Before I trash 3 quad Origin 300s...
jwhat
Re: Before I trash 3 quad Origin 300s...
Unread postby jwhat » Wed Jan 10, 2018 2:30 pm
Hi Numalinkers,
Posting on this old thread as I have 5 x O350 chassis and thinking of linking them all up with Numalink Router module (sgi part#: 013-3531-002).
This is later AC powered Numalink router for O300/O350 not O3000 series R-Brick version.
I have read all of good materials gathered together by regan: http://www.nekochan.net/wiki/Use_a_rbri ... Origin_300
So before leaping into this wanted to get some feedback.
1. There are two key issues:
A. If you use R-Brick need to force Mxxxx serial prefix onto Lxxxx prefix brick (ie move from 3000 -> 300)
B. Have Serial Number Security enabled so you cannot clear serial number to kickoff reassignment (via L2 or other numalinked machine)
As 1.A issues is a result of using R-Brick and only permanent fix is to do Dallas chip swap, presume if using the later Numalink Router module then this problem will not exist as it expect Mxxxx serials not Lxxxx ?
The 1.B issue can be trivially avoided by simply reflashing L1 to older version, by first starting router stand alone and then doing resets etc as per documented work around, then do serial clear using old L1 ?
I know you can force flash older L1 as I went down from final L1 version (1.48.1 I think) to older versions to get all my chassis’s L1s aligned.
This assumes that Numalink Router Module will continue to operate and be flashable irrespective of what L1 version it is on as long as you start it standalone in first instance.
Am I missing something ?
Right now this is just a thought as I have no Numalink Router module and don’t really want to spend $$ on one if I get stuck with unsuable device.
Note: did eBay on old Dallas chip part , but they do not seem to be available, do any Nekochaners have spare chip (allowing for worst case with need for chip swap) ?
Cheers from Oz.
jwhat.
Zerolapse
Unread postby Zerolapse » Mon Jan 15, 2018 12:20 pm
Jwhat,
As the person who discovered & documented much of this initially, I can tell you that you're on the right track.
In general, the chip swap (or initialization if you're electronically inclined) at any level of the setup should fix your issues, but order matters. Do you have an L2 controller? This is often the easiest way to set a "Master" Serial number. If you set it at the controller, you can force each machine to copy it as you plug them in by replacing their Dallas chips as well. Note that this essentially resets ALL of the NVRAM settings so take care to preserve the original chip in case you need to go back, and you will have to reset everything, including potentially brick type by hand via the L1 interface.
Swapping or initializing the chip makes the system believe the the NVRAM has been corrupted, so by default it copies an adjacent serial number in order recover (adjacent in this case meaning from the L2 controller, or another NUMA connected device). AFAIK it doesn't matter what L1 version you're at, this should still work at least on the O300 systems. I have not tried it on the O350, but it should be pretty inexpensive to test if you're brave.
Most newish SGIs (3* series origin/onyx/altix at least) use the Dallas DS1742W-120 which is no longer manufactured and difficult to find. However, the DS1742W-120+ supersedes it, and it does work just fine. This one was relatively easy to procure (I bought several from Mouser Electronics a year or two ago for about $22 US each) so you might try looking for one of those.
In any case, I've found that L1 firmware version 1.22.4 (built 07/21/2003 10:58:05) supports all the features I require and is relatively compliant when it comes to these sorts of exercises. I highly recommend using an L2 controller (I'm using a physical one, but the virtual L2 for Linux may work as well) and resetting the serial on one device at a time so they all match before you try to cable them together. If you have any old Dallas chips from another SGI, those will often work as well (I initially did this hack with the L1 from a dead Fuel). Again, you can also initialize the chips you have, but I suggest finding at least one so you have a way back if you mess up the first time.
Hope that helps,
-Jesse
The current fleet.
Zerolapse
Unread postby Zerolapse » Mon Jan 15, 2018 12:26 pm
Note that, I should have been more clear in the first paragraph. You will likely need to reset the router *first* to match your serial numbers. I suggest using the one from the O350 that has the Base-IO board in it. Set that one to rack 1, node 1, then set the L2 to match that serial number (before you plug it into anything). That way everything will carry a legitimate O350 serial. Once you have the L2 controller and the first node working together, try replacing the chip in the router and watch the log in the L1. If successful, you should see it copy the serial number from either node 1 or the L2. Be sure it's plugged into the L2's USB port before you power it up for the first time after the swap.
