It is currently Thu May 23, 2013 4:08 am
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3  Next
Unread postPosted: Thu Jan 12, 2012 5:09 am
... since a memory upgrade - thank's to ramq :) - my tezro constantly crashes after ~4 hours with system panic.
:shock:
in the SYSLOG I get
Code:
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: Serial #: P1000651
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: HARDWARE ERROR STATE:
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +  Errors on node Nasid 0x0 (0)
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +    IP35 in /hw/module/001c01/node [serial number NCG031]
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +      BEDROCK signalled following errors.
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +        ICRB1_A Entry Register: 0x817400ae2227d1
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +          00<->00: IO Write operation
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +          39<->02: SN0Net address 0x2b8889f4
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +          44<->40: TNUM of XTalk req. 0x14
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +          48<->45: SIDN of XTalk req. 0xb
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +          54<->52: CRB error code 0x0
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +          55<->55: CRB has an error
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +        ICRB1_B Entry Register: 0x280302400000000
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +        ICRB4_A Entry Register: 0x817400ae222781
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +          39<->02: SN0Net address 0x2b8889e0
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +        ICRB4_B Entry Register: 0x300304400000000
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +        ICRB7_A Entry Register: 0xf77400ae222741
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +          39<->02: SN0Net address 0x2b8889d0
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +          49<->49: Error set in incoming XTalk request
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +          50<->50: CRB entry has been marked
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +          54<->52: CRB error code 0x7
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +        ICRB7_B Entry Register: 0x300304400000000
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +        ICRB9_A Entry Register: 0x817400ae2227c1
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +          39<->02: SN0Net address 0x2b8889f0
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +        ICRB9_B Entry Register: 0x280302400000000
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +        BEDROCK NI Port Error Register: 0xff
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: +          07<->00: Number of LLP SN errors 0xff
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: End Hardware Error State
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: ++FRU ANALYSIS BEGIN
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: No rules triggered:  Insufficient data
Jan 12 14:35:41 5D:tezro sn0log: Timeout Histogram is empty.
Jan 12 14:35:41 5D:tezro sn0log: A Fatal: ++FRU ANALYSIS END
Jan 12 14:35:41 6D:tezro sn0log: End of flashlog for /hw/module/001c01/node/hub/mon
What could that be?
Unread postPosted: Thu Jan 12, 2012 5:28 am
Did you clean out the sockets, clean the contacts, try moving the sticks around, all that good stuff? I would start with blowing all the dust out and re-plugging every stick, extra firm.
If problems continue, last time I heard of a tezro memory upgrade failing it was because of a VRM pushed beyond it's limits. It could be power related, but normally the diagnostic is smart enough to tell you more-or-less exactly what is failing in the power systems.
:Onyx: (Maradona) :Octane: (DavidVilla) A1186 (Xavi)
A1370 (Messi) dp43tf (Puyol) A1387 (Abidal) A1408 (Guardiola)
"InfiniteReality Graphics - Power Through Complexity"
Unread postPosted: Thu Jan 12, 2012 6:13 am
... well they where cleaned now from dust for several times. I mean both, the sockets and the modules .....
all RAM is showing up at hinv.
Unread postPosted: Thu Jan 12, 2012 6:16 am
When it crash do it call the same dimm "IP35 in /hw/module/001c01/node [serial number NCG031]
I'm assuming that is the DIMM location. If so, as suggested earlier move it around and if crash see if the same serial number or hardware location is reported.
5/11/11 12:58:19 AM gfxCardStatus[268] AMD Radeon HD 6750M in use. Bummer! Less battery life for you.
5/11/11 12:58:20 AM gfxCardStatus[268] Intel HD Graphics 3000 in use. Sweet deal! More battery life.
MacBook Pro 17inch 2011
Mac Mini 2010
Unread postPosted: Thu Jan 12, 2012 7:22 am
hmm, with
/usr/sbin/l1cmd --scdev /hw/module/001c01/L1/controller serial all
I will get:
Code:
NODE        IP53_4CPU       NCG031         030_1868_001          C    00
and
Code:
DIMM 0     CE000000000000000C6E9900 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 2     CE000000000000000CC84D00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 4     CE000000000000000CBB4D00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 6     7F94FFFFFFFFFFFFCE79C80D SM57264DSGI100C2   00FF   8.0  N/A
DIMM 1     CE000000000000000C309D00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 3     CE000000000000000CBF4D00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 5     CE000000000000000CC34D00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 7     CE000000000000000C9CAF00 M3 47L6423DT3-CA0   3D   10.0  N/A
... so it looks more like a cpu problem?
Unread postPosted: Thu Jan 12, 2012 8:00 am
any ideas? also nothing useful (for me) in the controller log:
Code:
/usr/sbin/l1cmd --scdev /hw/module/001c01/L1/controller log
01/11/12 11:32:39 SCC WR 6 (len=97) - UART:UART_TIMEOUT
01/11/12 11:32:41 power up (PANEL)
01/11/12 11:32:45 Node 0 XTalk clock 88
01/11/12 11:32:48 reset again MIPS
01/11/12 11:32:52 Node 0 XTalk clock 88
01/11/12 15:59:46 Power Down: issue 'pwr d' again to immediately power down.
01/11/12 15:59:47 power down (PANEL)
01/11/12 15:59:47 SCC WR 6 (len=97) - UART:UART_TIMEOUT
01/12/12 00:52:41 L1 booting 1.30.11
01/12/12 00:52:43 USB0: waiting on open
01/12/12 01:40:24 L1 booting 1.30.11
01/12/12 01:40:27 USB0: waiting on open
01/12/12 01:40:56 power up (PANEL)
01/12/12 01:41:01 Node 0 XTalk clock 88
01/12/12 01:41:03 reset again MIPS
01/12/12 01:41:06 Cooling system stabilized
01/12/12 01:41:07 Node 0 XTalk clock 88
01/12/12 05:53:19 Power Down: issue 'pwr d' again to immediately power down.
01/12/12 05:53:20 SCC WR 6 (len=97) - UART:UART_TIMEOUT
01/12/12 05:55:44 power down (PANEL)
01/12/12 05:55:45 power up (PANEL)
01/12/12 05:55:50 Node 0 XTalk clock 88
01/12/12 05:55:52 reset again MIPS
01/12/12 05:55:57 Node 0 XTalk clock 88
01/12/12 08:16:55 Power Down: issue 'pwr d' again to immediately power down.
01/12/12 08:16:56 SCC WR 6 (len=97) - UART:UART_TIMEOUT
01/12/12 08:16:57 power down (PANEL)
01/12/12 08:18:47 L1 booting 1.30.11
01/12/12 08:18:49 USB0: waiting on open
01/12/12 08:19:02 power up (PANEL)
01/12/12 08:19:07 Node 0 XTalk clock 88
01/12/12 08:19:09 Cooling system stabilized
01/12/12 08:19:09 reset again MIPS
01/12/12 08:19:14 Node 0 XTalk clock 88
01/12/12 08:37:12 Power Down: issue 'pwr d' again to immediately power down.
01/12/12 08:37:13 power down (PANEL)
01/12/12 08:37:13 SCC WR 6 (len=97) - UART:UART_TIMEOUT
01/12/12 08:45:58 L1 booting 1.30.11
01/12/12 08:46:00 USB0: waiting on open
01/12/12 08:46:51 power up (PANEL)
01/12/12 08:46:56 Node 0 XTalk clock 88
01/12/12 08:46:58 reset again MIPS
01/12/12 08:47:00 Cooling system stabilized
01/12/12 08:47:02 Node 0 XTalk clock 88
tezro chrashed again. I removed now all new memory modules.
Unread postPosted: Thu Jan 12, 2012 9:13 am
... still no luck with removing all *new* RAM modules, the system is still crashing (with panic).
:cry:
any ideas?
Unread postPosted: Thu Jan 12, 2012 9:59 am
I'm going to guess that CPU /hw/module/001c01/node [serial number NCG031 caught the error and reported it. I will look at "DIMM 6 7F94FFFFFFFFFFFFCE79C80D SM57264DSGI100C2 00FF 8.0 N/A " as being suspect. It don't match the rest. Different Speed. If you had another then you could have paired it off.
Try removing it and see how the system run. Take a look at it also see if it physically different.
Mac Mini 2010
Unread postPosted: Thu Jan 12, 2012 10:07 am
that printout came from a reinstall of the *old* 512 modules. This is the actual printout in the moment:
Code:
DIMM 2     CE000000000000000CBB4D00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 4     CE000000000000000CBF4D00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 6     CE000000000000000CD74D00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 3     CE000000000000000CC84D00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 7     CE000000000000000CD34D00 M3 46L2820DT2-CA0   2D   10.0  N/A
Unread postPosted: Thu Jan 12, 2012 10:53 am
does anyone know where the runalldiags script went in irix 6.5.28?
