Indigo 2 GU1-Extreme vs. Solid Impact?
climbingcolorado
Unread postby climbingcolorado » Thu Sep 22, 2016 9:19 pm
Hello,
I just got my hands on two Indigo 2 computers. One has an R10k@195Mhz w/Solid Impact graphics and the other has an R4400@250Mhz w/GU1-Extreme graphics (both in purple cases). Which graphics card is better? I've found several websites that describe what the two cards are, various graphics options, and their history but no performance comparison data.
Cordially,
Rob
USAF Academy, CO
Rob Ramsey
USAF Academy, CO
Security+, Network+, A+, Server+, Linux+, Project+,
CEH, CCNA, CCNA Security, CCNP, RHCSA, SCSA, ITILv3
:Indigo2IMP: R10k@195Mhz w/SolidIMPACT & 256MB RAM
:Indigo2IMP: R4400@250Mhz w/GU1-Extreme & 128MB RAM
Re: Indigo 2 GU1-Extreme vs. Solid Impact?
Unread postby robespierre » Fri Sep 23, 2016 2:05 am
Ian Mapleson has compiled some very interesting performance comparisons, like this one:
http://www.futuretech.blinkenlights.nl/ ... lebuf.html
You can see that R10K Solid IMPACT is between 10% to 200% faster than R4400 EXtreme. For some applications the advantage to IMPACT is somewhat greater.
climbingcolorado
Unread postby climbingcolorado » Fri Sep 23, 2016 7:20 am
Hello,
Thanks for the link! I found the following:
                                               MWin   MWin/SH   MWin/W   SWin   SWin/SH   SWin/W
Indigo2 R10000 195MHz 1MB L2 SolidIMPACT:      2.54    27.39    15.21    6.56    30.68    16.05
Indigo2 R4400SC/250 2MB GU1-Extreme (8GE):     2.11    11.25    12.43    4.06    11.63    13.67
Cordially,
Rob
USAF Academy, CO
Rob Ramsey
USAF Academy, CO
Unread postby vishnu » Fri Sep 23, 2016 10:08 am
Even though you're already an owner Ian's indigo2 buyer's guide is still a worthwhile read: http://www.sgidepot.co.uk/i2info.html
Unread postby foetz » Fri Sep 23, 2016 5:02 pm
the impact has more juice but the extreme is more compatible. in fact your r4400/extreme combination is one of the most compatible of all. no program i know of complains about it and you can run everything from irix 4 to 6.5.22
Unread postby Trippynet » Sat Sep 24, 2016 5:35 am
Well, it's more compatible from an OS perspective, but of course the downside is that you can't run MIPS4 stuff such as Nekoware, hence I'd say compatibility varies depending on what you're looking at.
climbingcolorado
Unread postby climbingcolorado » Sat Sep 24, 2016 9:44 am
To be honest, I'm not planning on doing much graphically with the systems; maybe play BZFlag or Doom for fun. Does anyone remember the command to bring up the CPU, video, and memory utilization bar chart? It's been forever since I've sat at an SGI.
Thanks!
Rob
Rob Ramsey
USAF Academy, CO
Unread postby dexter1 » Sat Sep 24, 2016 10:07 am
climbingcolorado wrote:Does anyone remember the command to bring up the CPU, video, and memory utilization bar chart?
It's gr_osview
Unread postby Trippynet » Sat Sep 24, 2016 10:08 am
gr_osview
