Before I trash 3 quad Origin 300s...
Re: Before I trash 3 quad Origin 300s...
Unread postby recondas » Thu Jun 04, 2009 5:18 pm
Zerolapse wrote:Oh, btw...the easiest way to get the serials on your O300s in sync is to set the L2 to one they can set (prefix 'M') then do a 'serial clear' on each O300...if everything is wired properly it should pick up the serial from the L2 Controller automagically.
Jesse - some background info from you might prove equally helpful. Could you post an "hinv -vm" and a "serial all" for your R-Brick linked system? If you're not comfortable posting your serial numbers on-line, you could replace each of the last three or four characters with an 'x' without diminishing the value of the information.
Zerolapse
Unread postby Zerolapse » Thu Jun 04, 2009 6:15 pm
Well if it's for a good cause.... ;)
serial all:
001c01:
Local System Serial Number      NVRAM         M1000707
Reference System Serial Number  Attached L2   M1000707
Local Brick Serial Number       EEPROM        MHE126
Reference Brick Serial Number   NVRAM         MHE126
EEPROM      Product Name    Serial      Part Number           Rev  T/W
NODE        IP45_4CPU       MHE126      030_1728_002          B    00
IO8         IO8             MHE259      030_1673_003          E    00
EEPROM     JEDEC-SPD Info           Part Number        Rev Speed  SGI
DIMM 0     CE0000000000000027F50200 M3 46L2820BT1-CA0  0B    8.0  N/A
DIMM 2     CE000000000000000C6C6200 M3 46L6423CT2-CA0  2C   10.0  N/A
DIMM 1     CE00000000000000270D0300 M3 46L2820BT1-CA0  0B    8.0  N/A
DIMM 3     CE000000000000000C165A00 M3 46L6423CT2-CA0  2C   10.0  N/A
001c02:
Local Brick Serial Number       EEPROM        MHL667
Reference Brick Serial Number   NVRAM         MHL667
NODE        IP45_4CPU       MHL667      030_1728_002          B    00
IO8         IO8             MHL150      030_1673_003          E    00
DIMM 0     CE0000000000000026D2C400 M3 47L6510BT0-CA0  0B   10.0  N/A
DIMM 2     CE0000000000000026D1C400 M3 47L6510BT0-CA0  0B   10.0  N/A
DIMM 1     CE0000000000000026DBC400 M3 47L6510BT0-CA0  0B   10.0  N/A
DIMM 3     CE0000000000000026DAC400 M3 47L6510BT0-CA0  0B   10.0  N/A
001c03:
Local Brick Serial Number       EEPROM        MJC460
Reference Brick Serial Number   NVRAM         MJC460
NODE        IP45_4CPU       MJC460      030_1728_002          D    00
IO8         IO8             MJC508      030_1673_003          F    00
DIMM 0     CE000000000000000C3A2200 M3 47L6423DT2-CA0  2D   10.0  N/A
DIMM 2     CE000000000000002861BA01 M3 47L6510BT0-CA0  0B   10.0  N/A
DIMM 1     CE000000000000000C420401 M3 47L6423ET3-CA0  3E   10.0  N/A
DIMM 3     CE00000000000000285ABA01 M3 47L6510BT0-CA0  0B   10.0  N/A
001c04:
Local Brick Serial Number       EEPROM        MHX969
Reference Brick Serial Number   NVRAM         MHX969
NODE        IP45_4CPU       MHX969      030_1728_002          D    00
IO8         IO8             MJW733      030_1673_003          F    00
DIMM 0     CE000000000000000C843000 M3 46L2820DT2-CA0  2D   10.0  N/A
DIMM 2     7F7FFE00000000001200157A CM2201B            2     8.0  N/A
DIMM 1     CE000000000000000CDF4D00 M3 46L2820DT2-CA0  2D   10.0  N/A
DIMM 3     CE000000000000000C8C3000 M3 46L2820DT2-CA0  2D   10.0  N/A
001r05:
Local Brick Serial Number       EEPROM        KHR511
Reference Brick Serial Number   NVRAM         KHR511
POWER       RPWR            KHR511      030_1631_002          E    00
LOGIC       ROUTER          LGP178      030_1634_002          B    00
hinv -m -v:
       IP45_4CPU Board: barcode MHE126     part 030-1728-002 rev -B
             IO8 Board: barcode MHE259     part 030-1673-003 rev -E
       IP45_4CPU Board: barcode MHL667     part 030-1728-002 rev -B