From there, any nodes that have security enabled could be reset the same way, one at a time, until you get them all to match. Work slowly and take care to configure the rack and slot numbers appropriately on each node.
The current fleet.
Unread postby vishnu » Mon Jan 15, 2018 9:07 pm
Digikey was stocking Dallas chips not too long ago but I just looked and they're not anymore. Checked Newark too, no soap. Now what are we going to do? :roll:
Zerolapse
Unread postby Zerolapse » Mon Jan 15, 2018 9:44 pm
Doh. :-( I wonder if there's another model that would be compatible. I expect that someone would have to spend a fair amount of time digging through spec sheets to figure that out....or harvest the chips from dead boxes. SGI's can't be the only application for these.
-Jesse
The current fleet.
Unread postby Raion-Fox » Mon Jan 15, 2018 10:02 pm
Could always gamble one of those eBay Chinese shippers
jwhat
Unread postby jwhat » Tue Jan 16, 2018 3:26 pm
Thanks Zerolapse (& others),
Here is some clarification on my setup:
1. 5 x O350 with all serial sync’ed (Mxxxxx) & rack/slot set from 01.01 to 01.05.
2. 3 x 0350 with L1 1.44.0 (IRIX 6.5.30), 2 x O350 with L1 1.40.5 (IRIX 6.5.29)
3. L2 , yes have 2. Both have serials in sync with O350 (Mxxxxxx), one at 1.48.0 (patchSG0007149), one at 1.40.1 (IRIX 6.5.29)
4. L3, yes have this installed on old PC and running fine, but now I have L2, I just directly Telnet to L2 from my Mac.
I am only using one L2 (other is spare) and have it connected to 2 x L1 USB for 2 separate configurations: [rackslot 01.01, 01.02 Numalink’ed] and [rackslot 01.03, 01.04 Numalink’ed + 01.05 CPU Less via XIO]
Reason I am looking at Numalink router is to join all these up into one (at which point I will also put spare IP59_4CPU board back into CPU less chassis).
Read all your (Zerolapse) contribution to thread and appreciate all testing and validation you have done.
Also did further search on eBay for Dallas chip and this time by only using part number found number of people still selling then. Ordered 5 for future safe keeping (as Dallas failure appears to be case of when rather than if).
My specific question is, can I avoid chip swap if using AC Numalink module (should already be happy with Mxxxxxx serials), rather than O3000 series R-Brick ?
Thanks again for all the hard work on serial numbers.
Cheers from Oz,
jwhat.
Zerolapse
Unread postby Zerolapse » Tue Jan 16, 2018 9:08 pm
Hey jwhat,
You're most welcome! I'm glad someone is putting it to use. All of the variations of the R-Bricks/NumaLink Modules/Etc I've seen for the 3 series Origin systems also have serial number based security. The brick basically learns the serial the first time it's plugged in then won't allow you to change it via normal means. As far as I'm aware the only difference between the A/C Numalink module and the R brick is really just a power supply. So in short, yes, a chip swap or initialization is probably going to be required, unless you can come up with the unlock codes for the Brick. At this point, that will likely be far more difficult than the chip swap. The chip in the R-Brick is particularly easy to get to, it only really requires removal of the cover and it's right there (and socketed so there's no soldering required :D).
-Jesse
The current fleet.
japes
Unread postby japes » Tue Jan 16, 2018 10:42 pm
I have a few of those DALLAS chips, I might have tossed one or two, but I'm saving them now. One day team IP35 is going to need to find out where to file down the case to graft in a new battery.
I haven't found a pin compatible replacement, I looked a while back the last time I saw this topic come up. Someone can search, but I think it's been over a year ago that we noted DigiKey and Mouser were down to their last ones, then done. Maxim says it's discontinued or whatever and there are no samples. Maybe if you want 100,000 of them they'll make you a run...so line up your 9,990 friends and we can all go in together and have 10 each.
I don't remember if I looked for something operationally compatible that could be put on an adapter board....that's something to consider.
japes
Unread postby japes » Tue Jan 16, 2018 10:49 pm
if your dallas chips work I wouldn't worry too much about them - somewhere around her I used an arduino or teensy actually to read the contents - they're only like 2k of data so you can save it, fill it with FF and then rewrite whatever was originally on it if you need to. Heck, you might be able to rewrite the serial number and be done with it.
jwhat
Unread postby jwhat » Fri Feb 23, 2018 6:32 am
Ok Numalinkers,
as with most things in playing with these old SGI boxes the numalink module had some problems...
