Fuel V10 EEPROM 'disassembly'
Unread postby jan-jaap » Wed Nov 23, 2011 5:27 am
Since there's some interest out there to hack late revision V10 cards into V12's, let me share my knowledge of the EEPROM contents. I personally have no real interest in pursuing this but maybe someone else will take it from here.
Have a look at the L1 output:
# l1cmd serial all
Local System Serial Number      EEPROM        08:00:69:0B:C3:C2
Local Brick Serial Number       EEPROM        MED907
Reference Brick Serial Number   NVRAM         MED907
NODE        IP34            MED907         030_1707_002          D    00
MAC         MAC ADDRESS     NA             NA                    NA   NA
PIMM        IP34PIMM        MDG739         030_1708_002          G    00
XIO         ASTODYB         MDG840         030_1725_001          D    00
DIMM 0     CE0000000000000026BAAE00 M3 46L3313BT1-CA0   0B   10.0  N/A
DIMM 2     CE0000000000000026C3AE00 M3 46L3313BT1-CA0   0B   10.0  N/A
DIMM 1     CE0000000000000028C12601 M3 46L3313BT1-CA0   0B   10.0  N/A
DIMM 3     CE00000000000000269CF500 M3 46L3313BT1-CA0   0B   10.0  N/A
So, this V10 board has
Product name: ASTODYB
Serial        MDG840
Part Number   030_1725_001
Rev           D
T/W           0
(no idea what the T/W is)
The L1 'eeprom' command will dump the contents of one (or all) eeproms in the system. On my Fuel V10 (the blue one), it looks like this:
# l1cmd eeprom
NODE (CH)
00 20 01 06 00 00 00 d9
NODE (CIA)
00 02 17 c2 4e 41 c2 4e 41 c1 00 00 00 00 00 84
NODE (BIA)
00 09 00 d7 c2 2f c9 43 45 4c 45 53 54 49 43 41
c4 49 50 33 34 c6 4d 45 44 39 30 37 cc 30 33 30
5f 31 37 30 37 5f 30 30 32 00 c2 5f 44 01 02 c2
30 30 04 00 00 59 45 04 00 00 00 02 04 00 00 4c
cf c1 00 00 00 00 00 49
NODE (PIA), no data available (1)
NODE (IUA)
00 01 30 01 00 03 00 00 00 00 00 08 00 01 00 0c
0b 45 01 03 00 20 1f 00 01 02 03 4a 00 03 4a 06
50 26 06 3f fc 06 3f b7 06 08 88 06 02 46 06 00
ec 18 00 6b 00 00 00 74
MAC (CH)
00 00 01 03 00 00 00 fc
MAC (CIA)
MAC (BIA)
00 0b 00 00 00 00 c2 4e 41 cb 4d 41 43 20 41 44
44 52 45 53 53 c6 4e 41 20 20 20 20 cc 4e 41 20
20 20 20 20 20 20 20 20 20 00 c2 4e 41 01 02 c2
4e 41 04 ff ff ff ff 04 ff ff ff ff 04 ff ff ff
ff cc 30 38 30 30 36 39 30 42 43 33 43 32 00 c1
00 00 00 00 00 00 00 ac
MAC (PIA), no data available (1)
MAC (IUA), no data available (1)
PIMM (CH)
00 20 00 01 00 00 00 df
PIMM (CIA), no data available (1)
PIMM (BIA)
00 07 00 59 a1 2f c9 43 45 4c 45 53 54 49 43 41
c8 49 50 33 34 50 49 4d 4d c6 4d 44 47 37 33 39
cc 30 33 30 5f 31 37 30 38 5f 30 30 32 00 c2 5f
47 01 02 c2 30 30 c1 71
PIMM (PIA), no data available (1)
PIMM (IUA)
