ID Chip in Fuel
nicte
ID Chip in Fuel
Unread postby nicte » Sun Jan 15, 2012 10:06 am
Does anybody find the place where ID chip in Fuel is located ?
Is it the same chip like on Octane or new one ?
THA
Rr
PymbleSoftware
Re: ID Chip in Fuel
Unread postby PymbleSoftware » Sun Jan 15, 2012 10:42 am
nicte wrote:Does anybody find the place where ID chip in Fuel is located ?
THA
Rr
I have never owned a Fuel but it is large Dallas 1742W. The same as what is in the Origin 300s from what I can tell from this wiki topic...
Something that large would be difficult to not to spot on a board.
R.
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
nicte
Re: ID Chip in Fuel
Unread postby nicte » Sun Jan 15, 2012 11:37 am
Thanks a lot !
I've also found that it's not replaceable with Octane
:^S
pity...
Re: ID Chip in Fuel
Unread postby SAQ » Sun Jan 15, 2012 7:57 pm
I thought I remembered seeing that Fuel used a small encrypted EEPROM for the serial number.
Re: ID Chip in Fuel
Unread postby hamei » Sun Jan 15, 2012 9:15 pm
SAQ wrote:I thought I remembered seeing that Fuel used a small encrypted EEPROM for the serial number.
This is not gospel, it's been quite a while since i had to mess with it, but both of you are right. There's an atmel system i.d. chip over towards the left end of the pci sockets AND apparently the Dallas chip remembers some settings, so when you change i.d.'s it's best to change both, if possible. At least, that was my experience.
nicte
Re: ID Chip in Fuel
Unread postby nicte » Mon Jan 16, 2012 2:33 am
Well, now I have a real mess...
So :
1. there's two chips -Atmel and Dallas
2. which of them carries sys ID : Atmel or Dallas ? Both ??? The same ID ???
3. Which of them can be reprogrammed and how?
Re: ID Chip in Fuel
Unread postby hamei » Mon Jan 16, 2012 4:31 am
nicte wrote:Well, now I have a real mess...
So :
Search for some posts by pinball cf the Atmel. I believe the thread was about fixing the environment sensor chip, which is nearby.
I replaced the mainboard years ago and had to move both. Not sure what that means or if it was a fluke or a screwup on my part, but something to be aware of.
The Atmel cannot be reprogrammed. Don't know about the Dallas. Are you trying to maintain an id for some licensed software ? You can't move both chips over just to be safe ?
Re: ID Chip in Fuel
Unread postby SAQ » Mon Jan 16, 2012 11:00 am
So :
It looks like he's trying to move over from an Octane or other NIC system.
Wasn't there a piece of software around that did a non-permanent change of the serial number after it was loaded into IRIX?
PymbleSoftware
Re: ID Chip in Fuel
Unread postby PymbleSoftware » Mon Jan 16, 2012 12:29 pm
hamei wrote:The Atmel cannot be reprogrammed. Don't know about the Dallas.
FWIW, I believe the Dallas can be reprogrammed. The "fix" for the serial number mismatch issue is to put in a blank Dallas chip in the r-brick and its gets programmed from the L2. But I suspect it might be compressed or encrypted.
I have a spare o3k r-brick programmed with security enforced Dallas chip taped inside the case of the r-brick if its needed.
R.
死の神はりんごだけ食べる
Re: ID Chip in Fuel
Unread postby hamei » Mon Jan 16, 2012 5:35 pm
SAQ wrote:It looks like he's trying to move over from an Octane or other NIC system.
THAT would be difficult.
Yes. Sysid was the name. But it's not persistent .... although not a problem I guess, just load it every time you boot ....
Re: ID Chip in Fuel
Unread postby jan-jaap » Tue Jan 17, 2012 1:41 am
Nobody mentioned the L1 'eeprom Fuel write default' command yet:
001c01-L1>help eeprom
eeprom
        show brick eeprom data.
eeprom <exp> <exp> <exp>
        show brick eeprom data at <eeprom> <offset> <length>.
        write standard Fuel EEPROM data to MAC EEPROM
The Atmel chip is write-once so you can't change ID data stored there. But the day your Dallas chip runs out of battery you may be able to initialize a fresh Dallas using the above command. It will probably use default data and the serial number stored in the Atmel. Fortunately, I didn't need to do this yet so this is all speculation.
If you want to change the MAC address of the system to migrate licensed software, you should google the 'squirrel' method.
nicte
Re: ID Chip in Fuel
Unread postby nicte » Tue Jan 17, 2012 3:34 am
Thanks A LOT...
Re: ID Chip in Fuel
Unread postby hamei » Tue Jan 17, 2012 6:16 am
Just for the future ...
I figure you can identify the Dallas chip all by yourselves :P
hhoffman
Re: ID Chip in Fuel
Unread postby hhoffman » Wed May 03, 2017 9:44 am
Hi there,
I did change the DALLAS Chip on my tezro (o.k. it's not a fuel), it does not start since then. I get now
SGI SN1 L1 Controller
Firmware Image A: Rev. 1.30.11, Built 07/16/2004 07:53:59
001c01-L1>INFO: 001c01 will power up system in 55 seconds...
INFO: 001c01 will power up system in 50 seconds...
INFO: 001c01 will power up system in 45 seconds...
INFO: 001c01 will power up system in 40 seconds...
INFO: 001c01 will power up system in 35 seconds...
INFO: 001c01 will power up system in 30 seconds...
INFO: 001c01 will power up system in 25 seconds...
INFO: 001c01 will power up system in 20 seconds...
INFO: 001c01 will power up system in 15 seconds...
INFO: 001c01 will power up system in 10 seconds...
INFO: 001c01 will power up system in  5 seconds...
INFO: 001c01 powering up the system.
INFO: Cannot enable VRM: 9p error.
INFO: Cannot enable VRM: 10
INFO: Cannot enable VRM: 11
controller firmware panic!   resetting...
IMAGE A: Rev. 1.30.11
[sys stack]
   TR: ffe870cc ffe898a8 ffe877d2 ffe4c2c6 ffe10fd6
   <bad stack FP @ 301017f0 => 20646574>
[thread ID 30006530 stack]
   Bus Error, PC=ffe8fffc
(if you see this, please email ssh@sgi.com and include
 the output from the 'log' command and a description of
 what caused the problem)
I tried
001c01-L1>eeprom Fuel write default
Command not available for this brick type
Any idea what to do now?
Re: ID Chip in Fuel
Unread postby jan-jaap » Thu May 04, 2017 5:06 am
hhoffman wrote:
For as much as I can make any sense of THIS thread, it could be a problem with the graphics board. Or maybe try to reseat the VRMs in the system, with the mods this guys made he could easily have unseated one. Or ask him ...
Users browsing this forum: Ahrefs [Bot] and 4 guests
