dual head V6/V12: is it possible ?
yungjoon
Unread postby yungjoon » Fri Apr 03, 2009 2:12 am
Hi,
I have a spare V6 board.
Is it possible to mount the V12/V6 together on the same XIO carrier and have a dual display at different resolutions for each board ?
Yes I can ?...
My config: Octane2/R14K 600Mhz/2Go/V12/xbow 1.4/Irix 6.5.27.
Thanks,
yungjoon
Re: dual head V6/V12: is it possible ?
Unread postby recondas » Fri Apr 03, 2009 4:59 am
It is possible, but it won't be simple. There was a Dual V12 available directly from SGI as an option for the Octane2. That dual V12 option requires a special XIO carrier so that both V12 boards can be physically fit into the Octane2. You'll need that special carrier <or the skills to make or modify one>.
yungjoon
Unread postby yungjoon » Mon Apr 06, 2009 1:57 am
Ok, I can forget this.
I have also a spare ESI board, but I think that V12+ESI configuration is much more difficult to set up...
Thanks for your reply.
Unread postby SAQ » Mon Apr 06, 2009 9:43 am
I think the big issue would be actuating the XIO locking hardware. If you can figure out a way to do that it should work just fine, since ODYSSEY+ODYSSEY is supported. My guess is that the dual-Vpro carrier is mainly to actuate the XIO locks, anyway, since there wouldn't be any support screws on the chassis, right?
Perhaps look into the way the Origin2k handles XIO locking and then take a file to the metal plate..
Dr. Dave
Unread postby Dr. Dave » Mon Apr 06, 2009 7:24 pm
Stiff wire through one of the panel screw holes...
Zerolapse
Unread postby Zerolapse » Fri Apr 17, 2009 12:10 pm
This does work....I've done it with a V8/V6 setup before.... You just have to remove the bottom halves of the XIO carriers and for the love of god...be careful sliding the cards in there....
-Jesse
The current fleet.