00 01 60 01 00 01 00 04 00 14 00 2e 00 2e 00 3e
00 4a 00 4a 00 4a 00 4a 00 4a 00 4a 00 4a 00 4a
00 3e 00 4a 00 4a 00 4a 00 4a 00 4a 00 4a 00 4a
00 4a 04 44 01 00 00 00 0f 00 01 01 01 70 00 01
70 00 04 03 01 01 20 07 01 00 46 00 46 00 04 03
01 01 20 07 01 00 33 00 33 00 00 00 00 00 00 00
00 00 00 00 00 00 00 7d
XIO (CH)
XIO (CIA), no data available (1)
XIO (BIA)
00 09 00 00 25 2f c9 53 4f 4c 45 43 54 52 4f 4e
c7 41 53 54 4f 44 59 42 c6 4d 44 47 38 34 30 cc
30 33 30 5f 31 37 32 35 5f 30 30 31 00 c2 5f 44
01 02 c2 30 30 04 00 00 4c 07 04 00 00 00 02 04
00 00 42 16 c1 00 00 89
XIO (PIA), no data available (1)
XIO (IUA)
00 01 33 01 01 01 01 04 01 06 03 00 09 02 0f 01
13 01 16 01 19 01 24 00 00 00 00 00 00 04 03 01
01 20 07 01 05 ff 00 ff 04 42 01 01 00 20 03 00
01 02 01 4f 00 01 4f f4
DIMM 0 (JEDEC-SPD)
80 08 07 0c 0a 02 48 00 04 a0 80 02 80 08 08 01
0e 04 0c 01 02 26 00 00 00 00 00 50 3c 50 30 20
b0 b0 60 60 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 39
ce 00 00 00 00 00 00 00 01 4d 33 20 34 36 4c 33
33 31 33 42 54 31 2d 43 41 30 20 30 42 07 01 26
ba ae 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM 2 (JEDEC-SPD)
c3 ae 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM 1 (JEDEC-SPD)
33 31 33 42 54 31 2d 43 41 30 20 30 42 14 01 28
c1 26 01 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM 3 (JEDEC-SPD)
33 31 33 42 54 31 2d 43 41 30 20 30 42 10 01 26
9c f5 00 00 57 4d 43 31 42 30 30 00 00 00 00 00
fuel 2#
This part is definitely my V10:
XIO (BIA)
My V10 has barcode MGD480, or hex 4d 47 44 34 38 30 (some bytes are swapped)
It is product name ASTODYB, or 41 53 54 4f 44 59 42
<speculation mode on>both strings are prefixed by hex cN, where N is the length. Scroll back a little and there's c9 + 9 bytes: c9 53 4f 4c 45 43 54 52 4f 4e, or SOLECTRON, the manufacturer!
Next up: cc + 12 bytes: cc 30 33 30 5f 31 37 32 35 5f 30 30 31 => "030_1725_001" (the part#)
A '\00', which we shall ignore.
c2 + 2 bytes: c2 5f 44 => "_D" (the rev.)
A '\01' '\02' which we ignore again 8-)
c2 + 2 bytes: c2 30 30 => "00" (the T/W)
Now, the L1 has an undocumented command 'eeprom fill'. I have never tried it for obvious reasons, but if you want to change the contents of your EEPROM, this may be a start :twisted:
There's another EEPROM on the card, identified as "XIO (IUA)". Who knows what's to be found there. There may or may not be a CRC on these EEPROMs.
Happy hacking! Please remember, I am *not* responsible for your bricked VPro card, nor a sudden surge of hacked V12's ;)
Re: Fuel V10 EEPROM 'disassembly'
Unread postby recondas » Wed Nov 23, 2011 6:55 am
Thanks j-j!