I got reasonable priced AC numalink router module and expected have smooth sailing, based on prior experiences documented here.
My router had l1 flash version 1.28.3.
I immediately connected up box to L3/L2 Linux box via USB and got security warning when I tried to clear the serial number.
So open up box and dropped in Dallas DS1742-120+ chip .. expecting quick and easy serial re-programming process.
But router would not power on. It would boot to L1 and then come up with message about no "!NO L1 COMS!" on front panel and even when I pressed the physical power button, it would not power up.... button was simply non-responsive.
Though it was still plugged into L3/L2 Linux USB.
So I took out new chip and put back the old one just to confirm that it worked on with this and sure enough it powered up ok and I got serial mismatch error from L3/L2 controller.
So then tried it via hardware L2 and connected to Numalink. Still no luck with new Dallas chip, I simply could not get it to power up, so was kind of stuck.
So based on this thread and the original mechanism of first initialising chip via Fuel, I decided on variation of this approach which was simply to pull Dallas chip from my Onyx4 G2 chassis (which already had right serial / rack / slot config) and drop that into numalink router module.
This worked and module now came up with serial and rack / slot configuration from the G2 brick. So I now have working AC numalink router module and have tested this across 2 chassis, pending getting some more numalink cables and increasing the number of chassis connected.
But I hit a stumbling block with G2. I first put the new Dallas DS1742-120+ chip into this and it just hung on power up. No L1 message on LCD and no output from console serial put. Next I decided quick way to fix this was simply to put in the original chip from numalink router into the G2 chassis.
But now I get never ending stream of error message on serial console port on power up:
ALERT: NODE EEPROM read error, no acknowledge
On the L2 get the following:
M2004476-001-L2>config
L2 192.168.223.140: - 0001 (LOCAL)
L1 192.168.223.140:0:0   - 001c03
L1 192.168.223.140:0:5   - 001c04
L1 192.168.223.140:0:6   - C or I/O brick (422 connection) not configured
So it seems to recognise that there is something there, but I cannot configure this in any way as all l1 commands directed to the full address or ":0:6" short hand get error response from L2.
So I have gained a numalink router module but lost a G2 chassis....
I guess next step is to try a different Dallas DS1742-120+ chip (I have 6 of these) and if that does not work then I will need to find a new 2U_INT_53 system board...
Not the result I was hoping to get, as I wanted to numalink all five of my chassis's together and as I have extra 4x1GHZ IP59_4CPU board, I was going to try this out in the G2 chassis to see if if that would work.
For those interested here is picture of internals of AC router (you can see the Dallas chip):
and the new stack...
This is ebay special, so missing cover for switch (I have extra fans) and metal work got a bit bent around switch during shipping. I am now looking for switch cover plastics if anyone has them...
Also note that the third fan is just cosmetic and serves no useful purpose.
Any suggestions / tips on getting G2 back up and running ?
I will post update hinv once I have extra cables, which are now on way to Oz from eBay.
Cheers from Oz.
jwhat
jwhat
Unread postby jwhat » Fri Feb 23, 2018 10:39 pm
Hi Numalinkers/Chip Swappers,
did some more testing with bricked G2 chassis.
Pulled out ebay sourced Dallas DS1742-120+ and replaced it with another one from same batch.
Same result, no console boot info and no indicator on LCD and no activity on l1 USB port connected to L2.
So then put back the DS1742-120 from the numalink router module and also put in 4x1GHz IP59_4CPU board.
Same result as before ... scrolling "ALERT: NODE EEPROM read error, no acknowledge" message on console.
Next I pulled Dallas DS1742-120 chip from gutted Tezro desktop chassis. No success with this either.
Very frustrating. Looks like replacement 2U_INT_53 board is going to be needed, to get G2 chassis up and running again. Not the result I was hoping for.
Problem appears to be with l1. Is there a way to get turn on debug/diagnostics, when you can't get anything on serial console port ?
Is there a diagnostic port on the 2U_INT_53 board ?
Also goes "automagic" serial number reassignment work with only l1 connection to L2 or do you have to have numalink connection in place ?
EDIT: did test with no Dallas chip in chassis at all and got same behavior as per DS1742-120+ (ie no output on serial console). I am wondering if much tighter fit of 120+ might have damaged socket, resulting in other chip not working...
Cheers from Oz,
jwhat.