             IO8 Board: barcode MHL150     part 030-1673-003 rev -E
       IP45_4CPU Board: barcode MJC460     part 030-1728-002 rev -D
             IO8 Board: barcode MJC508     part 030-1673-003 rev -F
       IP45_4CPU Board: barcode MHX969     part 030-1728-002 rev -D
             IO8 Board: barcode MJW733     part 030-1673-003 rev -F
          ROUTER Board: barcode LGP178     part 030-1634-002 rev -B
16 500 MHZ IP35 Processors
CPU: MIPS R14000 Processor Chip Revision: 1.4
FPU: MIPS R14010 Floating Point Chip Revision: 1.4
CPU 0 at Module 001c01/Slot 0/Slice A: 500 Mhz MIPS R14000 Processor Chip (enabled)
  Processor revision: 1.4. Scache: Size 2 MB Speed 250 Mhz  Tap 0xa
CPU 1 at Module 001c01/Slot 0/Slice B: 500 Mhz MIPS R14000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 500 Mhz MIPS R14000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 500 Mhz MIPS R14000 Processor Chip (enabled)
CPU 4 at Module 001c02/Slot 0/Slice A: 500 Mhz MIPS R14000 Processor Chip (enabled)
CPU 5 at Module 001c02/Slot 0/Slice B: 500 Mhz MIPS R14000 Processor Chip (enabled)
CPU 6 at Module 001c02/Slot 0/Slice C: 500 Mhz MIPS R14000 Processor Chip (enabled)
CPU 7 at Module 001c02/Slot 0/Slice D: 500 Mhz MIPS R14000 Processor Chip (enabled)
CPU 8 at Module 001c03/Slot 0/Slice A: 500 Mhz MIPS R14000 Processor Chip (enabled)
CPU 9 at Module 001c03/Slot 0/Slice B: 500 Mhz MIPS R14000 Processor Chip (enabled)
CPU 10 at Module 001c03/Slot 0/Slice C: 500 Mhz MIPS R14000 Processor Chip (enabled)
CPU 11 at Module 001c03/Slot 0/Slice D: 500 Mhz MIPS R14000 Processor Chip (enabled)
CPU 12 at Module 001c04/Slot 0/Slice A: 500 Mhz MIPS R14000 Processor Chip (enabled)
CPU 13 at Module 001c04/Slot 0/Slice B: 500 Mhz MIPS R14000 Processor Chip (enabled)
CPU 14 at Module 001c04/Slot 0/Slice C: 500 Mhz MIPS R14000 Processor Chip (enabled)
CPU 15 at Module 001c04/Slot 0/Slice D: 500 Mhz MIPS R14000 Processor Chip (enabled)
Main memory size: 11264 Mbytes
Memory at Module 001c01/Slot 0: 3072 MB (enabled)
  Bank 2 contains 512 MB (Premium) DIMMS (enabled)
  Bank 3 contains 512 MB (Premium) DIMMS (enabled)
Memory at Module 001c02/Slot 0: 2048 MB (enabled)
Memory at Module 001c03/Slot 0: 2048 MB (enabled)
Memory at Module 001c04/Slot 0: 4096 MB (enabled)
ROUTER in Module 001c02/Slot 0: Revision 1: Active Ports [1,2,3,4,] (enabled)
Integral SCSI controller 10: Version QL12160, low voltage differential
Integral SCSI controller 11: Version QL12160, low voltage differential
Integral SCSI controller 8: Version QL12160, low voltage differential
Integral SCSI controller 9: Version QL12160, low voltage differential
Integral SCSI controller 6: Version QL12160, low voltage differential
Integral SCSI controller 7: Version QL12160, low voltage differential
IOC3/IOC4 serial port: tty13
IOC3/IOC4 serial port: tty11
IOC3/IOC4 serial port: tty14
IOC3/IOC4 serial port: tty12
IOC3/IOC4 serial port: tty7
IOC3/IOC4 serial port: tty8
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Gigabit Ethernet: eg0, module 001c01, pci_bus 2, pci_slot 1, firmware version 12.4.10
Fast Ethernet: ef3, version 1, module 001c03, pci 4
Fast Ethernet: ef2, version 1, module 001c04, pci 4
Fast Ethernet: ef1, version 1, module 001c02, pci 4
  PCI Adapter ID (vendor 0x10a9, device 0x0009) PCI slot 1
IOC3/IOC4 external interrupts: 4
IOC3/IOC4 external interrupts: 3
HUB in Module 001c03/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
HUB in Module 001c04/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
IP35prom in Module 001c01/Slot n0: Revision 6.211
IP35prom in Module 001c02/Slot n0: Revision 6.211
IP35prom in Module 001c03/Slot n0: Revision 6.211
IP35prom in Module 001c04/Slot n0: Revision 6.211
USB controller: type OHCI
The current fleet.