If some one wants to compare the differences, here's the eeprom dump for the each of the Fuel V12s in my 'graphics-added' O350:
#1
Serial        MLV203
Part Number   030_1726_003
Rev           E
T/W           00
ODYSSEY (CH)
ODYSSEY (CIA), no data available (1)
ODYSSEY (BIA)
00 09 00 9b 57 33 c9 53 4f 4c 45 43 54 52 4f 4e
c6 41 53 54 4f 44 59 c6 4d 4c 56 32 30 33 cc 30
33 30 5f 31 37 32 36 5f 30 30 33 00 c2 5f 45 01
02 c2 30 30 04 ff ff ff ff 04 ff ff ff ff 04 ff
ff ff ff c1 00 00 00 a0
ODYSSEY (PIA), no data available (1)
ODYSSEY (IUA)
#2
Serial        MYA424
Part Number   030_1726_005
Rev           A
T/W           0
ODYSSEY (CH)
ODYSSEY (BIA)
00 09 00 62 53 40 c9 53 4f 4c 45 43 54 52 4f 4e
c6 41 53 54 4f 44 59 c6 4d 59 41 34 32 34 cc 30
33 30 5f 31 37 32 36 5f 30 30 35 00 c2 5f 41 01
ff ff ff c1 00 00 00 d5
ODYSSEY (IUA)
00 02 33 01 01 01 01 04 01 06 03 00 09 02 0f 01
01 02 01 4f 00 01 4f f3
#1 de-hexed in a similar fashion to what jan-jaap did with the V10 data in his post:
cc 30 33 30 5f 31 37 32 36 5f 30 30 33 = 030_1726_003 (part number)
c9 53 4f 4c 45 43 54 52 4f 4e = SOLECTRON (manufacturer)
c6 41 53 54 4f 44 59 = ASTODY (product name)
c6 4d 4c 56 32 30 33 = MLV203 (bar code)
c2 30 30  =  00 (T/W)
c2 5f 45  =  _E (revision code)
jan-jaap wrote:There's another EEPROM on the card, identified as "XIO (IUA)". Who knows what's to be found there.
The "CH" and "IUA" segments appear to be identical between your V10 and and the first V12, but there are differences between the IUA segments of the two V12s.
Unread postby foetz » Sat Apr 27, 2013 1:34 pm
coming from viewtopic.php?f=3&t=16725878&p=7359377#p7359377 here's the dump of my "exotic" v12:
ODYSSEY (CH)
ODYSSEY (BIA)
00 09 00 33 3d 43 c9 43 45 4c 45 53 54 49 43 41
c6 41 53 54 4f 44 59 c6 4d 4d 50 32 38 33 cc 30
33 30 5f 31 39 39 36 5f 30 30 31 00 c2 5f 41 01
02 c2 30 30 c1 00 00 00 c7 04 00 00 28 bb 04 00
00 00 02 04 00 00 11 6f
ODYSSEY (IUA)
00 03 33 01 01 01 01 04 01 06 03 00 09 02 0f 01
01 02 01 4f 00 01 4f f2
translators welcome :P
canavan
Unread postby canavan » Sun Apr 28, 2013 8:39 am
# l1cmd serial all
Local System Serial Number      NVRAM         P1003724
Reference System Serial Number  NVRAM         P1003724
Local Brick Serial Number       EEPROM        NTX614
Reference Brick Serial Number   NVRAM         NTX614
INTERFACE   WS_INT_53       NTX614         030_1881_007          A    00
IO9         IO9             NVZ751         030_1771_005          B    00
ODYSSEY     ODY128B1_2      NTX597         030_1884_005          B    00
SNOWBALL    SNOWBALL_EDGE   NBL538         030_1927_003          B    00
NODE        IP59_4CPU       NTR758         030_1989_003          C    00
IO DGHTR    CHWS_IO_DAUG    NTX842         030_1875_003          A    00
DIMM 0     7F94FFFFFFFFFFFFB30B680D SM57228DSGI100C2   00FF   8.0  N/A
