30'' LCD Monitor for Tezro, possible?
modology
Unread postby modology » Mon Sep 29, 2008 6:13 pm
Hi I am planning to buy Dell 30'' LCD UltraSharp (2560x1600). My only concern is that it needs DVI-D. I wonder this LCD screen is compatible with Tezro system V12, DM3, DM5 + BOB and can V12 graphic card support 2560x1600 high resolution? Thanks
Re: 30'' LCD Monitor for Tezro, possible?
Unread postby recondas » Mon Sep 29, 2008 6:59 pm
pip
Unread postby pip » Mon Sep 29, 2008 7:17 pm
Any resolution above 1920x1200 requires dual-link DVI. The linked list of supported resolutions doesn't list anything above 1920x1200, so I don't think the V12 has dual-link DVI.
:Octane: R12K/300x2, MXE
:Indy: :O2: :1600SW: :ChallengeL:
modology
Unread postby modology » Tue Sep 30, 2008 4:22 am
:? wat if I use DVI-D to VGA adapter, would it work? Is there anyway that we can force IRIX resolution to 2560x1600 though V12 might not be able to?
schleusel
Unread postby schleusel » Tue Sep 30, 2008 8:56 am
Sorry, no chance :(
2560x1600_60hz means a pixel clock frequency of > 300 MHz, while the single-link DVI port on the V12 is limited to 165 MHz. Using a VGA adapter won't help either as the VPros in general are limited by a slow 220 MHz DAC. I doubt the 30" display would accept 2560x1600 on the analog port anyway though..
hmm.. It should theoretically be possible to produce a 2560x1600_30hz mode which would reduce the needed frequency to around 160 MHz, i.e. should even be possible through single-link DVI. But i'm almost certain the 30" display would refuse to accept that one :(
modology
Unread postby modology » Tue Sep 30, 2008 9:34 am
thanks alot for enlightening me. It's sad to realize that even an most recent Tezro system is getting outdated through time and it's sad that SGI has dropped this platform. I gonna stick with 24'' then.
Unread postby recondas » Tue Sep 30, 2008 9:51 am
modology wrote:gonna stick with 24'' then.
You can still pick up a little more screen real estate. A V12 with a DCD can run two 24" LCDs, each at 1920x1200. And the difference in cost between a 30" and two 24s might be enough to pay for a DCD.
D-EJ915
Unread postby D-EJ915 » Tue Sep 30, 2008 12:36 pm
If you can rotate the screens or use portrait resolutions with the DCD the Eizo 30" lets you split the screen in half and drive each side off a different input. Not sure if any other ones do that or not, I know the IBM 22" did something similar in one of the versions but each side would have been a 30" monitor...
Unread postby hamei » Tue Sep 30, 2008 7:10 pm
recondas wrote: ... enough to pay for a DCD.
I happen to have one of those which I would trade for a faster Fuel cpu ... (800mhz)
schleusel
Unread postby schleusel » Wed Oct 01, 2008 3:16 am
D-EJ915 wrote:If you can rotate the screens or use portrait resolutions with the DCD the Eizo 30" lets you split the screen in half and drive each side off a different input. Not sure if any other ones do that or not, I know the IBM 22" did something similar in one of the versions but each side would have been a 30" monitor...
Nice - didn't know there was a 30" that could be driven by two single-link channels.
That ridiculously high DPI IBM display (or the rebadged ViewSonic version) was actually supported on the Tezro. Only on the rackmount version though as it is driven by four single-link channels, i.e. you need dual V12 pipes each with the DCD in place ;-) .. 3840x2400 on 22" - just sick :-)
So i appears to be possible to produce such complex modes for the V12 - if you find somebody with the vfc skills to do so. I was even too stupid to build regular DCD modes when I tried it.. ;-)
modology
Unread postby modology » Wed Oct 01, 2008 4:48 am
Can it be done in tower form Tezro? I wonder if we can plug in second V12 DCD in as well
schleusel
Unread postby schleusel » Wed Oct 01, 2008 5:08 am
modology wrote:I dont quite get it. Does it mean I have to get the second V12 DCD in order to do so? You mentioned 3840x2400 on 22"-hmm....is it even possible?
Yes, you'd need two V12 boards and two DCD option boards to get the four (single-link) DVI outputs needed to drive the display. Each of these four channels would then provide one 960×2400 stripe or 1920×1200 tile which the display internally combines to 3840x2400:
http://en.wikipedia.org/wiki/IBM_T220/T221_LCD_monitors
As the desktop Tezro only supports one V12 board plus DCD for a maximum of two channels this combination is only possible in a dual module rackmount Tezro. And even if you have all that hardware, you'd likely still need SGI to set it up for you as the video mode files etc. needed for that aren't included in stock IRIX.. :)
Unread postby recondas » Wed Oct 01, 2008 5:28 am
schleusel wrote:Nice - didn't know there was a 30" that could be driven by two single-link channels.
That would be a very nice use for a DCD equipped V12 - if the 13W3-to-DVI connection issue could be resolved, it'd be extra slick on a dual-pipe InfiniteReality system <and setting up the 1200x1920 display modes with ircombine would be relatively simple when compared to the VFC process required by the V12>.
schleusel wrote:So it appears to be possible to produce such complex modes for the V12 - if you find somebody with the vfc skills to do so. I was even too stupid to build regular DCD modes when I tried it.. ;-)
That means there probably isn't much hope for the rest of us.
modology
Unread postby modology » Wed Oct 01, 2008 5:33 am
;) MYTH BUSTED
Unread postby hamei » Wed Oct 01, 2008 7:13 am
schleusel wrote:That ridiculously high DPI IBM display (or the rebadged ViewSonic version) ...
Neat ! Also very cute the way the carefully avoided mentioning the word IBM :D
The Eizo looks great but three grand ? Do you think they'd offer a sub-prime mortgage on it ?
