It is currently Sat May 18, 2013 3:07 pm
Post new topic Reply to topic  [ 4 posts ]
Unread postPosted: Tue Jan 17, 2012 1:37 pm
In wanted to attach a DELL PowerVault 220S (dual Ultra 320 SCSI enclosure) to my SGI's. The PowerVault assigns ID 0 ... 5 to disks, 6 to the SES controller, and 8 ... 15 to disks again.
SGI hardware typically reserves ID0 for the SCSI controller, so I was afraid I would be able to use only 13 of the 14 disk slots.
Turns out you can change the ID of the SCSI host controller from the PROM:
Code:
setenv scsihostid 7
The result, with the array configured as a single bus attached to my Tezro:
Code:
  Disk drive: unit 0 on SCSI controller 1 (unit 0)
  Disk drive: unit 1 on SCSI controller 1 (unit 1)
  Disk drive: unit 2 on SCSI controller 1 (unit 2)
  Disk drive: unit 3 on SCSI controller 1 (unit 3)
  Disk drive: unit 4 on SCSI controller 1 (unit 4)
  Disk drive: unit 5 on SCSI controller 1 (unit 5)
  Scanner: unit 6 on SCSI controller 1
  Disk drive: unit 10 on SCSI controller 1 (unit 10)
  Disk drive: unit 11 on SCSI controller 1 (unit 11)
  Disk drive: unit 12 on SCSI controller 1 (unit 12)
  Disk drive: unit 13 on SCSI controller 1 (unit 13)
(Currently running with 10 disks; I'm 4 disk brackets short)
I'm curious about the performance when fully populated with 72GB 15K.3 disks, in two groups of 7 disks and attached to a dual Ultra320 controller (LSI1030). In theory it should peak at 640MB/s 8-)
Changing the SCSI host ID this way is a bit of a hack: it changes the host ID of all controllers in the system
Unread postPosted: Tue Jan 17, 2012 6:30 pm
jan-jaap wrote:
That's a pretty cool trick, j-j. Could occasionally be useful. Thank you for mentioning it.
Unread postPosted: Thu Jan 19, 2012 7:35 am
I saw one Fuel with this environment variable declared with the value 00. Since the Fuel has two on-board controllers, it is likely possible to specify an id per controller. In your case, trying 07 ought to keep id 0 for the internal controller, and use 7 for the external controller... or maybe the opposite ;)
:Indigo:R4000 :Indigo2:R4400 :Indigo2IMP:R4400 :Indigo2:R8000 :Indigo2IMP:R10000 :Indy:R4000PC :Indy:R4000SC :Indy:R5000SC :O2:R5000 :O2:RM7000 :Octane:2xR10000 :Octane:R12000 :O200: - :O200:2x2xR10000 :Fuel:R16000 :A350:
among more than 150 machines : Apollo, Be, Data General, Digital, HP, IBM, MIPS before SGI, Motorola, NeXT, SGI, Solbourne, Sun...
Unread postPosted: Tue Feb 28, 2012 5:52 am
This is wrong. Or at least it is incomplete.
Changing the scsihostid variable in PROM changes the hostid of the standard onboard scsi controllers.
I added an LSI dual Ultra320 controller to improve the transfer rates of my PowerVault, and it was completely unaffected by the scsihostid variable.
But /var/sysgen/system/irix.sm lists a variety of tunables for the LSI driver ('ls'). One of them is:
Code:
ls_scsi_hostid (valid for controller only)
   (valid range 0-15, default is 0)
The syntax is a little involved, but you can (no, you must) set it per controller, like this
Code:
* Set the SCSI ID to 7 for the LSI dual U320 card to make the PowerVault 220S work
DEVICE_ADMIN: /hw/module/001c01/IXbrick/xtalk/11/pci-x/1/1a/scsi_ctlr/0 ls_scsi_hostid=7
DEVICE_ADMIN: /hw/module/001c01/IXbrick/xtalk/11/pci-x/1/1b/scsi_ctlr/0 ls_scsi_hostid=7
The dual U320 scsi controller shows up in 'hinv' like this:
Code:
Integral SCSI controller 5: Version LS1030, low voltage differential
Integral SCSI controller 6: Version LS1030, low voltage differential
The full device path for controllers 5 & 6 can then be found like this:
Code:
tezro 12# ls -l /hw/scsi_ctlr/
total 0
lrw-------    1 root     sys           57 Feb 28 14:43 0 -> /hw/module/001c01/IXbrick/xtalk/15/pci-x/0/3/scsi_ctlr/0
lrw-------    1 root     sys           57 Feb 28 14:43 1 -> /hw/module/001c01/IXbrick/xtalk/15/pci-x/0/3/scsi_ctlr/1
lrw-------    1 root     sys           57 Feb 28 14:43 2 -> /hw/module/001c01/IXbrick/xtalk/15/pci-x/0/1/scsi_ctlr/0
lrw-------    1 root     sys           58 Feb 28 14:43 3 -> /hw/module/001c01/IXbrick/xtalk/11/pci-x/0/1a/scsi_ctlr/0
lrw-------    1 root     sys           58 Feb 28 14:43 4 -> /hw/module/001c01/IXbrick/xtalk/11/pci-x/0/1b/scsi_ctlr/0
lrw-------    1 root     sys           58 Feb 28 14:43 5 -> /hw/module/001c01/IXbrick/xtalk/11/pci-x/1/1a/scsi_ctlr/0
lrw-------    1 root     sys           58 Feb 28 14:43 6 -> /hw/module/001c01/IXbrick/xtalk/11/pci-x/1/1b/scsi_ctlr/0
lrw-------    1 root     sys           58 Feb 28 14:43 7 -> /hw/module/001c01/IXbrick/xtalk/11/pci-x/1/2a/scsi_ctlr/0
lrw-------    1 root     sys           58 Feb 28 14:43 8 -> /hw/module/001c01/IXbrick/xtalk/11/pci-x/1/2b/scsi_ctlr/0
After a quick '/etc/autoconfig -fv' & reboot, the PowerVault 220S shows up:
Code:
  Disk drive: unit 0 on SCSI controller 5 (unit 0)
  Disk drive: unit 1 on SCSI controller 5 (unit 1)
  Disk drive: unit 2 on SCSI controller 5 (unit 2)
  Disk drive: unit 3 on SCSI controller 5 (unit 3)
  Disk drive: unit 4 on SCSI controller 5 (unit 4)
  Disk drive: unit 5 on SCSI controller 5 (unit 5)
  Scanner: unit 6 on SCSI controller 5
  Disk drive: unit 8 on SCSI controller 5 (unit 8)
  Scanner: unit 6 on SCSI controller 6
  Disk drive: unit 9 on SCSI controller 6 (unit 9)
  Disk drive: unit 10 on SCSI controller 6 (unit 10)
  Disk drive: unit 11 on SCSI controller 6 (unit 11)
  Disk drive: unit 12 on SCSI controller 6 (unit 12)
  Disk drive: unit 13 on SCSI controller 6 (unit 13)
  Disk drive: unit 14 on SCSI controller 6 (unit 14)
  Disk drive: unit 15 on SCSI controller 6 (unit 15)
Notice the disk at SCSI ID 0 on controller 5
Each channel of the Powervault contains a management module which shows up as a scanner in IRIX :roll:
