Indy Internal VGA
pentium
Indy Internal VGA
Unread postby pentium » Sat Apr 09, 2011 7:53 pm
Was bored today and was fed up looking for a 13W3 adapter so pulled out the iron and a few things around the shop.
Means I can only use one GIO slot but oh well, it's not like I don't have three more of the damn systems. :roll:
Edit:
sgifanatic
Re: Indy Internal VGA
Unread postby sgifanatic » Sat Apr 09, 2011 10:43 pm
Very cool Pentium! I have seen couple of Wiki postings on this, but not based on the numbered pins on the Indy's mainboard. If you don't mind, could you please post the wiring diagram you used to get this to work?
pentium
Unread postby pentium » Sat Apr 09, 2011 11:07 pm
VGA                          13W3
1 ----------------------------R
2-----------------------------G
3-----------------------------B
4-----------------------------7
5-----------------------------8 (it's ground, so wherever)
6-----------------------------R shield
7-----------------------------G shield
8-----------------------------B shield
9-----------------------------NOT USED (key)
10---------------------------10
11---------------------------2
12---------------------------6
13---------------------------3
14---------------------------5
15---------------------------1
VGA Pinout
SGI 13W3 Pinout
sgifanatic
Unread postby sgifanatic » Sun Apr 10, 2011 3:53 am
Thank you very much!
PymbleSoftware
Unread postby PymbleSoftware » Sun Apr 10, 2011 5:14 am
Wiki'd here
R.
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
milatchi
Unread postby milatchi » Sun Apr 10, 2011 12:01 pm
Impressive, most impressive. --paraphrased from Darth Vader
"EV-ERY-ONE!" --Stansfield
duck
Unread postby duck » Mon Apr 11, 2011 10:30 am
Very nice work!
(Yes, I just wasted an hour or so sketching that thing in inkscape :-P )
___(o)=
\____)
pentium
Unread postby pentium » Thu Feb 25, 2016 8:15 pm
Five years later I want to point out that I really badly screwed up the 13W3 pinout and never saw sgifanatic's suggestion to fix that. :oops:
The one several posts above applies to other machines like the Onyx or Octane which use almost none of the extra pins on the 13W3 connector. Indy Newport Graphics however are a lot more monitor friendly and also supply a horizontal and vertical sync. The pinout is listed on page 201 of the Indy Owners guide but here's the proper wiring chart.
      13W3                                         VGA
1 (Monitor Type 3) ------------------------- 15 (ID Bit 3)
2 (Monitor Type 0) ------------------------- 11 (ID Bit 0)
3 (Composite Sync) ------------------------- N/C
4 (Horiz. Sync) ---------------------------- 13 (Horiz. Sync)
5 (Vert. Sync) ----------------------------- 14 (Vert. Sync)
6 (Monitor Type 1) ------------------------- 12 (ID Bit 1)
7 (Monitor Type 2 -------------------------- 4 (ID Bit 2)
8 (Ground) --------------------------------- 6 (Red Shield)
9 (Ground)---------------------------------- 7 (Green Shield)
10 (Ground) -------------------------------- 8 (Blue Shield)
A1 (Red) ----------------------------------- 1 (Red)
A2 (Green) --------------------------------- 2 (Green)
A3 (Blue) ---------------------------------- 3 (Blue)
9 (Ground)* -------------------------------- 5 (Ground)
N/C ---------------------------------------- 9 (KEY/DDC +5v)
*All grounds are common, so it doesn't matter if you use pin 8, 9 or 10.
Unread postby dexter1 » Fri Feb 26, 2016 5:07 am
I changed the wiki to reflect this. Let me know if it needs more work.
uridium
Unread postby uridium » Tue Oct 10, 2017 8:33 pm
Only just discovered this. Really like your work. Well done.
Al Boyanich
necron2600
Unread postby necron2600 » Thu Oct 12, 2017 5:51 pm
Any interest in making some to sell? I would buy a couple if you do have an interest.
Users browsing this forum: Bing [Bot] and 3 guests
