Can't get SCSI2SD working on Challenge S
Fleeno
Unread postby Fleeno » Wed Nov 30, 2016 8:03 pm
I have a Challenge S (Indy) that I'm trying to setup with a SCSI2SD. I'm actually trying to install OpenBSD from an external CDROM, and when I attempt to boot I get this:
>> scsi(0)cdrom(6)partition(8)bootecoff scsi(0)cdrom(6)partition(0)/bsd.rd.IP22
Cannot load scsi(0)cdrom(6)partition(8)bootecoff.
Illegal f_magic number 0x0, expected MIPSELMAGIC or MIPSEBMAGIC.
Exception: <vector=Normal>
Status register: 0x30004803<CU1,CU0,IM7,IM4,IPL=???,MODE=KERNEL,EXL,IE>
Cause register: 0x10<CE=0,EXC=RADE>
Exception PC: 0xbfc432c4, Exception RA: 0xbfc32c84
Read address error exception, bad address: 0xc000015
Saved user regs in hex (&gpda 0xa8740e48, &_regs 0xa8741048):
arg: a8740000 a8747510 a8749800 a8747510
tmp: a8740000 0 a8749800 f a87473d0 a87ffba0 a000000 a87ffca0
sve: a8740000 3 400000 8000000 16 3f80 0 2000000
t8 a8740000 t9 ffffffff at ffffffff v0 ffffffff v1 ffffffff k1 42
gp a8740000 fp ffffffff sp ffffffff ra ffffffff
PANIC: Unexpected exception
I have the SCSI2SD setup with a 4GB card, and I've followed the directions in the wiki entry and believe I have it setup about the same, other than my card is smaller.
If I use a real HDD instead, I can boot the OpenBSD installer just fine.
I feel like it's some sort of SCSI issue, as I also get this on boot:
dks0d1s0: volume header not valid
sc0,1,0: SYNC negotiation error, resetting SCSI bus
Warning: unrecognized volume header type.
I've tried it with and without the terminator resistors installed, though I don't think I need them since I have a terminator on there, which works with the real drives.
Here's a quick hinv just for some info:
>> hinv
System: IP22
Processor: 100 Mhz R4600, with FPU
Primary I-cache size: 16 Kbytes
Primary D-cache size: 16 Kbytes
Memory size: 32 Mbytes
SCSI Disk: scsi(0)disk(1)
SCSI CDROM: scsi(0)cdrom(6)
Thanks!
:O2: :O2: :O2: :1600SW: :Octane: :Indy: :BA123:
Re: Can't get SCSI2SD working on Challenge S
Unread postby robespierre » Thu Dec 01, 2016 3:03 am
Is the SCSI connector keyed for polarity? What you said is that the CDROM drive works when a "real HDD" is used, but not when the SCSI2SD is plugged in. What about when nothing is plugged in?
Does your SCSI HDD supply termination power to the bus?
Fleeno
Unread postby Fleeno » Thu Dec 01, 2016 7:26 am
The SCSI connector does have a notch/key, so they should be connected properly.
I did just try it with no HDD or SCSI2SD connected, and it does work just fine that way!
As for the HDD supplying termination power, I'm not sure. I'll have to find the manual for it and see if it does or not.
Thanks!
tomvos
Unread postby tomvos » Thu Dec 01, 2016 8:44 am
About the SYNC error, see the http://www.nekochan.net/wiki/SCSI2SD entry:
I've installed IRIX 6.5.22m on the SCSI2SD device for my 180MHz R5000 Indy with 192MB ram and a XL24 graphics board. The installation is the same as installing on a regular disk, but because the SCSI2SD board does not support sync negotiation, you will receive the following warnings:
- sc0,1,0: SYNC negotiation error, resetting SCSI bus.
- NOTICE: wd93 SCSI Bus=0 ID=1: SYNC negotiation error, resetting bus.
Just a guess, did you update to the latest SCSI2SD firmware? Initially I had quite some problems with the adapter, but after a certain firmware release the behaviour of the SCSI2SD adapter got much more predictable. It might be worth a try.
Fleeno
Unread postby Fleeno » Sat Dec 03, 2016 10:44 am
tomvos wrote:Just a guess, did you update to the latest SCSI2SD firmware? Initially I had quite some problems with the adapter, but after a certain firmware release the behaviour of the SCSI2SD adapter got much more predictable. It might be worth a try.
Hi Tom, I did update to the latest firmware. I haven't tinkered with it much in the last few days, but I'm getting back to it now. Hopefully I can get it working!
Unread postby dexter1 » Mon Dec 05, 2016 12:30 am
Fleeno wrote:I have the SCSI2SD setup with a 4GB card, and I've followed the directions in the wiki entry and believe I have it setup about the same, other than my card is smaller.
What hardware version is your SCSI2SD card? It sounds as if you have the latest v6 version of the card.
Fleeno
Unread postby Fleeno » Tue Dec 27, 2016 2:19 pm
The hardware version is V5.0a, and I'm on firmware 4.6.
Thinking it was a SCSI issue, I've since added a different terminator onto the back of my external CD-ROM drive. That hasn't made a difference.
But, I've instead decided to try installing IRIX instead. I can boot into fx and (apparently) partition the SD drive, but after that I try to boot into the installer and get a similar message:
Insert the installation CD-ROM, then press <enter>:
Cannot load scsi(0)cdrom(6)partition(8)sashARCS.
Cannot load scsi(0)cdrom(6)partition(8)sashARCS -- execute format error.
Unable to continue; press <enter> to return to the menu:
I did swap back in my real HDD, and it does work there. I've tried several SD cards as well. Maybe I just have a bad adapter?
Fleeno
Unread postby Fleeno » Wed Dec 28, 2016 8:53 am
Well, I got it working in a round-about way...
I installed IRIX on a real HDD in this system, then added the SCSI2SD as a second drive. I cloned the root HDD to the SD, removed the HDD, and it boots fine from the SCSI2SD!
So now I have a working Challenge S with a 4GB SD drive.
Unread postby dexter1 » Wed Dec 28, 2016 2:07 pm
This indeed sounds like the adapter causing problems on the SCSI bus. It does look easily testable because the system can't boot from the CDROM when the SCSI2SD is attached.
I never used the SCSI2SD card with additional hardware on the SCSI bus, since i can netboot most of these systems. Good that you have it running, another silent MIPS IRIX/OpenBSD box humming along!
Fleeno
Unread postby Fleeno » Wed Dec 28, 2016 5:50 pm
It's just IRIX for now! I decided that since almost anything can run OpenBSD, that this machine should stay pure.
I should really get setup for serving up installs over the network. I'm going to be reinstalling my Octane soon on a SSD, and potentially have a new Indigo2 on the way.