DIMM 2     7F94FFFFFFFFFFFF5548501D SM57228DSGI100C2   00FF   8.0  N/A
DIMM 4     CE000000000000000CB84D00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 6     CE0000000000000027AA2E00 M3 46L2820BT1-CA0   0B    8.0  N/A
DIMM 1     7F94FFFFFFFFFFFFD548501D SM57228DSGI100C2   00FF   8.0  N/A
DIMM 3     7F94FFFFFFFFFFFF9548501D SM57228DSGI100C2   00FF   8.0  N/A
DIMM 5     CE000000000000000CB34D00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 7     CE0000000000000028561500 M3 46L2820BT1-CA0   0B    8.0  N/A
# /usr/gfx/gfxinfo
        Managed (":0.0") 1920x1200
        BUZZ version B.2
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
        Dual Channel Display option
         Monitor 1 type: ENC 8512        Monitor 2 type: Unknown
         Video Output: 1920 pixels, 1200 lines, 60.00Hz (1920x1200_60p)
# l1cmd eeprom
INTERFACE (CH)
INTERFACE (CIA)
INTERFACE (BIA)
00 09 00 5f 11 4f c9 53 4f 4c 45 43 54 52 4f 4e
c9 57 53 5f 49 4e 54 5f 35 33 c6 4e 54 58 36 31
34 cc 30 33 30 5f 31 38 38 31 5f 30 30 37 00 c2
5f 41 01 02 c2 30 30 04 00 00 3d b5 04 00 00 00
02 04 00 00 2c f3 c1 ea
INTERFACE (PIA), no data available (1)
INTERFACE (IUA)
IO9 (CH)
IO9 (CIA), no data available (1)
IO9 (BIA)
00 07 00 ae 8f 4f c9 53 4f 4c 45 43 54 52 4f 4e
c3 49 4f 39 c6 4e 56 5a 37 35 31 cc 30 33 30 5f
31 37 37 31 5f 30 30 35 00 c2 5f 42 01 02 c2 30
30 c1 00 00 00 00 00 2b
IO9 (PIA), no data available (1)
IO9 (IUA), no data available (1)
ODYSSEY (CH)
ODYSSEY (BIA)
00 0a 00 ad fc 4e c9 53 4f 4c 45 43 54 52 4f 4e
ca 4f 44 59 31 32 38 42 31 5f 32 c6 4e 54 58 35
39 37 cc 30 33 30 5f 31 38 38 34 5f 30 30 35 00
c2 5f 42 01 02 c2 30 30 04 ff ff ff ff 04 ff ff
ff ff 04 ff ff ff ff c1 00 00 00 00 00 00 00 f3
ODYSSEY (IUA)
SNOWBALL (CH)
00 00 00 01 00 00 00 ff
SNOWBALL (CIA), no data available (1)
SNOWBALL (BIA)
00 08 00 bf 56 3f c9 43 45 4c 45 53 54 49 43 41
cd 53 4e 4f 57 42 41 4c 4c 5f 45 44 47 45 c6 4e
42 4c 35 33 38 cc 30 33 30 5f 31 39 32 37 5f 30
30 33 00 c2 5f 42 01 02 c2 30 30 c1 00 00 00 9d
SNOWBALL (PIA), no data available (1)
SNOWBALL (IUA), no data available (1)
NODE (CH)
NODE (CIA)
NODE (BIA)
02 0f 00 d3 2e 4f c9 53 4f 4c 45 43 54 52 4f 4e
c9 49 50 35 39 5f 34 43 50 55 c6 4e 54 52 37 35
38 cc 30 33 30 5f 31 39 38 39 5f 30 30 33 00 c2
5f 43 01 02 c2 30 30 01 03 04 ff ff ff ff 04 6a
ed b3 85 04 ff ff ff ff 04 ff ff ff ff 04 ff ff
ff ff 04 00 00 00 c8 04 00 00 03 e8 c6 36 5f 35
5f 32 30 c6 36 5f 5f 31 33 32 c7 31 5f 32 36 5f
30 35 c1 00 00 00 00 29
NODE (IUA)
00 01 85 01 01 01 02 04 00 00 01 08 04 00 0b 02
13 0a 17 02 2b 04 2f 01 3b 01 3b 01 4a 01 4a 01
4a 01 4a 01 4a 01 4a 01 4a 01 4a 01 4a 01 4a 01
55 01 76 00 2c a0 00 2d a0 00 2e a0 00 2f a0 04
44 01 00 00 00 0f 00 01 01 01 70 00 01 70 04 03
01 01 20 07 01 00 44 00 44 0a 45 01 03 00 20 1f
00 01 02 03 4a 00 03 4a 06 50 26 06 3f fc 06 3f
