1st Generation SB Audigy ES SB0160 audio works in IP35
GL1zdA
Unread postby GL1zdA » Mon Apr 08, 2013 1:09 pm
An Audigy ES (SB0160 - first generation Audigy without FireWire) also works. It gives the same warning as the full Audigy SB0090, but works (at least with IRIX system sound) and is reported as an "Iris Audio Processor: version EMU revision A3, number 1". Tested with IRIX 6.5.26.
Moderator Edit:
Split from The Fuel (IP35) Hardware Aggregator after the appropriate content was aggregated. <recondas>
