G 23
INFO                * Miscompare on bit: 3  XMAP CLUT DATA pin: H 23
INFO                * Miscompare on bit: 4  XMAP CLUT DATA pin: J 22
INFO                * Miscompare on bit: 5  XMAP CLUT DATA pin: H 24
INFO                * Miscompare on bit: 6  XMAP CLUT DATA pin: J 23
INFO                * Miscompare on bit: 7  XMAP CLUT DATA pin: J 24
INFO                * Miscompare on bit: 8  XMAP CLUT DATA pin: K 21
INFO                * Miscompare on bit: 9  XMAP CLUT DATA pin: K 22
INFO                * Miscompare on bit: 10 XMAP CLUT DATA pin: L 20
INFO                * Miscompare on bit: 11 XMAP CLUT DATA pin: K 23
INFO                * Miscompare on bit: 12 XMAP CLUT DATA pin: L 21
INFO                * Miscompare on bit: 13 XMAP CLUT DATA pin: L 22
INFO                * Miscompare on bit: 14 XMAP CLUT DATA pin: L 23
INFO                * Miscompare on bit: 15 XMAP CLUT DATA pin: L 24
INFO                * Miscompare on bit: 16 XMAP CLUT DATA pin: M 21
INFO                * Miscompare on bit: 17 XMAP CLUT DATA pin: M 22
INFO                * Miscompare on bit: 18 XMAP CLUT DATA pin: M 23
INFO                * Miscompare on bit: 19 XMAP CLUT DATA pin: N 23
INFO                * Miscompare on bit: 20 XMAP CLUT DATA pin: P 24
INFO                * Miscompare on bit: 21 XMAP CLUT DATA pin: N 22
INFO                * Miscompare on bit: 22 XMAP CLUT DATA pin: N 21
INFO                * Miscompare on bit: 23 XMAP CLUT DATA pin: P 23
INFO                * Miscompare on bit: 24 XMAP CLUT DATA pin: R 23
INFO                * Miscompare on bit: 25 XMAP CLUT DATA pin: P 22
INFO                * Miscompare on bit: 26 XMAP CLUT DATA pin: P 21
INFO                * Miscompare on bit: 27 XMAP CLUT DATA pin: T 24
INFO                * Miscompare on bit: 28 XMAP CLUT DATA pin: P 20
INFO                * Miscompare on bit: 29 XMAP CLUT DATA pin: R 22
INFO                * Miscompare on bit: 30 XMAP CLUT DATA pin: R 21
INFO                * Miscompare on bit: 31 XMAP CLUT DATA pin: T 23
INFO                CLUT mem errors = 30333; Gamma mem errors = 0
DIAG                Replace DG board; repair based on above INFO lines by 1)
DIAG                  fixing shorts or stucks on memory bus interfaces, 2)
DIAG                  replacing memory chips, 3) replace flawed ASICs (in order
DIAG                  of likelihood).
CODE xmapmem        BF  R PNDG-030-1055-001:SN-KWZ301(0000.004d.e7de)@XMAP0
RSLT xmapmem        FAIL                XMAP MEMORY TEST FAILED.
INFO                Maximum error count (1) reached
META                ITERATION=1       PASSES         NON-PASSES
META                reset             1              0
META                xgid              1              0
META                xgregs            1              0
META                xgram             1              0
META                xgerr             1              0
META                hh_reg            1              0
META                ha_reg            1              0
META                jtaginit          1              0
META                mbox              1              0
META                sysprobe          1              0
META                nicprobe          1              0
META                intr              1              0
META                icu_mem           1              0
META                fmreg             1              0
META                fmvcbus           1              0
META                fmdid             1              0
META                fmovdid           1              0
META                encreg            1              0
META                vocreg            1              0
META                vocdblbuf         1              0
META                vocspreg          1              0
META                voccpbuf          1              0
META                dacreg            1              0
META                xmapreg           1              0
META                xmapdid           1              0
META                xmapovdid         1              0
META                xmapchid          1              0
META                vcbus             1              0
META                xmapmem           0              1
META                TOTAL             28             1
CODE                SUM  Hardware error
CODE                BSUM   0R   0Y  13G PNGE-030-1398-001:SN-GLN976 (0000.002b.f160)
CODE                BSUM   0R   0Y   2G PNTM-030-1053-001:SN-GBY932 (0000.0024.051e)
CODE                BSUM   0R   0Y   2G PNRM-030-1402-001:SN-DEM976 (0000.0025.9bd4)
CODE                BSUM   1R   0Y  17G PNDG-030-1055-001:SN-KWZ301 (0000.004d.e7de)
CODE                CSUM   1R   0Y  17G XMAP0
TRCE                Sending crashlog to availmon... (Use +nolog to avoid this.)
Database API Error -9: "Can't connect to local MySQL server through socket '/tmp/espdb.sock' (2)" - Invalid/missing database name
Usage:
espquery [-th] [-u username] [-p password] [-n hostname] -s sqlstring dbname
Not sure that reseating boards will fix the problem.
Would this be a hardware failure? What board is at fault?
I do have some spare boards, hopefully i have one that works.
MrBill
Re: Onyx2 trouble
Unread postby MrBill » Thu Feb 09, 2017 5:07 pm
Inventory of spare boards :
013-2464-001 raster manager
030-1055-001 onyx display generator
013-1972-002 dg5-2 w/gvo option
030-1042-001 ??
013-1926-002 ??
?? - fibre channel board
What board should be swapped out? i don't want to pull any boards out i do not have to.
Re: Onyx2 trouble
Unread postby Raion-Fox » Thu Feb 09, 2017 6:28 pm
Your Display generator (the board with the monitor connections) is the one at fault here. You will need to replace it as it looks like the memory chips in it are shot. They're very static sensitive.
MrBill
Re: Onyx2 trouble
Unread postby MrBill » Thu Feb 09, 2017 8:01 pm
Ok yeah, i have heard they are very static sensitive, I will handle with care and use a grounding strap.
Are the memory chips standard and can be sourced somewhere online or are they proprietary as hell, specific to this machine and not a chance of replacing them?
Re: Onyx2 trouble
Unread postby jan-jaap » Fri Feb 10, 2017 12:02 am
'irsaudit' has marked your DG board as faulty. So just pull it and replace it with one of your spares:
Either should work, the latter has some extra BNCs if ever you want to attach an SDI monitor and do funky graphics-to-video things.
The remarks about replacing RAM chips that 'irsaudit' spews out are for SGI engineers. It doesn't even say where on the board to replace anything so it's not very useful for an end user.
You've got an empty slot for an extra RM9, so once you've got something that passes irsaudit you might as well load one of the three spare
and enjoy the extra raster/texture memory.
Re: Onyx2 trouble
Unread postby dexter1 » Fri Feb 10, 2017 3:42 am
MrBill wrote:013-1926-002 ??
That doesn't seem to be the part number for an Onyx Everest/Powerpath or Origin XIO option board, but the steel actuator mechanism of an Origin/Onyx option, holding the board in place.
A picture would help in identifying the unknown board(s).