b7 06 08 88 06 02 46 06 00 ec 04 43 01 03 00 20
07 00 01 02 02 73 00 02 73 00 00 00 00 00 00 48
DIMM 0 (JEDEC-SPD)
80 08 07 0d 0b 02 48 00 04 80 80 02 82 04 04 01
0e 04 0c 01 02 26 c0 a0 80 00 00 50 50 50 32 80
75 b0 60 60 00 00 00 00 00 50 50 3c 3c 75 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 bd
7f 94 ff ff ff ff ff ff 01 53 4d 35 37 32 32 38
44 53 47 49 31 30 30 43 32 20 20 00 ff 05 46 b3
0b 68 0d 53 4d 41 52 54 4d 6f 64 75 6c 61 72 54
65 63 68 6e 6f 6c 6f 67 69 65 73 ff ff ff ff ff
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
DIMM 2 (JEDEC-SPD)
44 53 47 49 31 30 30 43 32 20 20 00 ff 05 46 55
48 50 1d 53 4d 41 52 54 4d 6f 64 75 6c 61 72 54
DIMM 4 (JEDEC-SPD)
80 08 07 0d 0b 02 48 00 04 a0 80 02 82 04 04 01
0e 04 0c 01 02 26 00 00 00 00 00 50 3c 50 30 80
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 95
ce 00 00 00 00 00 00 00 01 4d 33 20 34 36 4c 32
38 32 30 44 54 32 2d 43 41 30 20 32 44 03 17 0c
b8 4d 00 00 57 4d 43 31 43 30 38 00 00 00 00 00
DIMM 6 (JEDEC-SPD)
0e 04 0c 01 02 26 00 a0 80 00 00 50 3c 50 30 80
38 32 30 42 54 31 2d 43 41 30 20 30 42 16 01 27
aa 2e 00 00 57 4d 42 30 34 30 47 00 00 00 00 00
DIMM 1 (JEDEC-SPD)
44 53 47 49 31 30 30 43 32 20 20 00 ff 05 46 d5
DIMM 3 (JEDEC-SPD)
44 53 47 49 31 30 30 43 32 20 20 00 ff 05 46 95
DIMM 5 (JEDEC-SPD)
b3 4d 00 00 57 4d 43 31 43 30 38 00 00 00 00 00
DIMM 7 (JEDEC-SPD)
38 32 30 42 54 31 2d 43 41 30 20 30 42 14 01 28
56 15 00 00 57 38 43 32 32 30 47 00 00 00 00 00
IO DGHTR (CH)
IO DGHTR (CIA), no data available (1)
IO DGHTR (BIA)
00 08 00 fa 1d 4f c9 53 4f 4c 45 43 54 52 4f 4e
cc 43 48 57 53 5f 49 4f 5f 44 41 55 47 c6 4e 54
58 38 34 32 cc 30 33 30 5f 31 38 37 35 5f 30 30
33 00 c2 5f 41 01 02 c2 30 30 c1 00 00 00 00 6d
IO DGHTR (PIA), no data available (1)
IO DGHTR (IUA), no data available (1)
V10
# l1cmd serial all
Local System Serial Number      EEPROM        08:00:69:10:40:CA
Local Brick Serial Number       EEPROM        MNV672
Reference Brick Serial Number   NVRAM         MNV672
NODE        IP34            MNV672         030_1707_003          H    00
PIMM        IP34PIMM        MNT693         030_1730_001          G    00
XIO         ASTODYB                        030_1725_001          F    00
DIMM 0     CE00000000000000274F1C00 M3 46L6510BT1-CA0   0B   10.0  N/A
DIMM 2     CE0000000000000027B52A00 M3 46L6510BT1-CA0   0B   10.0  N/A
DIMM 1     CE0000000000000027A50F00 M3 46L6510BT1-CA0   0B   10.0  N/A
DIMM 3     CE0000000000000027C82A00 M3 46L6510BT1-CA0   0B   10.0  N/A
# /usr/gfx/gfxinfo
        BUZZ version B.1
        PB&J version 1
        32MB memory
                Banks: 2, CAS latency: 3
         Monitor 0 type: MDP 4192
l1cmd eeprom
NODE (CH)
NODE (CIA)
NODE (BIA)
00 09 00 7e 21 35 c9 53 4f 4c 45 43 54 52 4f 4e
c4 49 50 33 34 c6 4d 4e 56 36 37 32 cc 30 33 30
