Tape hardware compatibility
competentcompton
Unread postby competentcompton » Fri Jul 24, 2009 1:14 pm
Hi,
I was looking to getting a decent size tape system for backups on my irix boxes. I was looking at maybe a scsi exabyte VXA-2E anyone have any success getting one of these working on irix 6.5.xx?
Any thoughts or experiences appreciated.
Cheers
shel
Re: Tape hardware compatibility
Unread postby shel » Sun Jul 26, 2009 11:13 am
I don't know about Exabytes, but I've had no problems at all using various DLT drives on both Sun and SGI machines; I've plugged them in and they Just Work.
-Shel
wolflord
Unread postby wolflord » Mon Jul 27, 2009 10:47 am
competentcompton wrote:Hi,
Cheers
Since I have pretty much any tape drive floating around at work...also where my Octane is, I went and checked it out for you. My octane is running 6.5.19F at the moment(I keep meaning to update it but keep not having time) and I can use the tape drive just fine. Scsi inquiry commands come back fine and mt works just fine as well. I ran a quick tar and that worked out fine too.
WolfLord - :4D70G: :Octane2:
Unread postby foetz » Mon Jul 27, 2009 12:11 pm
could you also try an ultrium?
wolflord
Unread postby wolflord » Mon Jul 27, 2009 5:33 pm
foetz wrote:could you also try an ultrium?
I've tried one before, under at least 6.5.19 they have issues. I'm going to do a new install on the system Wednesday probably so I can run another test with a newer version of Irix. Are you looking for mainly LTO-1?
Unread postby foetz » Tue Jul 28, 2009 11:23 am
yes, 1 and 2.
thanks in advance
competentcompton
Unread postby competentcompton » Tue Jul 28, 2009 6:41 pm
Hey thanks for checking that it. Sound like good news I'll probably go ahead and get one.
Thanks again
wolflord
Unread postby wolflord » Wed Jul 29, 2009 8:47 am
yes, 1 and 2.
thanks in advance
Ok, I had a bad drive for the first go round it seems...on the second drive Irix sees it as a generic 'cartridge device'. I was able to do the scsi inquiry commands, mt status commands and read and write to a tape using tar. In this case both drive types LTO 1 and 2 were scsi attached. Still running 6.5.19.
Unread postby foetz » Wed Jul 29, 2009 5:41 pm
wolflord wrote:Ok, I had a bad drive for the first go round it seems...on the second drive Irix sees it as a generic 'cartridge device'. I was able to do the scsi inquiry commands, mt status commands and read and write to a tape using tar. In this case both drive types LTO 1 and 2 were scsi attached. Still running 6.5.19.
good enough for me. much thanks! :D
competentcompton
Unread postby competentcompton » Tue Jan 26, 2010 4:26 pm
Hi,
long time since I first posted this.
I tried an EXABYTE on an irix machine and no luck thus far.
hinv reports
Tape drive: unit 6 on SCSI controller 1: unknown
Then when I try to use anything such as status I get the following
mt -f /dev/mt/tps1d6
No such device
I need to try this with a different machine to see if it a bad tape unit, but so far the EXABYTE is not working??
Any thoughts anyone??
Cheers
Unread postby recondas » Tue Jan 26, 2010 5:37 pm
IRIX uses /var/sysgen/master.d/scsi to identify and define the capabilities of tape drives. The file contains several for the Exabyte *8200 and 8500 8mm*, but no VXA-2 If there are any drives with similar hardware technology, you might be able to modify one using the procedure outlined in the nekowiki: http://www.nekochan.net/wiki/ ... r_IRIX_6.5 I'd strongly recommend you make a backup of the original /var/sysgen/master.d/scsi before you make any edits.
Some manufacturers wrote their own IRIX definition files - though it doesn't appear that Exabyte/Tandberg released one for the VXA-2 series:
http://www.exabyte.com/support/online/d ... rod_id=400
http://www.exabyte.com/support/products ... pe%20Drive
competentcompton
Unread postby competentcompton » Tue Jan 26, 2010 5:43 pm
Hi,
Thanks, I was playing with scsiha to see what it was reporting first, and then I thought I would dive into that file.
I wonder is wolfblitz? (sorry I forgot your name :oops: ) who said that it worked may have and entry in
/var/sysgen/master.d/scsi for the EXABYTE
It is a vxa-2 BTW.
Thanks for the link
Cheers
