Mystery Crimson VME board
pentium
Unread postby pentium » Wed Nov 04, 2009 12:45 pm
Going from this thread, I bought that strange card that was listed on ebay for the purpose of using the black adapter board but I'm still very curious about the board that came with it.
When it arrived I found out that the two 50-pin connectors were on a second board and there was a red and green LED as well as an 18-pin connector on the main PCB.
I have tried googling up the numbers on the EPROM and the Performance Tech. chip but they got nothing and there is no part number on the board itself. what I do however know is that this DID indeed come from an SGI deskside of some sorts as the part number on the adapter matches up with an adapter board listed on B&B.
Here's some photographs. hopefully it shakes up someones memory on what exactly this is.
kshuff
Re: Mystery Crimson VME board
Unread postby kshuff » Wed Nov 04, 2009 4:15 pm
Its got a Motorola 68020 processor on it, what are the board part numbers?
-ks
See them all >here<
R-ten-K
Unread postby R-ten-K » Wed Nov 04, 2009 4:27 pm
That looks like a serial or FDDI concentrator board.
pentium
Unread postby pentium » Wed Nov 04, 2009 4:45 pm
kshuff wrote:Its got a Motorola 68020 processor on it, what are the board part numbers?
That is the problem. there is none, or at least there are none that google is finding.
Dr. Dave
Unread postby Dr. Dave » Wed Nov 04, 2009 5:02 pm
"PCC" = 'Programmable Communications Controller' maybe?
Look up the datasheets on those AMD chips at the bottom, that should give you a good idea.
wolflord
Unread postby wolflord » Wed Nov 04, 2009 7:51 pm
HIPPI board maybe? First spec for that was a 50 wire TP cable according to wikipedia....
WolfLord - :4D70G: :Octane2:
Unread postby jan-jaap » Thu Nov 05, 2009 1:02 am
R-ten-K wrote:That looks like a serial or FDDI concentrator board.
I've never looked inside an FDDI concentrator, but the VME FDDI board for Iris 4D's (a rebadged Interphase V/FDDI 4211) looks like this:
wolflord wrote:HIPPI board maybe? First spec for that was a 50 wire TP cable according to wikipedia....
I think so too. And Performance Technologies used to make them. That was when HIPPI was still called something else (turbo net?). I had spotted this board on eBay months ago, but the lack of drivers, bulkheads, or a system to connect it to stopped me from buying one of them.
At least you've got yourself a VME 6U-9U adapter :)
pentium
Unread postby pentium » Thu Nov 05, 2009 5:41 am
I thought HPPI was just another version of FDDI? :?
I'm totally confused now on it. I'm getting a million acronyms for HPPI (one being "High-Performance Peripheral Interface") and no pictures even remotely close to HPPI-looking (whatever that may be) appear on google images.
Someone please fill me in.
Unread postby jan-jaap » Thu Nov 05, 2009 6:13 am
pentium wrote:I thought HPPI was just another version of FDDI? :?
Certainly not.
FDDI is a network technology, like ethernet (or ATM). If you want to know about FDDI, read this: http://www.siliconsamsara.org/OLD/PracFDDI/index.html
I don't know much about HIPPI, but I do know it's not FDDI. I think HIPPI is (was ?) mostly used as a point-to-point interconnect, like infiniband.
HIPPI is a parallel interface using copper wiring, FDDI is a serial interface with a fiber optic transport.
pentium
Unread postby pentium » Thu Nov 05, 2009 8:18 am
So I could loosely say it was kinda like Craylink where you were link systems together to make something more powerful?
I'm still a little confused, mostly because I have never heard of it or seen pictures of it being used, ever.
wolflord
Unread postby wolflord » Thu Nov 05, 2009 10:27 am
pentium
Unread postby pentium » Thu Nov 05, 2009 11:48 am
Thanks. That really helped make me get an understanding of what HPPI is.
speaking of which, I think there is an HPPI board for the Onyx and challenge systems, correct? would anyone have photos of it and/or the bulkheads?
Unread postby recondas » Sat Nov 07, 2009 6:00 am
Had enough yet? :D Looks like there might be another candidate for your 6U VME board collection: http://cgi.ebay.com/Silicon-Graphics-SG ... 679wt_1016
Though this one isn't quite as mysterious: http://techpubs.sgi.com/library/tpl/cgi ... /ch01.html
It's intended to link a VME expansion chassis to an Origin 200(0) / Onyx2 <or with the right brick, even an O3k>: http://www.sgi.com/products/software/react/vme.html
kshuff
Unread postby kshuff » Sat Nov 07, 2009 7:16 am
No good without the XIO board and cabling though :(
-ks
See them all >here<
pentium
Unread postby pentium » Sat Nov 07, 2009 7:38 am
kshuff wrote:No good without the XIO board and cabling though :(
Exactly. Also, I don't really see what adding a VME backplane to my O2K would do as there were so few VME boards that even did anything under irix.
I'll let that pass as that dev board killed me. x_X
EDIT: I wonder how expensive and rare Irix-compatible GPIB boards are? At least I can think of a use for that: linking up my friends signal generator and scope! :D
