problems on octane random shut downs
soviet
Unread postby soviet » Mon Aug 13, 2012 8:37 am
Hello i have a octane 1, and having random power downs problems, and also some times i can't power it up i have to move the octane around or lift it 5 cm drop it and then push the power button and the system start ok.
Sometimes i can work for hours whit no problems, but at random the system start the shut down procedure and display a XIO error on the console before shut down.
How can i fix this ?.
Re: problems on octane random shut downs
Unread postby ClassicHasClass » Mon Aug 13, 2012 10:08 am
If moving it around or bouncing it seems to fix it, sounds like "something" is "loose."
soviet
Unread postby soviet » Mon Aug 13, 2012 11:35 am
i Think the same but seems to not by something loose in the machine i removed the psu and the xio cards and repluged them to no avail
Unread postby SAQ » Tue Aug 14, 2012 9:22 pm
If it isn't something loose then the next suspect is probably the frontplane board (FP1) - the power button does show up as an XIO widget, and a failure somewhere there would definitely start a shutdown.
The main circuitry on the FP1 is the XBOW ASIC, but the board still might be worth checking it out because it does sound like something mechanical, and it might be the switch or a trace.
soviet
Unread postby soviet » Sat Apr 30, 2016 6:29 am
OK i know it take a little time but was able to fix this issue, one big coil inside the power supply have both pins to the board cold soldered it was completely loose re solder it and know the poweroff issues diapered.
Unread postby vishnu » Sun May 01, 2016 5:50 pm
soviet wrote:OK i know it take a little time but was able to fix this issue, one big coil inside the power supply have both pins to the board cold soldered it was completely loose re solder it and know the poweroff issues diapered.
That's some fine debugging to track something like that down, nice going... :mrgreen:
soviet
Unread postby soviet » Sat Oct 14, 2017 10:45 am
Yes now i managed to damage the scsi bus i believe, removed the tape drive without powering off the computer and now the os get stuck when booting, i can boot fine from the installer cd but the installation never finish :'( get stuck at the same point the os boot.
Unread postby vishnu » Sat Oct 14, 2017 11:01 pm
soviet wrote:Yes now i managed to damage the scsi bus i believe, removed the tape drive without powering off the computer and now the os get stuck when booting, i can boot fine from the installer cd but the installation never finish :'( get stuck at the same point the os boot.
And that's with the tape drive put back in, right? Because if it's still out the problem could be a bus termination failure...
Unread postby robespierre » Sun Oct 15, 2017 12:25 am
I don't think you damaged the bus controller. SCA2 connectors are designed to connect and disconnect safely in powered enclosures (hot plug ability). I would look elsewhere.
soviet
Unread postby soviet » Mon Oct 16, 2017 11:04 am
When i removed the dat drive the system got frozen the next time at boot the computer started to boot and got stuck every time half way at startup.
Then i tried several hard drives, and external cdrom different termination but im unable to get to the second half of the installation sequence.
The installer get stalled when i start the install environment, not sure what to try next.