PymbleSoftware
Unread postby PymbleSoftware » Thu Jun 04, 2009 6:21 pm
Cool thanks... apparently the electricity company is out at my place working on the meter box... So I will have a look at it again when I get home... Also I have updated the wiki entry a little..
Regan
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
PymbleSoftware
Unread postby PymbleSoftware » Fri Jun 05, 2009 7:29 pm
I used Mxxxxxx for L2 and cleared the Origin300s...
The router brick is a no go...
1.25 serial clear
001r25:
INFO: command not supported on bricks that enforce security.
Mxxxxxxx-001-L2>
I am going to have to talk to sgi or figure something out for myself..
Regan
死の神はりんごだけ食べる
PymbleSoftware
Unread postby PymbleSoftware » Fri Jun 05, 2009 8:00 pm
Here is a really crappy work around... :evil: :twisted:
unplug the USB on the router brick..
Power up the router brick at the back.
push the button on the front
Reconnect the USB cable at the back..
connect to the l1 on the router brick.
flash default a
reboot_l1
escape back to the l2
1.1 reset
1.2 reset
1.3 reset
....and...
***Warning: Board in module 001c01 is missing or disabled
It previously contained a New Type board, barcode  laser 0
***Warning: Found a new IP35 board in module 001c03, serial MJN491
Please use the 'update' command from the PROM Monitor to update the inventory
***Warning: Found a new IBRICK board in module 001c03, serial MHR530
DONE
**** System Configuration and Diagnostics Summary ****
CONFIG:
         No. of NODEs enabled    = 3
         No. of NODEs disabled   = 0
         No. of CPUs enabled     = 12
         No. of CPUs disabled    = 0
         Mem enabled             = 12288 MB
         Mem disabled            = 0 MB
         No. of RTRs enabled     = 1
         No. of RTRs disabled    = 0
DIAG RESULTS:
         ALL DIAGS PASSED.
System Maintenance Menu
1) Start System
2) Install System Software
3) Run Diagnostics
4) Recover System
5) Enter Command Monitor
Option?
hinv -mv
       IP45_4CPU Board: barcode KJD687     part 030-1797-001 rev -B
             IO8 Board: barcode MHL579     part 030-1673-003 rev -E
       IP45_4CPU Board: barcode MLJ194     part 030-1779-001 rev -C
             IO8 Board: barcode MLG164     part 030-1673-003 rev -F
       IP45_4CPU Board: barcode MJN491     part 030-1728-002 rev -D
             IO8 Board: barcode MHR530     part 030-1673-003 rev -F
          ROUTER Board: barcode LGP402     part 030-1634-002 rev -B
Processor 0: 600 MHZ IP35
Processor 1: 600 MHZ IP35
Processor 2: 600 MHZ IP35
Processor 3: 600 MHZ IP35
Processor 4: 500 MHZ IP35
Processor 5: 500 MHZ IP35
Processor 6: 500 MHZ IP35
Processor 7: 500 MHZ IP35
Processor 8: 500 MHZ IP35
Processor 9: 500 MHZ IP35
Processor 10: 500 MHZ IP35
Processor 11: 500 MHZ IP35
CPU 1 at Module 001c01/Slot 0/Slice B: 600 Mhz MIPS R14000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 600 Mhz MIPS R14000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 600 Mhz MIPS R14000 Processor Chip (enabled)
  Processor revision: 2.4. Scache: Size 2 MB Speed 250 Mhz  Tap 0xa
Main memory size: 12288 Mbytes
Memory at Module 001c02/Slot 0: 4096 MB (enabled)
Memory at Module 001c03/Slot 0: 4096 MB (enabled)
ROUTER in Module 001c03/Slot 0: Revision 1: Active Ports [2,4,5,] (enabled)
Integral SCSI controller 12: Version QL12160, low voltage differential
Integral SCSI controller 13: Version QL12160, low voltage differential
  Disk drive: unit 1 on SCSI controller 10 (unit 1)
  Disk drive: unit 2 on SCSI controller 10 (unit 2)
Integral SCSI controller 14: Version QL12160, single ended
  Disk drive: unit 1 on SCSI controller 14 (unit 1)
  Disk drive: unit 2 on SCSI controller 14 (unit 2)
Integral SCSI controller 15: Version QL12160, low voltage differential
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
Fast Ethernet: ef2, version 1, module 001c03, pci 4
  PCI Adapter ID (vendor 0x1077, device 0x1216) PCI slot 2
  PCI Adapter ID (vendor 0x1000, device 0x0054) PCI slot 2
IP35prom in Module 001c02/Slot n0: Revision 6.201
IP35prom in Module 001c03/Slot n0: Revision 6.210
and yes I did loose my licenses..
