Can't type into Indy serial console?
mattst88
Unread postby mattst88 » Sat Apr 12, 2014 3:53 pm
I'm trying to get serial console to work on a couple of Indys.
I have Indy -> [Mini-DIN8M/DB25M cable] -> [DB25F/DB9M adapter] -> [DB9F/DB9F null modem cable] -> PC
The Indy boots (no keyboard attached), and I get the System Maintenance Menu prompt, but it doesn't accept my input from the PC. I've confirmed this behavior with two Indys, so I doubt they're individually to blame.
I'm using GNU Screen with default settings (9600 8n1). Any idea what's going on?
My computers (incomplete)
Re: Can't type into Indy serial console?
Unread postby foetz » Sun Apr 13, 2014 4:22 am
what os is on the pc?
mattst88
Unread postby mattst88 » Sun Apr 13, 2014 10:15 am
foetz wrote:what os is on the pc?
Linux.
Unread postby recondas » Sun Apr 13, 2014 12:07 pm
mattst88 wrote:I have Indy -> [Mini-DIN8M/DB25M cable] -> [DB25F/DB9M adapter] -> [DB9F/DB9F null modem cable] -> PC
Thats's a fair amount of serial gender-bending. Have you already compared the pin out from one end to the other? Seem to vaguely recall a few of of the mini-din8 to DB25 cables intended for early macs didn't provide the right connections for reliable terminal access.
mattst88
Unread postby mattst88 » Tue Apr 15, 2014 6:45 pm
I have not. This NetBSD page [1] gave a hint though: "Macintosh serial cables work great for serial-console cables, as long as you are willing to do it without hardware handshaking lines."
Running screen with hardware flow control off lets it work.
screen /dev/ttyS0 ixon ixoff
I'll probably get a different cable with the appropriate lines [2] though.
[1] http://www.netbsd.org/ports/sgimips/faq.html
[2] http://www.pccables.com/MINI_DIN8_M_to_ ... _CABLE.htm