Unread postPosted: Thu Jan 12, 2012 2:23 pm
Doesn't look like you've found a ready solution. I'd suggest some basic diagnostic troubleshooting to see if you can narrow down cause and effect.
First, a little additional background info might be helpful. Could you post an hinv -vm, an L1 serial all, and an L1 pci? (before and after your recent upgrade if they're available)
Then I'd recommend reducing your Tezro to a minimal configuration, if it runs in that configuration without generating the crash/panic, re-add the components one at a time to see if the re-installation of any particular item(s) case the problem to reappear.
So, remove:
  • All PCI boards,
  • All but the memory in the first bank (two DIMMs),
  • the DM3
  • the secondary hard drive (unit 2 in your hinv)
Boot the system, stop in the PROM, and clear the Power-on Diagnostics (POD) logs (so you don't propagate existing diagnostic failures). To access POD mode, stop at the PROM command line (item 5 in the PROM menu list), and sequentially run the following commands from the command line:
  • pod
  • go cac
  • log <Note: I'd suggest recording the output of the pod log command>
  • clearalllogs
  • initalllogs
  • flush
  • reset (the system will restart)
After the system restarts, go back into the PROM monitor and execute:
  • update
Then boot the system and test to see if the panic re-occurs.
Unread postPosted: Fri Jan 13, 2012 2:18 am
when I cal pod from the command line in the PROM, nothing happens ....
:roll:
Meanwhile I have a nullmodemcable, but not a genderchanger to connect the console port of the tezro to the serial port of an o2. Is there somewhere a wiki about how to 'talk' to the tezro L1 from another irix workstation?
Or maybe a wiki, how to connect from linux through the usb L1 connector?
How do I find faulty memory modules?
well that is the system:
Code:
       IP53_4CPU Board: barcode NCG031     part 030-1868-001 rev -C
       WS_INT_53 Board: barcode NBY613     part 030-1881-006 rev -A
      ODY128B1_2 Board: barcode MZD531     part 030-1884-004 rev -D
       XT-DIGVID Board: barcode NCB425     part 030-1927-003 rev  B
             IO9 Board: barcode NAF962     part 030-1771-005 rev -A
     PCI_SIO_UFC Board: barcode MYS662     part 030-1657-003 rev  A
4 700 MHZ IP35 Processors
  Processor revision: 2.1. Scache: Size 4 MB Speed 350 Mhz  Tap 0xc
CPU 1 at Module 001c01/Slot 0/Slice B: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 700 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 8192 Mbytes
Integral SCSI controller 3: Version Fibre Channel QL2342 Port 1, 133 MHz PCI-X
  Disk drive: unit 0 on SCSI controller 3 (unit 0)
  Disk drive: unit 1 on SCSI controller 3 (unit 1)
  Disk drive: unit 2 on SCSI controller 3 (unit 2)
  Disk drive: unit 3 on SCSI controller 3 (unit 3)
  Disk drive: unit 4 on SCSI controller 3 (unit 4)
  Disk drive: unit 5 on SCSI controller 3 (unit 5)
  Disk drive: unit 6 on SCSI controller 3 (unit 6)
  Disk drive: unit 7 on SCSI controller 3 (unit 7)
  Disk drive: unit 8 on SCSI controller 3 (unit 8)
  Disk drive: unit 9 on SCSI controller 3 (unit 9)
  Disk drive: unit 10 on SCSI controller 3 (unit 10)
  Disk drive: unit 11 on SCSI controller 3 (unit 11)
  Disk drive: unit 12 on SCSI controller 3 (unit 12)
  Disk drive: unit 13 on SCSI controller 3 (unit 13)
  Disk drive: unit 14 on SCSI controller 3 (unit 14)
Integral SCSI controller 4: Version Fibre Channel QL2342 Port 2, 133 MHz PCI-X
  Disk drive: unit 0 on SCSI controller 4 (unit 0)
  Disk drive: unit 1 on SCSI controller 4 (unit 1)
  Disk drive: unit 2 on SCSI controller 4 (unit 2)
  Disk drive: unit 3 on SCSI controller 4 (unit 3)
  Disk drive: unit 4 on SCSI controller 4 (unit 4)
  Disk drive: unit 5 on SCSI controller 4 (unit 5)
  Disk drive: unit 6 on SCSI controller 4 (unit 6)
  Disk drive: unit 7 on SCSI controller 4 (unit 7)
  Disk drive: unit 8 on SCSI controller 4 (unit 8)
  Disk drive: unit 9 on SCSI controller 4 (unit 9)