5f 31 37 30 37 5f 30 30 33 00 c2 5f 48 01 02 c2
30 30 04 ff ff ff ff 04 ff ff ff ff 04 ff ff ff
ff c1 00 00 00 00 00 b9
NODE (IUA)
00 03 30 01 00 03 00 00 00 00 00 08 00 01 00 0c
ec 18 00 6b 00 00 00 72
MAC (CH)
MAC (CIA)
MAC (BIA)
ff cc 30 38 30 30 36 39 31 30 34 30 43 41 00 c1
00 00 00 00 00 00 00 c0
PIMM (CH)
PIMM (BIA)
00 07 00 46 3d 35 c9 53 4f 4c 45 43 54 52 4f 4e
c8 49 50 33 34 50 49 4d 4d c6 4d 4e 54 36 39 33
cc 30 33 30 5f 31 37 33 30 5f 30 30 31 00 c2 5f
47 01 02 c2 30 30 c1 a6
PIMM (IUA)
00 03 60 01 00 01 00 04 00 14 00 2e 00 2e 00 3e
00 00 00 00 00 00 00 7b
XIO (CH)
XIO (BIA)
00 09 00 89 61 32 c9 53 4f 4c 45 43 54 52 4f 4e
c7 41 53 54 4f 44 59 42 c6 00 00 00 00 00 00 cc
30 33 30 5f 31 37 32 35 5f 30 30 31 00 c2 5f 46
01 02 c2 30 30 04 ff ff ff ff 04 ff ff ff ff 04
ff ff ff ff c1 00 00 ec
XIO (IUA)
DIMM 0 (JEDEC-SPD)
80 08 07 0c 0b 02 48 00 04 a0 80 02 80 04 04 01
0e 04 0c 01 02 26 00 00 00 00 00 50 3c 50 30 40
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 52
ce 00 00 00 00 00 00 00 01 4d 33 20 34 36 4c 36
35 31 30 42 54 31 2d 43 41 30 20 30 42 03 01 27
4f 1c 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM 2 (JEDEC-SPD)
35 31 30 42 54 31 2d 43 41 30 20 30 42 05 01 27
b5 2a 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM 1 (JEDEC-SPD)
a5 0f 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM 3 (JEDEC-SPD)
c8 2a 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A broken V12 030_1996_001. If anyone wants to try soldering the eeproms from this board to a 128MB V10, it's available for the cost of shipping - or in exchange for a V12ified V10...
# /usr/gfx/gfxinfo
        BUZZ version B.1
        PB&J version 1
        128MB memory
# l1cmd serial all
XIO         ASTODY          MNV119         030_1996_001          A    00
# l1cmd eeprom
NODE (CH)
NODE (CIA)
NODE (BIA)
NODE (IUA)
MAC (CH)
MAC (CIA)
MAC (BIA)
PIMM (CH)
PIMM (BIA)
PIMM (IUA)
XIO (CH)
XIO (BIA)
00 09 00 af 83 44 c9 43 45 4c 45 53 54 49 43 41
c6 41 53 54 4f 44 59 c6 4d 4e 56 31 31 39 cc 30
02 c2 30 30 04 00 00 05 77 04 00 00 00 02 04 00
00 01 72 c1 00 00 00 73
XIO (IUA)
Unread postby jan-jaap » Sun Apr 28, 2013 11:13 am
canavan wrote:
If that one is yours: congrats. The 4x1GHz Tezro is about as good as it gets :)
Looks like this one?
canavan
Unread postby canavan » Wed May 01, 2013 2:31 pm
jan-jaap wrote:Looks like this one?
No, it doesn't look like a deskside Onyx2. I thought you'd know that...
Unread postby jan-jaap » Thu May 02, 2013 12:36 am
canavan wrote:No, it doesn't look like a deskside Onyx2. I thought you'd know that...
copy-paste fail :oops: Let me try again: viewtopic.php?f=14&t=12569 ?
Both are purple and highly desirable, though :mrgreen:
kubatyszko
Unread postby kubatyszko » Sun Jan 04, 2015 7:02 am
Hey guys,
I finally had some time to play with the EEPROM's, V10's and a V12.
