No video output from Indy?
mattst88
Unread postby mattst88 » Sat Apr 05, 2014 3:33 pm
I've got an SGI 13W3 -> VGA adapter that I'm trying to use to get video out of an Indy. When powered on, the Indy makes its boot chime, the LED flips red to green a couple of times before settling on green, but I get nothing from the monitor.
The monitor is a Dell 2405FPW, which according to the wiki (http://www.nekochan.net/wiki/Monitors_on_SGI_Machines) supports sync-on-green and works with the O2.
I have noticed that pin 9 (https://commons.wikimedia.org/wiki/File:DE15_male.svg) is missing on the (male) VGA end of the cable. Is this intentional, or is this my problem?
My computers (incomplete)
kjaer
Re: No video output from Indy?
Unread postby kjaer » Sat Apr 05, 2014 7:34 pm
For VGA, pin 9 is n/c.
Unread postby robespierre » Sat Apr 05, 2014 10:03 pm
The O2 outputs separate sync signals since it was designed with a VGA port. The Indy does not, so a monitor that is simply sync-on-green tolerant will not synchronize. You need to use setmon(1) with "-sn" to tell an Indy to output separate sync.
chicaneuk
Unread postby chicaneuk » Mon Apr 07, 2014 2:00 am
You may also need to reset the video output on the prom. I recently picked up an old Indy from work and had the same problem as you - got the boot chime, LED went to green, but no picture. I knew the video cable & monitor I had were good as I had been using them on an Indigo 2.
So I bought the correct serial cable from Amazon / eBay (don't recall which) and connected up to see it booting fine, so went into the command line on the prom and used the 'resetenv' command. Can't recall if I then needed a reboot, or whether the display flicked into life instantly, but either way it worked!
miod
Unread postby miod » Mon Apr 07, 2014 11:38 pm
chicaneuk wrote:You may also need to reset the video output on the prom. I recently picked up an old Indy from work and had the same problem as you - got the boot chime, LED went to green, but no picture. I knew the video cable & monitor I had were good as I had been using them on an Indigo 2.
In your particular case, this might have been caused by a monitor=H or monitor=h setting in the prom environment, which would have upset your monitor.
chicaneuk
Unread postby chicaneuk » Tue Apr 08, 2014 1:39 am
Good to know :) I must admit I didn't know the reason why the command worked (as I'm really not that sharp on SGI stuff) but just glad it fixed it!