Warning:  Internet Gateway web server running as root.
          Use "chkconfig webface_apache off" to disable.
20:10:00 (lmgrd) -----------------------------------------------
20:10:00 (lmgrd)   Please Note:
20:10:00 (lmgrd)
20:10:00 (lmgrd)   This log is intended for debug purposes only.
20:10:00 (lmgrd)   There are many details in licensing policies
20:10:00 (lmgrd)   that are not reported in the information logged
20:10:00 (lmgrd)   here, so if you use this log file for any kind
20:10:00 (lmgrd)   of usage reporting you will generally produce
20:10:00 (lmgrd)   incorrect results.
20:10:00 (lmgrd)
20:10:00 (lmgrd)
20:10:00 (lmgrd)
20:10:00 (lmgrd) FLEXlm (v9.22) started on minnie (sgi IP35) (6/5/2009)
20:10:00 (lmgrd) Copyright (c) 1988-2003 by Macrovision Corporation. All rights reserved.
20:10:00 (lmgrd) US Patents 5,390,297 and 5,671,412.
20:10:00 (lmgrd) World Wide Web:  http://www.macrovision.com
20:10:00 (lmgrd) License file(s): /var/flexlm/license_minnie.dat
20:10:00 (lmgrd) lmgrd tcp-port 31411
20:10:00 (lmgrd) Starting vendor daemons ...
20:10:00 (lmgrd) Started sgifd (internet tcp_port 1028 pid 425)
20:10:00 (sgifd) FLEXlm version 9.22
20:10:00 (sgifd) Server started on minnie for:  WorkShop
20:10:00 (sgifd) f77            f90             cc
20:10:00 (sgifd) cpp
20:10:00 (sgifd) Wrong hostid on SERVER line for license file:
20:10:00 (sgifd)        /var/flexlm/license_minnie.dat
20:10:00 (sgifd) SERVER line says d2001411, hostid is "d1000707 d1000707 d1000707"
20:10:00 (sgifd) Invalid hostid on SERVER line
20:10:00 (sgifd) Disabling 1 license from feature WorkShop(5DC80594E4318BC7094D)
20:10:00 (sgifd) Disabling 1 license from feature cc(CD8875B4A559B36942D9)
20:10:00 (sgifd) Disabling 1 license from feature cpp(6D48356401F3D2D91E4F)
20:10:00 (sgifd) Disabling 1 license from feature f77(4DF87514954384D32D1E)
20:10:00 (sgifd) Disabling 1 license from feature f90(1DD875A4D7501F433E10)
Starting new eventmond...
No System change detected.
Regan
死の神はりんごだけ食べる
Zerolapse
Unread postby Zerolapse » Sat Jun 06, 2009 11:34 am
Interesting...is your flash A an old version?
-Jesse
The current fleet.
PymbleSoftware
Unread postby PymbleSoftware » Sat Jun 06, 2009 1:54 pm
Zerolapse wrote:Interesting...is your flash A an old version?
-Jesse
From memory it was something like
flash a 1.26
flash b 1.40
Regan
死の神はりんごだけ食べる
Unread postby recondas » Sat Jun 06, 2009 2:32 pm
PymbleSoftware wrote:Here is a really crappy work around... :evil: :twisted:
Vice nice - how'd you manage to come up with just the right combination?
PymbleSoftware wrote:and yes I did loose my licenses..
Could you manually write your original serial number on the L2 <with the "serial set" command>, then rerun your newly discovered serial number migration process so that your original licensed serial number is written to the O300s and the Router brick?
PymbleSoftware
Unread postby PymbleSoftware » Sat Jun 06, 2009 2:54 pm
Logically..
The "Some explanation" section on the wiki entry goes someway as to my thought process at the time.
Basically conflict at power on -> start things individually, then reset, also I suspected the new firmware might to stop people doing things like this but the older firmware once you realize it exists is still selectable.
I can not change the router brick. If I need to power everything down or the UPS fails then I will have to go through the sequence again. I should "return" the licenses to SGI as well as some others I had in previous configurations of this machine, anyway I just commented out my legal valid licenses and cut and pasted some illegal "works anywhere" pirate ones a very long time member sent me on this very forum a few years ago... and anyway the code I am currently working on is only 10,000 lines... I might only add another couple of thousand lines when I use a new GUI library. I probably won't have to throw 12 CPUs at it for parallel builds until there is several multiples of size of code...
I could raise a support ticket about the router brick but I don't think they would be very amused, even if they did have a clue. The general response has been, oh thats pre-linux stuff, we will have to find someone who knows about it.