  Disk drive: unit 10 on SCSI controller 4 (unit 10)
  Disk drive: unit 11 on SCSI controller 4 (unit 11)
  Disk drive: unit 12 on SCSI controller 4 (unit 12)
  Disk drive: unit 13 on SCSI controller 4 (unit 13)
  Disk drive: unit 14 on SCSI controller 4 (unit 14)
Integral SCSI controller 5: Version Fibre Channel QL2342 Port 1, 133 MHz PCI-X
Integral SCSI controller 6: Version Fibre Channel QL2342 Port 2, 133 MHz PCI-X
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
Graphics board: V12
Gigabit Ethernet: tg1, module 001c01, PCI bus 3 slot 1 port 0
Gigabit Ethernet: tg2, module 001c01, PCI bus 3 slot 1 port 1
Iris Audio Processor: version RAD revision 13.0, number 1
  PCI Adapter ID (vendor 0x1077, device 0x2312) PCI slot 1
  PCI Adapter ID (vendor 0x14e4, device 0x1648) PCI slot 1
  PCI Adapter ID (vendor 0x1077, device 0x2312) PCI slot 2
  PCI Adapter ID (vendor 0x104c, device 0xac28) PCI slot 2
  PCI Adapter ID (vendor 0x10a9, device 0x0005) PCI slot 1
IOC4 firmware revision 79
Dual Channel Display
and
Code:
Local System Serial Number      NVRAM         P1000651
Reference System Serial Number  NVRAM         P1000651
Local Brick Serial Number       EEPROM        NBY613
Reference Brick Serial Number   NVRAM         NBY613
INTERFACE   WS_INT_53       NBY613         030_1881_006          A    00
IO9         IO9             NAF962         030_1771_005          A    00
ODYSSEY     ODY128B1_2      MZD531         030_1884_004          D    00
SNOWBALL    SNOWBALL_EDGE   NCB425         030_1927_003          B    00
IO DGHTR    CHWS_IO_DAUG    NAM759         030_1875_003          A    00
and
Code:
Bus Slot Slot Stat Bus Stat  Power Mode/Speed
  1    1 0x80 0x01      0x04   15W PCI  66MHz
  2    1 0x00 0x00      0x02  7.5W PCI  33MHz
  2    2 0x00 0x00      0x02  7.5W PCI  33MHz
  2    3 0x00 0x0f      0x02  none PCI  33MHz
  3    1 0x00 0x0d      0x2c   15W PCIX 133MHz
  3    2 0x00 0x0d      0x2c   15W PCIX 133MHz
  4    1 0x00 0x0d      0x6c   15W PCIX 133MHz
  4    2 0x00 0x0f      0x6c  none PCIX 133MHz
Unread postPosted: Fri Jan 13, 2012 2:39 pm
hhoffman wrote:
Meanwhile I have a nullmodemcable, but not a genderchanger to connect the console port of the tezro....
That should be cheap (and easy) to solve.
As guardian452 mentioned, there's already been a tezro-with-issues thread that ended up being attributed to the power draw on the system. Yours looks pretty heavily loaded - probably more so than the one in the other thread. You might indeed have faulty memory, but it might also be possible that maxing out your Tezro's memory caused just enough additional power load to cause problems.
If that's the case, hopefully no permanent damage was done. Testing your system with a minimal configuration and working your way back towards your original config will probably tell the story.
Considering your mention that your Tezro would crash after approximately four hours of use, there's also the possibility the additional load might raised the temperature on some of the internal components just enough to cause heat-related issues. That superficially fits with your Bedrock ASIC being prominently mentioned in the error log you posted - the Bedrock is usually the hottest running part of a Tezro. As you start the add-to-the-minimal-config troubleshooting process, during each step I'd suggest allowing your Tezro to run as long as it took for it to crash before, and then record the output of an L1 env so you can see what effect adding additional load has on system temperatures (and stability).
Unread postPosted: Sun Jan 15, 2012 6:42 am
ok, meanwhile I got a genderchanger and can now connect on o2 (/dev/ttyd1) to the console port of the tezro. What's next? How will I get the L1 env output of the tezro displayed on the o2?
Thank you for yor help, recondas!
:D
Unread postPosted: Sun Jan 15, 2012 8:08 am
... btw, the tezro is now running for 4:30 with full setup and 8GB RAM in idle mode without crash.
:roll:
Users browsing this forum: Bing [Bot] and 3 guests