I have 2 older rev V10's (the 32MB ones), 3 new rev V10's (the 128MB ones), and one V12 (broken - it boots and works, but anything heavier on the display and it freezes the whole system - doesn't even give me POD).
I carefully inspected the boards, and found 2 chips of interest:
Atmel 24C04 I2C EEPROM
Dallas (maxim) 2505 1-wire (with EEPROM)
Interestingly, the cards have pin headers that correspond to those chips - there's a 8-pin header (near the edge connector) wired into eeprom 1:1, 2:2 ... 8:8 etc. (pin number to pin number, NOT in the same order as the chip itself)
and a 2-pin header wired into dallas chip - here the pins are reversed, 1:2 and 2:1 (other 4 pins on the 6-pin dallas are not connected and not used).
I played *a lot* with eeprom reading and flashing (easy), and even after flashing V12's eeprom onto V10's eeprom - the V10 is still a 32MB V10.
What is very interesting, is that the "l1cmd eeprom" DOES NOT show full eeprom contents, it shows the portion directly AFTER whatever checksum and header there is (skipping the first 8-16 bytes or so),
if the checksum is incorrect, everything will still work, but the l1cmd eeprom won't show anything for that device, and l1cmd serial all will report bad checksum.
* I found it the hard way after I realised that I've overwritten a few bytes due to the way my i2c script worked.
Then, I looked at the dallas and was able to read its ID, but I couldn't read the EPROM contents - likely because of pull-up resistor that's somewhere on the board (and I had to use mine too) - that's the specific of 1wire protocol which uses ground and a single wire for power and signal.
Also, the dallas' eprom is *append-only* and it requires 12V programming pulse (which my super-duper device can't produce), I gave up on trying to read and reflash that.
So I took my soldering iron, and swapped the chips, and unfortunately no luck, 128MB V10 with both chips from V12 is still recognised as a V10 with 32MB RAM.
I even removed the small heatsink hoping to find other ID chips, and tried to remove the big one - but gave up, it's stuck on the chip and I don't want to damage a working card.
It is actually possible that SGI did put different chips but used the same RAM because it might have been what they had in stock that time...
canavan wrote:A broken V12 030_1996_001. If anyone wants to try soldering the eeproms from this board to a 128MB V10, it's available for the cost of shipping - or in exchange for a V12ified V10...
Where do you live and how much would the (cheapest) shipping to Japan cost ?
If yours is really broken, maybe I would be able to experiment a bit more (hard to do it on my working cards ensuring they continue working...).
Cheers
Unread postby recondas » Sun Jan 04, 2015 11:31 am
kubatyszko wrote:I finally had some time to play with the EEPROM's, V10's and a V12.
I really appreciate your efforts to keep this alive.
If you can work it out, V10 users worldwide will speak the name kubatyszko with hushed reverence. :D
kubatyszko wrote:I even removed the small heatsink hoping to find other ID chips, and tried to remove the big one - but gave up, it's stuck on the chip and I don't want to damage a working card.
I've had remove the heatsink from a couple of Fuel V12 so the hs could be trimmed to fit into an O350, and the process definitely ain't for the faint of heart. I took some photos of the BUZZ chip last time I did it (pretty sure that was hamei's O350/V12) and posted a cropped version in this thread.
Managed to find the uncropped original on a backup. Dunno if there's anything useful to you in the (slightly) wider view, bet here's a copy:
kubatyszko
Unread postby kubatyszko » Sun Jan 04, 2015 3:24 pm
Thanks, it seems it won't be as easy as it was with ATX PSU conversion though.
For a short time I *suspected* that small 8-pin chip in the upper right corner, I was able to read the markings off it with a lot of light and magnifying glass, but I don't think it's relevant.
The chip on the bottom right is likely a signal converter/buffer, so also a no bueno.
Another important point, is that if SGI was really making them the same with "decision" made after manufacturing, they would likely have had a header, and the only 2 headers are what I already mentioned - likely just for serial numbers.
There is a special many-pin header on the bottom side but that I'm not sure about.
Do we have any volunteers willing to take a heatsink off a V10 (ideally the 030-1826-xxx one) ?