Regan
死の神はりんごだけ食べる
Zerolapse
Unread postby Zerolapse » Sat Jun 06, 2009 7:47 pm
Wow that's interesting that it only checks on startup, that's quite an oversight (but great for us!!)...I guess that wouldn't fly in an enterprise environment though so they probably weren't too concerned....
PymbleSoftware wrote:I could raise a support ticket about the router brick but I don't think they would be very amused, even if they did have a clue.
I think you might actually have some luck with that...(hint, hint)
The current fleet.
Unread postby hamei » Sun Jun 07, 2009 12:21 am
Zerolapse wrote:I think you might actually have some luck with that...(hint, hint)
Rackable might be less anal-retentive than SGI was about these things. I can't help but think that more positive word of mouth about SGI would be a good thing, especially since it's close to free.
Congrats on the victory, Pymble :)
Unread postby recondas » Tue Jun 30, 2009 8:51 am
A very long shot - but it might be interesting to see how the R-Brick PROM and L1 controller exchange system serial number <SSN> information. The question will be how the firmware and PROM check the R-Brick's local system serial number.
While working out how the L1 and PROM identify the difference between an O350 and a Tezro rack system, bri3d and I discovered we could change the L1 system serial number prefix from the "M" the O350 uses to a "P" required by the Tezro rackmounted workstation <using an the L2 controller> to "change" the O350 into a Tezro. viewtopic.php?f=3&t=16721235
Admittedly the O350 didn't have serial security enforced, but might that mean it's possible to change the letter prefix of the local system serial number on the R-Brick without affecting the serial security check? Since the R-Brick and the O3x NUMAlink Module are so similar might the serial number prefix be the only difference <like switching the O350 to a Tezro by changing the serial number prefix>?
If you can change the serial number prefix without triggering the R-Brick's serial security, you could use the L2 controller to assign that "M" prefixed serial number to each of your O300s so they'd work with the B-Brick.
To find out you'd have to be willing to risk bricking some hardware.
    Start the L2 controller with nothing attached.
    Record the L2's current serial info <in case you'd like to restore it later>.
    Change the SSN in the L2 controller to the R-Brick's local system serial number - but change the "L" prefix to "M" <e.g. "serial set M1001241" - using your R-Brick's local serial number from an earlier post>
    Connect the R-Brick and see if will accept the M prefixed serial number.
If the R-Brick accepts the M prefix, leave that serial number in the L2 controller and use it to assign the number to each of your O300s.
If the R-Brick security won't allow a change to the letter prefix, an equally long shot might be to change on the the O300s to the "M" prefixed R-Brick serial number <while it's still in the L2> and try that as well <though I'd try it by starting everything from a cold boot>.
Another approach might be to try a different L1 controller in the R-Brick. It would appear from a google search for L1 part numbers that basic L1 hardware is shared across platforms - all of the ones I found were 030-1439-00x. Get one without the serial security set - say from a C-Brick. Install that into something besides the R-Brick and use the L2 controller to assign it the same serial number the R-Brick uses, but with an O300 friendly "M" prefix. Then use the L1 command "brick type r" to set the correct brick type <do this *last* - just in case a brick type of "r" auto-enables security>. Remove the newly configured L1 and install it into the R-Brick - if the L1 firmware is new enough to sense the presence of the R-brick and auto-enable serial security, hopefully it will lock in the now O300 friendly "M" serial.
Zerolapse
Unread postby Zerolapse » Tue Jun 30, 2009 10:28 am
I think I may have tried that during my R-Brick saga and I don't believe it works. But that doesn't mean we shouldn't try. :-)
-Jesse
The current fleet.
Unread postby recondas » Tue Jun 30, 2009 10:40 am
Zerolapse wrote:I think I may have tried that during my R-Brick saga and I don't believe it works. But that doesn't mean we shouldn't try. :-)
Jesse - do you recall if you also tried setting the O300 serial number to "M<numeric part of the R-Brick serial number>", or a different L1 in the R-Brick?
Zerolapse
Unread postby Zerolapse » Tue Jun 30, 2009 11:37 am
I believe I tried it both ways, but my memory could be failing me. I think the Origin 300 just doesn't like the M prefix for whatever reason and I'm pretty sure you can't change the R brick number at all without the security code. At least using convention means. :-) Apparently the R brick also employs some sort of crypto algorithm to protect the serial number, so unfortunately it's probably not as simple as burning a new one into the chip that holds it. However...downgrading the R-Brick's L1 firmware is possible...theoretically if you could find an old enough version you might be able to disable the security altogether.
-Jesse
The current fleet.
