Q: Octane DIVO GALILEO15?
Unread postby vishnu » Tue Jun 07, 2011 12:35 pm
The SGI part number is 030-0931-004, apparently it's been archived out of techpubs, which to me is mystifying because they've still got content for the Octane's lower-end video add-ons, and I thought this was their top-of-the-line. I can't even find out which version of DMediaPro it is. So, my question: Does anyone have the user's guide, or any other relevant documentation? Thanks a bunch!
Here's a pic:
Re: Q: Octane DIVO GALILEO15?
Unread postby jan-jaap » Tue Jun 07, 2011 12:50 pm
That's an Octane Digital Video card. Goes with IMPACT graphics, precedes DMedia (which goes with VPro).
http://www.siliconbunny.com/data_sheets ... _video.pdf
Drivers at : http://www.sgidepot.co.uk/depot/
Unread postby vishnu » Tue Jun 07, 2011 12:56 pm
"Goes with IMPACT graphics, precedes DMedia (which goes with VPro)..."
Wow, did I ever guess backwards! Thanks jan-jaap, that's all I needed to know... :mrgreen:
Unread postby jan-jaap » Tue Jun 07, 2011 1:15 pm
:mrgreen:
Oh, and unless it comes with the ribbon cables to connect it to the graphics side, it's pretty useless.
Unread postby vishnu » Tue Jun 07, 2011 1:37 pm
Well here's another question then, DMediaPro DM6 ^h^h^h, sorry I meant DM10, is the top-of-the-line, but it doesn't work with Octane, so what is the highest DMediaPro that does? Work with Octane, that is.
The one that I was asking about does come with cables, it's on ebay right now: http://cgi.ebay.com/SGI-Octane-Digital-Video-I-O-030-0931-004-030-0932-002-/150592144023?pt=PCC_Video_TV_Cards&hash=item230ffdc297
Unread postby jan-jaap » Tue Jun 07, 2011 2:12 pm
vishnu wrote:so what is the highest DMediaPro that does? Work with Octane, that is.
If you want digital video I/O, there's the DM2 ( http://www.sgidepot.co.uk/octane2/3033.pdf )
The DMediaPro DM2 and DM3 Boards (for Silicon Graphics Octane2 V10 and V12
workstations and SGI Onyx 3000/Origin 3000 systems respectively), transmit and
receive uncompressed High Definition video and Standard Definition video in real-time.
You'll need a DMediaPro breakout box (VBOB) and a pair of LVDS cables as well
If you want to add graphics-to-video (GVO) capability, you can do that with a V12 + DCD and a DM5 option in the VBOB: http://www.sgi.com/pdfs/3281.pdf
Unread postby vishnu » Tue Jun 07, 2011 2:30 pm
Wow thanks! I don't know how you know all that jan-jaap, but I'm glad you do... :mrgreen:
Unread postby recondas » Mon Jun 13, 2011 8:07 am
If you don't run across a reasonably priced DM2, it's also possible to use the somewhat more common O2k/Onyx2-style Digital Video Option Board (DIVO) in an Octane.
viewtopic.php?f=16&t=16718766&p=7295080&#p7295080
viewtopic.php?f=14&t=13955
Unread postby vishnu » Wed Feb 29, 2012 11:21 pm
Somewhat belated update; I am now the proud owner of both a DM2 and a DCD, thanks to great deals I inked with our fellow nekochaner RichTom1, and I found a DM5-equpped VBOB on ebay for next to nothing, from a seller who obviously didn't know what they had. Now, you'd think I'd feel guilty about that but what's the Latin for let the seller beware? :twisted:
Unread postby uunix » Mon Mar 20, 2017 1:20 pm
This thing shows up as GALILEO15 at hinv in PROM, I have tried installing the drivers from the links above but have failed miserably so far.
http://www.siliconbunny.com/data_sheets/octane_digital_video.pdf
Octane is running 6.5.30, and I think I have it with 6.5.11_divodvc_2.4, but got to find the missing dependencies.
Can someone confirm I'm installing the correct one?
galileo for 6.5 doesn't support the IP platform.
Thanks
Unread postby recondas » Mon Mar 20, 2017 4:11 pm
uunix wrote: I have it with 6.5.11_divodvc_2.4,
6.5.11_divodvc_2.4 is the software package for the O2k/Onyx2 Digital Video Option. The Onyx2 Divo can be made to work in an Octane, but is definitely not a configuration that was envisioned/supported by SGI (so it may not be well supported by some editing applications).
j-j mentioned above that Ian has the software driver package for the GALILEO15/Octane Digital Video card.
Unread postby uunix » Tue Mar 21, 2017 4:39 am
Phew, that was hard work.. well it is when you don't RTFM ..
Drivers found in the UNBUNDLED folder Overlay 2 5.6.30
Digital Video: unit 1, revision 5.2, TMI: revision 2, CSC: revision
Zerolapse
Unread postby Zerolapse » Mon Jul 24, 2017 10:32 pm
Did you guys ever get reliable capture out of the DIVO-DVC in the octane?
If so what software are you using?
-Jesse
The current fleet.
Unread postby uunix » Tue Jul 25, 2017 12:37 am
Yes
Smoke / Flame
